Old 26th April 2017, 18:28   #571
RSR
RSR's Avatar
Thanked: 4,549 Times
Default Re: Hyundai Xcent : Official Review
Originally Posted by srihari154 View Post
Hi All,
I still have stock tyres running 165/65 R14 (Steel & Alloy). Hence was wondering if the stock tyres can be upgraded to something better to improve the ground clearance, better if it would be a straight fit without any major changes.
Also Is it possible to upgrade the stock headlights to something better without any wiring changes or any uncessary load on the battery?
Hi! You can certainly upgrade both.
For tyres, upgrade to 175/65 R14 ones from the stock 165/65 R14 tyres. GC will increase by about 6.5 mm.
For headlamps, go for Osram Nightbreakers or Philips Extreme Visions. They are of the same wattage as the stock bulbs, but are brighter. The improvement varies depending on the reflector design. Do note that these tend to have a shorter life than regular bulbs.
Also, for better illumination, you can use your fog lamps while driving at night, in addition to the headlamps.
RSR is offline   (1) Thanks Reply With Quote
Old 10th May 2017, 09:42   #572
A/c does not work well if the car is slightly hot - had a bad experience as I had a long drive through the day. Service centre keeps denying that there is any issue!!!
tomjoe is offline   Reply With Quote
Old 10th May 2017, 11:33   #573
AkMar's Avatar
Thanked: 1,375 Times
The Xcent has a weak AC inspite of rear AC vents. In summers the AC cannot chill the cabin. It will just manage to keep temperature at comfortable levels. I am afraid service centre might not be able to do much about this.
AkMar is offline   Reply With Quote
Old 13th May 2017, 12:38   #574
Thanked: 13 Times
Which model are you referring to petrol or diesel. I have a diesel Xcent and would say the AC is very good cools the cabin quickly and also keeps the temperature cool.
Even when parked in the hot Sun for a few hours the cabin cools down way faster than my Swift.
sheldon4888 is offline   (1) Thanks Reply With Quote
Old 13th May 2017, 15:57   #575
RSR
RSR's Avatar
I believe this may be a specific technical issue with Xcents (especially petrol ones) that are equipped with the automatic climate control system (ACC). In all the diesel Xcent taxis (without rear A/C vents) that I have travelled in, the A/C cooled the cabin very well, keeping me quite cool even at the rear in summer.
To those who're facing an issue with the Xcent's A/C, could you please share the type of A/C (manual or ACC) your car has, and the fuel it runs on?
RSR is offline   Reply With Quote
Old 14th May 2017, 09:09   #576
Hi, I have an Xcent Manual Petrol (Manual AC) and the AC does struggle to keep the cabin cool in direct sunlight. You just have cool air blowing from the vent but the rest of the cabin remains warmer. I believe its due to the smaller compressor used in the Xcent and Grand i10.
aramosfet is offline   (1) Thanks Reply With Quote
Old 14th May 2017, 10:37   #577
Thanked: 7 Times
Mine is an Xcent Automatic (Pertrol) model. Suffer the same problems. Get some air from the vent. Car remains warmer. The rear seat vent is space waste. Could have got rid of it. No use whatsoever.
kayvwar is offline   (1) Thanks Reply With Quote
Old 14th May 2017, 15:50   #578
Thanked: 22 Times
Had the same issue about the ac not cooling at all in my petrol xcent. Then sent the car to the service centre where it was diagnosed that the ac filter was choked . After cleaning the cooling has improved significantly . Since the service interval is 1 yr might be worthwhile getting the same cleaned atleast 6 monthly.
amidoc is offline   (1) Thanks Reply With Quote
Old 16th May 2017, 11:43   #579
AkMar's Avatar
Ours is a petrol Xcent with manual AC.
AkMar is offline   (1) Thanks Reply With Quote
Old 13th June 2017, 14:49   #580
JD1
Thanked: 152 Times
Every 3-6 months I visit service center and get my AC filter cleaned (Bangalore / Petrol AT). After cleaning it performs well for a couple of months and then even the LO setting is just a helicopter making loud noise but not as much effective as I would have liked.
JD1 is offline   Reply With Quote
Old 13th June 2017, 15:41   #581
Thanked: 109 Times
Count my Xcent in on this.
Ours is a Petrol SX(O) variant. As mentioned in another reply, after doing the cleaning of A/C vents and filter, the A/C effect remains good for a month or so, and back to square one after that.
My family really complains about the power of the rear AC vents.
hamster is offline   (1) Thanks Reply With Quote
Old 15th June 2017, 09:35   #582
shatananda.k's Avatar
Thanked: 18 Times
Had a scary experience driving on ORR y'day. The steering wheel suddenly turned lifeless. Luckily, I was able to stop the vehicle in a corner and switch off the ignition.
On restarting, the behaviour was not observed again.
This problem has been mentioned earlier also. Is there any resolution ?
My 2 year service is due next week. So any inputs will help
shatananda.k is offline   Reply With Quote
Old 15th June 2017, 10:42   #583
nsbhagwat's Avatar
Thanked: 46 Times
Hi, is the AC filter cleaning a DIY job or we have to visit HSC?
Does the filter choke due to dust or pollen from all the trees?
Nikhil
nsbhagwat is offline   Reply With Quote
Old 15th June 2017, 14:45   #584
JD1
Thanked: 152 Times
Nikhil
I have not done a DIY as what the SA told is that you have to remove the panel (don't remember if it was behind dashboard or glove compartment) to access the AC filter. Since it is typically in warranty, I have never been charged for this service. If you aren't sure, you can also visit during one of their customer appreciation days and get these minor things serviced for free
I have seen the AC filter getting black (before cleaning) so I guess that is the dust from Bangalore roads. Once it's cleaned, the results are instantaneous (till about a month or two!)
Old 19th June 2017, 21:18   #585
Nikhil
I came across this video on cleaning cabin air filter in Xcent and tried it during the weekend. Its fairly easy to do.
I can confirm a modest improvement in the AC cooling. I haven't tested it much as it has been rainy and overcast here for the last few days.
Hyundai Xcent : Official Review-img_20170617_130650.jpg
Honda Amaze vs Maruti Dzire vs Hyundai Xcent girishglg Sedans 175 18th June 2015 23:33
Petrol: Hyundai Xcent or VW Polo? gigatech2006 What Car? 45 1st July 2014 17:59
Hyundai Xcent (Grand i10 Sedan) caught testing : Now launched @ Rs. 4.66 lakh CARDEEP The Indian Car Scene 263 7th April 2014 21:39
