Old 1st April 2016, 07:00   #3841
shankar.balan's Avatar
Thanked: 5,331 Times
Default Re: Maruti S-Cross : Official Review
With the price drop, the S Cross is a compelling proposition.
Wonder whether the advent of the Brezza will make an appreciable dent in the Creta.
Old 1st April 2016, 07:48   #3842
Originally Posted by sandygordon View Post
Considering Cochin roads, even the 1.3 would be over-powered. More over overtaking at slow speeds requires calculation and downshift on our roads, be it 1.6 or the 1.3. I miss the 1.6 on short stretches of some highways while dragging bigger cars.
Yes sir. You are true. Daily commutation of mine is being carried out in thick traffic and thin roads.
krish_kochi is offline   Reply With Quote
Old 1st April 2016, 09:20   #3843
Dr.Naren's Avatar
Thanked: 6,298 Times
If your drive is mainly in traffic, you are right buddy. 1.3 is the engine to go for. I had taken test drive of both 1.3 and 1.6 back to back in calicut. 1.3 was way better in city with reduced turbo lag, light clutch and slick shifts. I found the gearshifts little notchy and clutch heavier in 1.6 compared to 1.3. But 1.6 makes you smile every time you cross 2500 rpm
Dr.Naren is offline   Reply With Quote
Old 1st April 2016, 13:09   #3844
Pro-Idiot's Avatar
Thanked: 31 Times
Originally Posted by Pro-Idiot View Post
Mod note: Post edited. Adjusting paragraph spacing for readability. Thanks.
One important note to those looking at the variants on offer: The Alpha has Bosch speakers and has excellent sound, but I recently heard the speakers on a Delta, and was surprised that it didn't sound the same at all . They have Nippon speakers in the lower version, don't know about the Zeta.
Here are the OEM 'premium' speakers (woofers and tweeters). No crossover. You will have to use the 'premium crossover' instead.
Paper cones
Poor output for the stock HU as well, audiophiles should opt for an HU upgrade.
Originally Posted by TheGoodest View Post
2. The audio playback from the USB thumb drive isn't very good. The vocals are not very clear and it seems like they are drowned. The EQ settings don't help either. During test drives, I tried playing music from my friend's iPhone using AUX and the quality was great. Is the audio hardware on the infotainment system inherently poor?
I had issues with the usb port and I also couldn't get the aux to work.But after some more detailed analysis, found the usb port to be fine. And just today went to the car and found the setting to make the Aux port active.
But I do believe that the sound quality is not good on the lower variants only because the speakers are not good. The speakers on the alpha "are" different!
I am sure the test drive vehicle was an alpha, also if you look at the boot of the test drive vehicle carefully, you might see the amplifier that some dealers have had put in, the one that they try and sell you as an accessory
I had found this unacceptable when I was looking at the variants and could not believe that companies do that. But I guess they do.
All this aside, if you car hear the audio quality being acceptable when using an aux cable, then it does not have to do with either the speakers nor with the hardware.
There are only two things possible, one, the audio recording is not high quality in itself or the cable used is faulty.
Transfer the same track which sounds fine on the aux to the usb device you are using and check if it sounds different.
Pro-Idiot is offline   Reply With Quote
Old 1st April 2016, 13:27   #3845
govigov's Avatar
Thanked: 450 Times
@Pro-Idiot - How do you identify if the speakers are Bosch / Nippon apart from tearing apart the door frame?
They do mention that alpha and zeta gets 6 speakers (4+2) whereas delta and below gets only 4 speakers. This is mentioned in their brochure. So, does that mean the 4+2 variants get the better speakers? Or is it the addition of the tweeter that brings the sound quality.
Along the same lines, can some one try and get a picture of the back of the headunit? Is there a sub out / video-out present in there?
govigov is offline   Reply With Quote
Old 1st April 2016, 14:09   #3846
ajay_satpute's Avatar
Thanked: 1,358 Times
I disagree to this particular comment. I had test drove and heard music systems in three variants, 1.3 Zeta, 1.3 Alpha and 1.6 Alpha. I played the same song from the same source on all and it sounded exactly the same.
ajay_satpute is offline   Reply With Quote
Old 1st April 2016, 14:18   #3847
Just got my Bosch infotainment system on the S-cross upgraded to version 740, it has Apple Carplay support.
Reached out to Varun motors near my office and it took the technician 15 mins to upgrade the software from Ver 720 to Ver 740.
Loving it, the only issue i saw was Apple Maps logo was not available in the Carplay menu options.
Atalp is offline   (1) Thanks Reply With Quote
Old 1st April 2016, 14:22   #3848
Thanked: 215 Times
I can confirm that the speakers in Zeta 1.6 are made by Nippon. By looks, they are not of very good quality.
I got them changed to Hertz.
prasanna_indaje is offline   Reply With Quote
Old 1st April 2016, 16:34   #3849
Thanked: 105 Times
Can you please share the pics of upgrade if you have. I own 1.6 delta and somehow not too happy with the sound quality. Thinking of an ICE upgrade, starting with speakers.
Can you also share how much poorer you are?
Girish
girishv is offline   Reply With Quote
Old 1st April 2016, 17:03   #3850
Thanked: 215 Times
Girish
I do not have pics of the upgrade. Went for Hertz DCX -170 on all doors and added a 140 W active subwoofer.
Got this done at Nexa and I became poorer by 19k.
prasanna_indaje is offline   (1) Thanks Reply With Quote
Old 1st April 2016, 17:22   #3851
Thanked: 105 Times
Are all these speakers driven by the HU only. Wondering whether they work fine with my non touch screen player.
Thanks for the info.
Old 1st April 2016, 17:36   #3852
Thanked: 215 Times
Yes. They are driven by HU. The subwoofer has an inbuilt amplifier.
They should work fine with your HU.
Old 1st April 2016, 18:07   #3853
abhishek46's Avatar
Thanked: 1,978 Times
It looks like delta and Zeta variants are now stopped by Maruti.
http://overdrive.in/news/maruti-disc...ants-in-india/
I am seriously speechless now. RIP S-Cross 1.6.
abhishek46 is offline   (1) Thanks Reply With Quote
Old 1st April 2016, 18:16   #3854
IMHO, it is a logical step by Maruti. If you are going for the 1.6 S-Cross, then you are already spending at least a lakh and half more than the 1.3. So it becomes sensible to go for the fully loaded Alpha, rather than the lower variants. Also, the Zeta variant of 1.6 loses a lot of feature compared to the Zeta variant of 1.3.
Old 1st April 2016, 18:25   #3855
abhishek46's Avatar
I would not think that is a logical step. The price point (around 10.8 ex showroom) at which the delta trim 1.6 was available made a compelling case of itself due to the sheer performance it offered at the price.
The delta and zeta trims are not poorly loaded by any means.
For people who want the 1.6 engine alone and do not need so many features (which include some very ugly alloys), these variants could have suited them fine.
abhishek46 is offline   (2) Thanks Reply With Quote
The Maruti S-Cross. (Details released: Page 38) .anshuman The Indian Car Scene 1220 25th July 2015 11:33
Fiat Avventura vs VW Cross Polo vs Toyota Etios Cross vs Ford EcoSport a4anurag Hatchbacks 14 16th July 2015 10:22
CUV Wars: EcoSport vs Avventura vs Cross Polo vs Liva Cross vs Premier Rio devarshi84 What Car? 19 4th December 2014 03:25
