Old 31st May 2015, 12:37   #91
Torino's Avatar
Thanked: 480 Times
Default Re: Maruti Alto K10 : Official Review
It is quite maddening and sometimes panicking to not find the clutch lever and a gear lever.
Haven't tried Manual mode yet. But performance is fantastic for a car if this size.
Hi Anurag. Ha Ha, even I felt the same moving from my Ertiga. After having a brief drive in your K10 I bet at least for once you will forget about pressing the clutch when slowing down when driving your Swift. You will be fine once you swap cars often. You will appreciate the M mode after mastering the D mode.
Its performance will always surprise you. The quote from official teambhp Alto K10 review "..power-to-weight ratio of 91 BHP/ton (equal to the VW Polo GT TSI)!!"
Torino is online now   Reply With Quote
Old 1st June 2015, 13:07   #92
Thanked: 1,067 Times
Default Re: Maruti Suzuki A-Star Auto - Road Test
I run my Alto K10 less than 3K km/year, even then I am getting it serviced every year. In my case the costs are even lower at around 2.2K/service (including oil and filter change, air filter change and tuning).
Old 1st June 2015, 21:28   #93
outdoorlover's Avatar
Thanked: 63 Times
Aroy, I think it's important to have it serviced as per the manufacturer's schedule notwithstanding how little you drive it. I changed my engine oil to synthetic in the last service and I am glad that I did as the engine smoothens out well with synthetic.
outdoorlover is offline   Reply With Quote
Old 8th June 2015, 13:16   #94
Thanked: 79 Times
The Alto-K10 got brushed by a 2 wheeler and the right door mirror is broken. I am scouting for a replacement part (Part Number 84740M67P00) in Pune for the last 10 days without success.
What is the experience in other cities of procuring such consumable spares for the new Alto-K10?
shajoshi is offline   Reply With Quote
Old 8th June 2015, 13:42   #95
Thanked: 7 Times
We decided to buy Alto k10 VXi/VXi(O). How efficient is Airbags in Lower segment like Alto? Is it worth to spend 30K more for Driver Airbag?
guru0101 is offline   Reply With Quote
Old 8th June 2015, 15:51   #96
Torino's Avatar
Thanked: 480 Times
Hi guru0101. It is always recommended that you opt for the safety feature if you can. The steering wheel airbags in all Maruti cars will have same components and mechanism and you have nothing to worry about the airbag in the Alto. Manufacturers will not compromise on quality standards especially when it comes to safety equipment across the OEM's product range. With the recent Takata airbag issue, all the automotive safety manufacturers will ensure zero defect in their products. IIRC Maruti airbags are manufactured by Autoliv.
Old 8th June 2015, 16:00   #97
Thanked: 79 Times
Airbag is a great active safety feature. Wonder why Maruti does not provide it as an OEM Accessory across its range for a price? Also the AMT model does not get an Airbag - which is also weird.
Old 8th June 2015, 16:30   #98
Thanked: 14,321 Times
Without any safety equipment the OTR for the K10 AMT VXI goes to 5L in some cities.
Many shy away thinking why pay 5L for an Alto?! I'll put some more money and buy a bigger segment car.
a4anurag is online now   Reply With Quote
Old 8th June 2015, 20:13   #99
Since the new K10 is not selling high enough or the Alto 800 or WagonR or Swift so parts stocks are low hence the delay.
Old 27th August 2015, 11:40   #100
frostbite911's Avatar
Thanked: 246 Times
Hi All,
I have had my K10 for six months now (odo clocked at 3800km). For the past two days, i have been experiencing severe engine vibrations (Car started sounding like a tractor at one point). I checked the engine and i noticed that the two screws that hold the engine air intake pipe (please excuse me if that's not what its called) are loose and were rattling. I also noticed that the engine vibration on the left side is quite a lot.
In the pic enclosed, the two screws circled in red are the ones that came off. The area circled in blue is the part that has been vibrating a lot. I'm not sure if this part is supposed to be bolted tight or if its meant to be kept loose.
