Old 25th January 2015, 11:34   #211
Thanked: 213 Times
Default Re: Mahindra Scorpio : Official Review
Took a TD of the new scorpio today. One problem I encountered is that I couldn't see the center touchscreen panel AT ALL in sunlight. It's too vertical, perhaps they should have had it at a slant or put some non-reflective material on it. Could see it fine in the shade. But even then, operating that while driving could turn out to be a major pain.
A question I have is why is the engine warranty for only 75,000 Kms or 2 years? As opposed to the toyotas which have probably upwards of 100,000 kms or 3 years. Is this any indicator of engine reliability?
farhadtarapore is offline   Reply With Quote
Old 25th January 2015, 14:43   #212
Thanked: 205 Times
The HU is a bit of a problem with direct glare. I don't have to look at the HU for most practical purposes while driving and this is my experience. Only pain may perhaps be from the NAV to look and drive. That also gives you voice over. But certainly an angle of anti glare screen could have been been a welcome.
Th engine is bullet proof and know old MHawks done over 2 lack with not a fastener opened beyond the timing case and clutch bell.
In fact this version is a de-tuned 120 BHP running low rations. Given that the engine is expected to last longer. If it perhaps had further reduction in the higher gears like the XUV the engine would do better. But heavy reduction in a rear wheel driven car will result in a lot of vibration like the 6th gear on the Contessa at low RPM.
Some quick good to haves-
  1. Disk brake in the rear
  2. Point for grease in the propeller shaft Unions stars (perhaps the sealed joint have good grease and may last longer -don't know)
  3. XUV tune (140 BHP) and Gearbox
  4. Wheel base extension could have been between the wheels there by additional leg space and better suspension dynamics. Currently it is extended in the front.
  5. Engine could be dropped further down and improve stability by lowering the CG
  6. Plastic pinning in the mud flaps, bumper are all flimsy
Storage and all the other small things that make a big difference have been discussed in the past
Miyer is offline   (3) Thanks Reply With Quote
Old 3rd February 2015, 10:10   #213
sdp1975's Avatar
Thanked: 972 Times
Has the new Scorpio been crash tested by any car assessment programs ? I believe the older Scorpio got a very poor rating in the ANCAP program.
Also , Mods, it would be very helpful if you can post a separate review for the 4x4 variant as you did for the Storme.
sdp1975 is online now   (1) Thanks Reply With Quote
Old 3rd February 2015, 12:06   #214
Thanked: 443 Times
I believe the new Mahindra Scorpio is yet to go under hammers of NCAP. The Mahindra Scorpio isn’t sold in Europe and hasn’t been tested by Euro NCAP either.
Though Mahindra had claimed that the new chassis would enable to incorporate the “new safety” regulations to be implemented by Govt of India, I guess it would not be to the effect of NCAP’s requirements.
However, Mahindra does offer dual front airbags on the Scorpio (S6, S6+, S8 and S10 and now even with S4+) variants while ABS is standard on the S6+ variant and upwards. The car gets panic brake indication (if you brake hard over 100 km/hr than the hazard lights will turn on).
It would have been nice if Mahindra had given the Scorpio side airbags, at least as an option!
LoneRidder is offline   (1) Thanks Reply With Quote
Old 5th February 2015, 10:15   #215
windiesel's Avatar
Thanked: 55 Times
Any info on the Automatic? Are they coming out with a slush box or an AMT?
windiesel is offline   Reply With Quote
Old 17th February 2015, 12:19   #216
quadra's Avatar
Thanked: 58 Times
Inquired from a local dealer, s4+ 4wd is definitely available. The dealer however confirmed that you cannot install a 2 DIN HU, only single DIN HU can be attached on this model.
The dealer was however not able to answer my other query on whether it is possible to fit LED eyebrow headlights on S4+ model. I just wanted to know a) if its feasible and b) what is the cost of replacing the entire headlight unit with that of S10.
Powerdrift video on scorpio talks about some piece of hardware moving from left to right (vice-versa) when taking a turn. Check this video at 5.33. Does anyone know what exactly it is?
quadra is offline   Reply With Quote
Old 17th February 2015, 12:49   #217
Sheel's Avatar
Thanked: 5,649 Times
I did hear that sound, but I am sorry, it is not there either in my VLX 2WD or my S10 4WD.
But I think I have heard this sound in few Scorpios.
