Old 8th January 2016, 17:28   #541
Thanked: 54 Times
Mod note: Back to back posts, use Multi Quote [Quote +] instead. Thanks.
Originally Posted by kiku007 View Post
Here's our 3rd Ford in 10+ years Ford Aspire 1.5L AT.
Replaced the stock wheels and rubber with Momo Revenge + Conti MC5.
Your new cars looks stunning.. Those new tires and alloys makes it even better! Congrats. Happy and safe driving.
Originally Posted by AKTRACK View Post
I have done 9700 kms so far in the car in since 6th September last year. Am I the first Aspire owner to reach that number?
I guess you are. Mine is still few km shy of 5000 though I got my Aspire mid-September, 2015. That is because I share my driving with a Punto
Last edited by Jaggu : 8th January 2016 at 17:40. Reason: Back to back posts, use Multi Quote [Quote +] instead. Thanks.
sudhirnam is offline   Reply With Quote
Old 8th January 2016, 18:15   #542
vnabhi's Avatar
Thanked: 1,246 Times
Default Re: Ford Aspire : Official Review
This is the same as Ecosport. I didn't see any difference. The brakes are over servoed and at slow speeds are difficult to modulate. Even a light tap on the pedal results in hard braking. It gets better as speeds build up and I haven't had any issues in more than 2 years. However I had the problem initially when I got into the Ecosport from my Corolla. First 2-3 times would be like brakes jammed. I got used to this now but whenever someone else drives my car, the first thing they do is jam the brakes as they are not used to them being over servoed.
This doesn't take more than a couple of kms to get used to but when they go back to their own car, they complain that their own cars brakes now don't feel as good.
Basically braking is not progressive at slow speeds and has an on/off characteristic.
Since you owned a Figo before, how do the brakes of the ES compare with those on the Figo? I'm asking because after getting the Figo in 2012, I found my Fiesta's brakes not grabby enough. They need more pressure at slow speeds to stop the car quicker, unlike the Figo, where a mere jab will instantly make the brakes bite.
I was thinking that the Fiesta's brakes were not on par, but on reading these posts, have ended up confused! Perhaps the Fiesta's brakes are normal, and the Figo's are over-servoed.
Old 8th January 2016, 20:22   #543
Vid6639's Avatar
Thanked: 20,034 Times
Yeah the Figo's brakes are better than the Fiesta (old/classic). They fixed this as a conscious effort in the Figo.
If I had to rate the 3, the Fiesta would be at the bottom being under assisted. The Figo is the best of the 3. It's not over servoed but exactly right. And finally the Ecosport which is over servoed and grabby.
The new Figo is similar to the Ecosport but I haven't driven it long to rank it. Will need some more kms.
Vid6639 is offline   (2) Thanks Reply With Quote
Old 8th January 2016, 23:38   #544
dragonov007's Avatar
Thanked: 109 Times
I feel opinions regarding brake-servo can vary from person to person and is rarely conclusive.
With my limited knowledge,I can imagine these 3 situations mentioned below-
1. The Brakes are weak and over-servoed- Manufacturers may resort to over-servoing of brakes to mask the underlying weak brakes in their cars.This gives the feel of a quick initial bite and a sense of pseudo-powerful brakes,but during sustained braking operations they will soon show fade and will not be able to help shed speed quickly.
2.The brakes are powerful and servoed just right or a wee bit over-servoed- The brakes will bite quickly and in a progressive manner and will help the driver slow down from high speeds within a short distance and without any drama.
3. The brakes are powerful but under-servoed- In this age of over-assistance of every mechanical function in the modern car,and light controls a top priority among customers,I feel no manufacturer will willingly engineer their mass market car brakes like this,because during short test-drives drivers will feel such a brake system to be somewhat spongy and requiring a larger effort to give the desired braking force, and will conclude that they are not-powerful enough.