Have any of you faced this issue? Do help me out.
Thanks in advance
Maruti Alto K10 : Official Review-img_20150221_170156.jpg
frostbite911 is offline   Reply With Quote
Old 27th August 2015, 18:09   #101
Originally Posted by frostbite911 View Post
Hi All,
Thanks in advance
All screws are meant to be tight.
Just take the car to MASS and get the engine mounts checked. Seems that the the mounts have become loose.
Another reason may be the spark plugs. The symptom is hard start, reduced FE and sluggish acceleration. If so, check the cables leading to the plugs. Pull them and then push them tight.
Aroy is offline   (1) Thanks Reply With Quote
Old 27th August 2015, 21:44   #102
Red Circled: Air intake pipe holder;
Blue Circled: Engine mount.
I can't understand how can the engine vibrate within 6 months of ownership. Do get them tightened and the mounts inspected. If faulty, get both of them changed under warranty.
a4anurag is online now   (1) Thanks Reply With Quote
Old 1st September 2015, 11:14   #103
Thanked: 246 Times
Thank you Aroy and a4anurag. I gave the car for my second free service and i told the SM about these issues. He got them fixed. He didnt have a clear answer as to why they became loose. Said its possible due to bad roads. Anyways, got the car back today: runs smooth now. Will wait a little longer before i can wholeheartedly say that everything is fine.
Thanks once again
Old 7th October 2015, 15:32   #104
Thanked: 26,773 Times
Default Maruti Suzuki launches Alto K10 Urbano limited edition
Maruti Suzuki has launched a limited edition version of the Alto K10 hatchback in India. Dubbed the Alto K10 Urbano, it comes with cosmetic changes and additional features. It will be available on the LX, LXi, VXi and VXi (O) trim levels, including CNG.
Maruti Alto K10 : Official Review-urbano1.jpg
Maruti Alto K10 : Official Review-urbano3.jpg
The exteriors of the car get chrome inserts at various places including the fog lamp housings, ORVMs, wheel arches, tail lights and hatch. Additionally, there are decals on the sides of the car.
Maruti Alto K10 : Official Review-urbano2.jpg
Maruti Alto K10 : Official Review-urbano4.jpg
Maruti Alto K10 : Official Review-urbano5.jpg
On the inside, the Urbano is equipped with art leather seat covers, a matching steering wheel cover, floor mats and stylish pedals, ambient light and LED door sills.
Maruti Alto K10 : Official Review-urbano6.jpg
The Urbano is equipped with features such as reverse parking sensors, hands free Bluetooth kit, USB car charger with voltage and temperature display.
Maruti Alto K10 : Official Review-urbano7.jpg
The Alto K10 Urbano Limited Edition also comes with a 90% funding on MGA package.
The Urbano edition is priced Rs. 16,990/- higher than the regular Alto K10.
Aditya is online now   (7) Thanks Reply With Quote
Old 7th October 2015, 15:41   #105
Thanked: 1,239 Times
Default Re: Maruti Suzuki launches Alto K10 Urbano limited edition
The company seems to be gearing up for the festive season with limited editions across the product line
- Ciaz (new SHVS)
- S-Cross (Discounts)
- Swift (Glory)
- WagonR (Avance)
- Alto 800 (Onam & Urbano)
and may be others will follow...
i74js is online now   (1) Thanks Reply With Quote
2010 Maruti Alto K10 : Review theMAG Test-Drives & Initial Ownership Reports 884 5th July 2016 19:10
Maruti Suzuki Alto K10 LXi - One year Ownership experience sanjeevskartha Long-Term Ownership Reviews 19 13th April 2016 20:36
Alto K10 vs Alto 800 vs Hyundai Eon Added_flavor Hatchbacks 176 26th August 2015 10:34
The Maruti Suzuki Alto K10 - Big smiles for a few dimes hothatchaway Test-Drives & Initial Ownership Reports 32 16th September 2012 19:01
Maruti Alto K10 - Technical Specifications & Feature List Stratos Technical Stuff 4 24th June 2011 13:08
