Old 2nd April 2017, 19:26   #7096
Sree73's Avatar
Thanked: 748 Times
Originally Posted by Dr.Naren View Post
No warning on MID. But, if you lock the car using remote with bonnet not fully closed : you will get 3 chirps instead of 1.
OK. So, there is a potential risk. If someone opened the bonnet, did not close it properly and then immediately start the car and drive off, the car will be running with an unlocked bonnet lid.
The lid will not get open up while driving because there is a safety latch which we have to release manually to open the lid up.
Sree73 is offline   Reply With Quote
Old 2nd April 2017, 20:05   #7097
Dr.Naren's Avatar
Thanked: 6,807 Times
Default Re: Maruti S-Cross : Official Review
As you said, the lid won't open on it's own while driving. The potential risk is anybody else could open the bonnet. And yes, that is the reason for 3 chirps when you lock the car
Dr.Naren is offline   (1) Thanks Reply With Quote
Old 2nd April 2017, 23:16   #7098
kpzen's Avatar
Thanked: 1,617 Times
S-cross-ing the Jungle !!
Maruti S-Cross : Official Review-img_0956.jpg
kpzen is offline   (16) Thanks Reply With Quote
Old 2nd April 2017, 23:49   #7099
Dr.Naren's Avatar
Lovely pic
I am waiting for you to write down ownership review of your Code 6 tuned 1.6 S-Cross . As per the videos I had come across in what's app, the acceleration of Code 6 S-Cross is better than mine with TOT remap.
Dr.Naren is offline   Reply With Quote
Old 2nd April 2017, 23:53   #7100
Vigkey's Avatar
Thanked: 1,160 Times
BTW, I purchased a parts manual(latest edition) for a friend, and it looks like Maruti has localised the 1.6L engine and associated parts(transmission is still imported).
Facts which substantiate my claim are:
1. Engine number of 1.6 DDIS is MGP
Attachment 1625197
2. Earlier, air filters were imported from Romania(SGP), whereas the current part manual shows MGP number.
Older air filter(notice the missing M, which means SGP)
Newer air filter part number
Guys, what do you think?? Has Maruti finally answered our prayers??
Shashi
As Naren has already pointed out, Not quite Shashi
This is a simple data entry issue where they have maintained 2 part numbers for the same part. The pricing is also same for the duplicate parts. I can say this for sure based on my experience while my car was going through the repair. The initial estimate / quotation given by Bimal Maruti would have the part numbers with M in between (MGP), while the actual invoice will have part numbers without M in between (SGP). As you have pointed out, the parts manual has part numbers with M - and while making the quotation, they use part numbers from the manual and hence estimate has M. While actual invoicing is done, the scan the bar code on the pack which will not have M in the part number. Now, since both part numbers are maintained in the system, there is no error and since the pricing is also the same, there is no discrepancy. Hope this helps clear the confusion.
Does S-Cross give any indication in MID if the car is driven with the bonnet lid not closed properly. I just drove the car inside the parking place with the bonnet did not lock properly. I did not get any indication.
This is my understanding - The indication in MID is only for the centrally locked doors which includes the 4 doors and the hatch. Since bonnet is not included in central lock, the warning is not displayed in MID. So, as you said, it is very much possible to drive around with the bonnet open. However, unless in case of an accident, I do not see any chance of the heavy bonnet opening while driving. However, after parking, there is a high chance of someone opening the bonnet and stealing the battery. However, as Naren pointed out, if there is 3 chimes instead of 1, we can easily identify that the bonnet is open.
Vigkey is offline   (1) Thanks Reply With Quote
Old 3rd April 2017, 00:03   #7101
Dr.Naren's Avatar
Yes, it's a minor mistake by Maruti. All the engine related components are listed as MGP in parts catalogue now. Not to forget, even air filter is listed under engine parts category.
Also, Maruti has not imported any new batch of 1.6 engines since last 4 months. Looking at this team bhp thread, we will think that there are many guys getting 1.6 . But on roads, you won't find many. A Nexa dealer whom I know has sold 3-0-1-2 units of 1.6 S-Cross in last 4 months.
Old 3rd April 2017, 00:48   #7102
Thanked: 18 Times
Hello to all S Cross aficionados.
I thought I should share with you a small problem I faced with my car and the solution I found for the same. I hope it will help others facing the same issue.
Rapid deterioration of the Drivers Foot Mat.
Despite our cars having a double layered foot-mat, I noticed that my mat started fraying very rapidly, and within about 8 months, the upper mat had become threadbare, making the car interior look very old and tacky.