I feel Aspire TDCi's brakes are more close to situation no.2.I haven't driven my Aspire TDCi extensively as some of our fellow BHPians. I can only say that as per my feelings, the brakes in my ABS equipped Aspire bite in quite a linear and progressive manner within the 100 kph ceiling(90kph is the highest I have ever taken her to, yet). I have always managed to stop her totally smoothly.Now when I move back to my Getz 1.3 petrol, its brakes feel much less servoed and somewhat spongy compared to the Aspire,while my Santro Xing's brakes feel quite grabby during the initial pedal input.So brake modulation,I feel,is a matter of getting used to as you drive a particular car.
About tyre squeals,I have this experience to share-
Since I drive in maddening Kolkata streets,I have had my share of panic braking,albeit at low speeds,a few times.Once I was coming down a flyover at around 50 kph and this guy traveling in a cycle in the opposite lane decided to swerve and cut to my side of the road.I spotted him early,braked hard and heard a tyre squeal briefly.But the car did not give a sudden jerk or lose composure, nor did the wheels lock up and slide(yes mine is an ABS equipped one) and I could steer the car safely to avoid him by a wide margin.
dragonov007 is offline   (2) Thanks Reply With Quote
Old 9th January 2016, 11:34   #545
VeyronSuperSprt's Avatar
Thanked: 1,659 Times
The Aspire needs modulation at speeds above 110 kmph and that's a very tricky situation. Modulation at slow to medium speeds in the Aspire is fairly easily managed.
VeyronSuperSprt is offline   Reply With Quote
Old 9th January 2016, 11:38   #546
McLaren Rulez's Avatar
Thanked: 509 Times
Is this a problem specific to the Aspire or does it also affect the new Figo? Seems to be a serious issue, yet one that is not hard to fix if Ford changes the brake booster.
McLaren Rulez is offline   Reply With Quote
Old 9th January 2016, 12:12   #547
Surprisingly enough, the problem isn't there in the new Figo.
VeyronSuperSprt is offline   (1) Thanks Reply With Quote
Old 9th January 2016, 14:00   #548
coolboy007's Avatar
Thanked: 1,440 Times
I have also noticed that Ford uses different brake modulation settings in its cars which are similar. I have a Ecosport and 2014 Fiesta, the Ecosport has a very sharp pedal bite like the new gen Hyundai's, it is indeed over servoed and i think it has been done to impress the masses which feel that the braking is excellent.
Fiesta on the other hand has none of this jerky brake modulation and the brakes bite very progressively, i love progressive braking and not this on/off switch type. You would not expect them to differ things on Fiesta/Ecosport but they did so it is not a surprise to me if Figo/Aspire are different.
coolboy007 is offline   Reply With Quote
Old 11th January 2016, 18:45   #549
SJN
Thanked: 37 Times
My 1.5P Titanium AT is going great and it's first service is due soon. Below is a list of minor issues experienced by me till now:
  • Rattling noise near rear door especially when taking turns
  • When steering is turned completely on one side for U-turn, I feel noticeable increase in steering vibration
  • The engine runs at 1000 rpm even at idle. Is that normal? (might be silly question but I am driving a car with tachometer for the first time )
  • Unable to download phone book from my Android cellphone
  • Unable to play songs using USB port (tried 2 pendrives but get USB error)
  • Is there a detailed manual available for audio unit e.g. I am still not able to make out what is the use of alphabets on audio unit keypad?
  • Seat belt reminder notification has stopped (might be related to seat cover installation)
I would appreciate if fellow Aspire owners can share their experience or advice so that I can take up the "real" issues during service centre visit.
SJN is offline   Reply With Quote
Old 11th January 2016, 21:48   #550
d3mon's Avatar
Thanked: 591 Times
Originally Posted by SJN View Post
My 1.5P Titanium AT is going great and it's first service is due soon. Below is a list of minor issues experienced by me till now: [list][*]Rattling noise near rear door especially when taking turns
I have a rattling noise from the passenger seat belt area, which I haven't had had time to get fixed yet. During first service, they greased the rubber beadings and the door latches and tried looking for the source of the sound, but could not isolate it.