Old 17th February 2015, 15:40   #218
Thanked: 443 Times
Oh yea, that's the lug wrench kept loose below the middle seating. Its long and loose, keeps moving left to right. A simple well-crow tricking could have held it tight!
LoneRidder is offline   Reply With Quote
Old 20th February 2015, 23:29   #219
Thanked: 40 Times
Yes sunlight visibility of unit is not good but would you really need to operate in bright sunlight.
I am finding the placement of touchscreen nice . Easy to use using elbow as a pivot on the arm rest .
Not sure if people have noticed . The player volume is speed sensitive, the volume increases with increase in speed.
ManuMacher is offline   (2) Thanks Reply With Quote
Old 21st February 2015, 09:11   #220
Thanked: 205 Times
Caution Scorpio Owners-
There is a loss of Brake and Clutch pedal if the car experiences G forces. For instance if the car rolls over a speed bump/ramp (with the typical take off and land approach), when the car lands the fluids are still in flight and there is a loss of pedal. I recollect this problem with the initial TATA SUMO's and loss of control leading the car to turn turtle during fast curves.
A free rolling ball bearing contraption was used in the master cylinder to bear down on the fluid and fix the problem.
M&M, are you hearing the problem. Please fix this immediately.
Miyer is offline   (2) Thanks Reply With Quote
Old 22nd February 2015, 19:13   #221
s4ch's Avatar
Any further information on the automatic? I'm holding back on the current one to get the automatic instead? Anyone got any inside information?
s4ch is offline   Reply With Quote
Old 2nd March 2015, 16:19   #222
methecupid's Avatar
Thanked: 651 Times
I guess I will be able to answer both your questions, since I have got both of them done on my blue streak.
Concerning the first one, I got that done right after my car was delivered. Don't even let the dealer touch it. One thing I can say right now, its a royal pain. I have written about the installation done by one of the most genuine installers I have been to here in Mumbai. But the fact that it needs the utmost care cannot be magnified enough. (Installation time: 8.5 hours)
http://www.team-bhp.com/forum/mumbai...ur-mumbai.html (In-car Entertainment - Reliable Radio (Lamington road & Chembur, Mumbai))
Regarding the LED strip on the headlights, if you notice; the place where S10 has the tube, the variant has swapped it for a metallic strip. It also needs to be done by someone who has experience is installing the LEDs into headlights. The biggest challenge that I saw was to open the seal of the headlights and then eventually resealing it. A mistake in either of them will mean you will have a leaking HL unit. (Installation time: 3.5 hours)
methecupid is offline   (2) Thanks Reply With Quote
Old 3rd March 2015, 01:28   #223
Thanked: 116 Times
I dont know whether It has already been discussed in this thread or not, but saw two Scorpio NG's without the black strip on the back doors near DND flyway having temporary registration numbers. One was a white scorpio and other was black, both without that infamous cladding. A quick chat with mahindra showroom contact confirmed that they will be getting the new ones shortly within 7-8 days.
Storme_on_d_way is offline   (1) Thanks Reply With Quote
Old 3rd March 2015, 10:33   #224
m_upreti's Avatar
Thanked: 311 Times
About time they got rid of the patch. Somehow now it makes even better sense never to buy a M&M immediately after it is launched. One should always wait. and let them experiment on the first few batches before they get the market feedback and change.
Few more things they should be looking at changing / providing:
1. Remove the pseudo handle on to of the tail lights and either bring back the reflector cluster or have it something like an XUV500 has.
2. Remove the roof antenna and bring in a glass embedded one. This would be a relief for people living in high rainfall areas as the antenna hole invariably leaks after some time.
3. Provide indicators on the ORVM's
4. Provide a decent storage space for the tools including the jack handles etc.
m_upreti is offline   (1) Thanks Reply With Quote
Old 5th March 2015, 11:32   #225
Thanked: 40 Times
The reverse camera for S10 is available at Mahindra Accessory. I have it installed at IG, St Marks Rd, Bangalore. ICE needs a firmware update and I am waiting to see it in operation.
ManuMacher is offline   Reply With Quote
Mahindra Quanto : Official Review GTO Official New Car Reviews 298 29th January 2018 13:59
Bringing home the Mahindra Scorpio LX. EDIT : Scorpio finds a new home! benbsb29 Test-Drives & Initial Ownership Reports 168 8th January 2015 11:22
Mahindra Scorpio's Photos - Scorpio Xtreme hotkar Modifications & Accessories 35 3rd March 2012 23:43