After some research, I found that the best solution is to use Artificial Rubber Anti Vibration Pads, typically used in the Air Conditioning industry. There is a soft rubber (light duty) pad of size 150 x 150 x 8 mm which is just perfect.
The old upper mat can be easily removed as it is just stitched on to the main mat, and leaves no marks or scars when removed. In its place, two AV Pads placed abreast and hand stitched by a skilled shoemaker were just what the doctor ordered!
I used a ribbed and edge banded pad, and used a cutter to create an edge notch for the stitch, which was very skillfully put in with a black thread, evenly spaced. Thus, on completion, I was proud of the interiors of my car again.
I hope others facing a similar problem will find this useful.
Hemanth Sharma is offline   (9) Thanks Reply With Quote
Old 3rd April 2017, 16:32   #7103
aargee's Avatar
Thanked: 2,126 Times
A list dominated by Japanese . Suzuki S Cross is rated 6th best in terms of disparity between claimed and Real MPG fuel economy in UK
Will strongly agree; for the first 1.5 days during the first 961 Km, the FE I got was 21.X Kmpl. Post the inspection/1st service, the FE has dropped to 16.2 Kmpl. Also my app shows overall FE of 14.4 Kmpl
I assume I'll have to reset the FE in MID for every long trip or after every full tank or every run & not keep the statistic to accumulate.
What is that most owners follow here?
Old 3rd April 2017, 16:39   #7104
sudeepg's Avatar
Thanked: 1,288 Times
Is the system getting updated to Android Auto as part of this?
Or just normal update to existing system to fix bugs / enhance performance?
Just a normal update to enhance bugs and fixes.
After 1859 Km, got the engine bay cleaned, but not up to satisfaction due to lack of time. But better than nothing.
Products used...
1. Sonus All purpose cleaner
2. Ultima Waterless wash
3. CarPro PERL
4. Meguiar's applicator
I wished you provided more details about this DIY as a separate thread. Would be very useful for others.
I just got my car serviced for 30,000 KMS Paid service. My experience was not so good. Details on my ownership thread.
Total cost: INR 8,726
sudeepg is offline   (1) Thanks Reply With Quote
Old 3rd April 2017, 16:59   #7105
aargee's Avatar
I've nothing more to do & might even be less than what's discussed in this thread -
http://www.team-bhp.com/forum/techni...ing-guide.html (A superb Car cleaning, polishing & detailing guide)
Check out the page mentioned in the above thread. That's the bible to begin with.
Old 3rd April 2017, 17:17   #7106
Dr.Naren's Avatar
S-Cross 1.6 : Stage 1 Remap + Decat Downpipe :
0-100 : ~8 seconds ( on speedo)
Dr.Naren is offline   (2) Thanks Reply With Quote
Old 3rd April 2017, 18:04   #7107
Mr.O's Avatar
Thanked: 53 Times
JK Elanzos at 26K
Maruti S-Cross : Official Review-20170403_173531__1491222562_116.68.123.175.jpg
Tires are wearing out a bit unevenly. Same for all 4 tires, though 4 tires are rotated at every 5K KM from MASS. We usually do all the alignment and balancing works outside of MASS but non of the alignment guys in my home town have the data for S-Cross.
Mr.O is offline   (5) Thanks Reply With Quote
Old 3rd April 2017, 18:07   #7108
sudeepg's Avatar
Originally Posted by Mr.O View Post
JK Elanzos at 26K
Attachment 1625937
This is Odd. I expected the JK's to last longer. I have Pirellis and have done 28K now and there is way more tread depth than what you have. Do you drive a lot in very bad roads? My car is primarily driven in city roads and highways
sudeepg is offline   Reply With Quote
Old 3rd April 2017, 18:33   #7109
Mr.O's Avatar
Thanked: 53 Times
We don't drive much through bad roads. 40% of our runs are though ghat roads. And our driving style is slightly on the aggressive side. But no burn outs though
Mr.O is offline   Reply With Quote
Old 3rd April 2017, 19:25   #7110
aargee's Avatar
Ghat roads? From MVPA via MC road towards Ettumanur/Kottayam? Ah!! Forgot the roads are under construction. Is that the reason?
PS - Next time I'm in MVPA, I'll catch up with you on my Brownie
aargee is offline   (1) Thanks Reply With Quote
The Maruti S-Cross. (Details released: Page 38) .anshuman The Indian Car Scene 1220 25th July 2015 11:33
Fiat Avventura vs VW Cross Polo vs Toyota Etios Cross vs Ford EcoSport a4anurag Hatchbacks 14 16th July 2015 10:22
CUV Wars: EcoSport vs Avventura vs Cross Polo vs Liva Cross vs Premier Rio devarshi84 What Car? 19 4th December 2014 03:25