If you do manage to get this noise fixed, please do let me know how they tackled this. Thanks!
d3mon is offline   (1) Thanks Reply With Quote
Old 12th January 2016, 15:07   #551
Thanked: 136 Times
You know what, even before I purchased my car I was ready for rattling issues and they did crop up. My car had rattling noises from the B pillars and the C pillars but were rectified during the first service. They did take a lot of time and drives though. Now the car is rattle free. Rattling noises just get to your nerves. It is hard to diagnose at times. I tried to diagnose it but could not. I don't know how they do it.
AKTRACK is offline   (2) Thanks Reply With Quote
Old 15th January 2016, 17:31   #552
Thanked: 326 Times
So! The reading says 1675.
Its been 17 days being with us. Yes, I'm talking about Ingot Silver 1.5D Titanium Aspire.
It all happened pretty quickly. Booked it on 16th, was at home on 30th. It was a nice experience with Sequel Ford. The buying experience was smooth.
Swapped the shoes immediately, MRF's were gone and in comes the 185/65 Yoko Earth 1's. I am not going to talk about the drive experience right away, since plagued with tyre pressure issue. I was assuming that the tyre is filled with Nitrogen, but it wasn't. And it ruined my 1K+ trip to Hyderabad.
Good points :
Fuel Efficiency: Its showing 20 right now. That includes city, highway, nearly non-existent roads. So I'm satisfied with it.
NVH: People at the back seat can't tell its a diesel.
Driver Seat height adjust: Has a healthy range. Took it to top most position while driving on highway, the experience was like driving a SUV.
Audio: The sound quality is quite good for a standard fitment.
Not so-good points:
Getting ideal seat position takes time. The recline on the front seats is a bit too much.
The refinement at idle is not to my liking. May be I'm used to MJD's , which are refined at idle. Also, it shudders quite a bit when you turn the key off.
Squeak from left C- pillar. Need to be rectified on first service.
I hope I can come with a detailed ownership report, but looking at quality of work of some fellow members, scares the hell out of me
Some pictures to share:
Ford Aspire : Official Review-img_20160104_061442.jpg
Ford Aspire : Official Review-img_20160106_2000411.jpg
Ford Aspire : Official Review-img_20160106_2003411.jpg
fz_rider is offline   (1) Thanks Reply With Quote
Old 16th January 2016, 13:14   #553
kiku007's Avatar
Thanked: 1,329 Times
Momo Revenge Anthracite finish
Continental MC5 - 195/55 R15
Some pics of the car. Hate the rear of these compact sedans. Nevertheless the car is a looker in most angles.
Ford Aspire : Official Review-dsc_0081_anne.jpg
Ford Aspire : Official Review-dsc_0080_anne.jpg
kiku007 is offline   (4) Thanks Reply With Quote
Old 20th January 2016, 10:42   #554
teemus's Avatar
Thanked: 499 Times
Originally Posted by samaspire View Post
Its Samarth / Sam
Sorry about that, I guess I am too much used to calling my friend Sameer as Sam!
So what's the update about your Aspire? Got it mended?
What was the quote for the repairs and how was the experience with insurance company?
teemus is offline   (1) Thanks Reply With Quote
Old 20th January 2016, 12:56   #555
Thanked: 54 Times
Those tires look great on your Aspire. Did this improve the handing of the car? I guess you feel more confident while cornering owing to better grips these tires offer.
Recently my car MID showed 'SERV ON' indicating a service reminder. The car was serviced at 2500 km and next is due only at 10 k or 12 months. I had it checked at Ford. It seemed to be a software error which they managed to solve after working for an hour or so. They gave a free wash for the car
Have any Aspire owners seen this error?
The Blue Oval comes home - Ford Figo Aspire TDCi Titanium KreativeGeek Test-Drives & Initial Ownership Reports 116 14th July 2017 15:59
My Ford Figo Aspire Titanium+ (Tuxedo Black) witwiky Test-Drives & Initial Ownership Reports 97 10th October 2015 01:18
Ford Figo-based compact sedan - The Aspire JayPrashanth The Indian Car Scene 1062 18th September 2015 18:53
