Old 29th August 2016, 17:01   #991
d3mon's Avatar
Thanked: 584 Times
Default Re: Ford Aspire : Official Review
Nice input! I dont think the gears are notchy at all but, it's a matter of depressing the clutch to full extent for gears to engage smoothly.
This car doesn't allow you to engage gears with half clutch mechanism
But, only place where I'm a bit unhappy is when I engage reverse and this is where it gets stuck most of the times. I mean have to focus to ensure it's engaged smoothly else it takes more than one time effort
Btw, do you have a picture of the area where the gear selector is located in the car and also of that 3M spray? I'm due for 3rd service in 800kms
Forget fully depressing the clutch pedal - even double clutching when shifting to first/second gears hadn't helped much - it used to feel like I was rowing through mud, and the lack of a positive feedback was a big annoyance. For me, it has been a night and day difference after this lubrication.
Earlier, my car's gearbox rated well below the standard set by the VW TDi gearbox (Still the best) and even below the Swift's positive shifting 'box. Now, it has just about caught up to the Suzuki's box!
The gear selector is located behind the flap circled in red. This region is located right behind the front left fog lamp. Sorry, I don't have a picture of the spray itself, but it was a generic 3M lubrication spray. Perhaps WD-40 will also do the trick.
Ford Aspire : Official Review-img_20160829_164615.jpg
d3mon is offline   (6) Thanks Reply With Quote
Old 29th August 2016, 17:43   #992
arunphilip's Avatar
Thanked: 4,745 Times
Thank you for the info and the pictures.
In all likelihood, the spray would be this 4-way lubricant from 3M: http://www.amazon.in/dp/B015OJJR8W
3M's range of lubricant sprays are listed here: http://solutions.3mindia.co.in/wps/p...ns/Lubricants/
I also want to point out that WD-40 will not be an equivalent substitute - while WD-40 will remove rust and moisture and loosen items, it does not have any lubricating properties. So if you use WD-40, you must follow it up with an actual lubricant.
arunphilip is offline   (3) Thanks Reply With Quote
Old 29th August 2016, 17:50   #993
d3mon's Avatar
Thanked: 584 Times
I think you have the right product there! Thanks for the clarification on WD-40. Didn't even know there are so many kinds of lubricants!
d3mon is offline   (1) Thanks Reply With Quote
Old 29th August 2016, 20:57   #994
samaspire's Avatar
Thanked: 2,314 Times
But, only place where I'm a bit unhappy is when I engage reverse and this is where it gets stuck most of the times. I mean have to focus to ensure it's engaged smoothly else it takes more than one time effort.
I have never had this problem till now, but it happened to me twice today.
Something to do with ageing?
I just crossed 6000 yesterday.
samaspire is offline   Reply With Quote
Old 29th August 2016, 21:51   #995
Thanked: 319 Times
.. Tip: I had them lubricate the gear selector with a 3M lubrication spray of some sort and it did wonders to the gear shifting action...
.. But, only place where I'm a bit unhappy is when I engage reverse and this is where it gets stuck most of the times. I mean have to focus to ensure it's engaged smoothly else it takes more than one time effort..
@d3mon: Thanks for the tip! Sounds really good. I went for the 30K KM service the day before your tip came, so I missed the bus this time around. Gear selector lubrication would be top priority during the next visit to the service centre
@mobike008: Couldn't agree with you more on the reverse gear thing. It's a real pain in the neck
espraveen is offline   Reply With Quote
Old 29th August 2016, 22:17   #996
aravind.anand's Avatar
Thanked: 1,818 Times
Come on, 6000 is not really 'ageing' this is an inherent nature of the iB5 transmission used by Ford I suppose, as none of the other forward gears exhibit this trait.
I don't think this is a lubrication issue, as even my Fiesta has it, and simplest work-around I have been using is to go back to neutral and firmly slot it to reverse again.
Over the years, I have the feel whenever the reverse is not fully engaged - the lesser lever movement indicates this, and in such instances, I don't release the clutch before firm-slotting to reverse.
aravind.anand is offline   (4) Thanks Reply With Quote
Old 29th August 2016, 22:31   #997
Thanked: 319 Times
Originally Posted by aravind.anand View Post
.. I don't think this is a lubrication issue, as even my Fiesta has it, and simplest work-around I have been using is to go back to neutral and firmly slot it to reverse again...
Yes! I have been doing what you've suggested here - > ''... the lesser lever movement indicates this, and in such instances, I don't release the clutch before firm-slotting to reverse'' and that sort of resolves the issue. But only after we get that moment of '' what the hell ''
And the lubrication stuff is for an improvement in the general forward gears slotting!!
Old 29th August 2016, 22:46   #998
d3mon's Avatar
Thanked: 584 Times
BTW you guys don't have to wait to go to the service center, if you don't want to.
The plastic flap that I posted about earlier isn't secured by any screws or anything - it just comes right off if you pull at it.
So if you have a can of lubricant (ahem) lying around, you could give this a shot as a DIY.
Look what I found! A guy is opening up this very panel and showing the gear selector working.
See from the 0:45 mark.
One thing I noticed in the video was that it has dust covers inside that panel for the individual cables, but in my car, there were none :|
Can someone confirm if they have it on their cars or not?
d3mon is offline   (5) Thanks Reply With Quote
Old 30th August 2016, 16:42   #999
mobike008's Avatar
Thanked: 8,036 Times
Come on, 6000 is not really 'ageing' this is an inherent nature of the iB5 transmission used by Ford I suppose, as none of the other forward gears exhibit this trait.I don't think this is a lubrication issue, as even my Fiesta has it, and simplest work-around I have been using is to go back to neutral and firmly slot it to reverse again.
Spot on Aravind
I have never had this problem till now, but it happened to me twice today. Something to do with ageing?
6000kms on a modern engine is like a baby transitioning to bottled milk..so imagine how much life is still there if that baby is supposed to lead an average life of 60 years. A stupid analogy but, I hope you got the drift
I had mentioned several times in my post about the reverse gear issue. Actually it's not an issue but, an irritant like the sound creeping in after 140kmph
Have outlined in this short report after my Kerala trip :
http://www.team-bhp.com/forum/test-d...ml#post3883406
mobike008 is offline   (2) Thanks Reply With Quote
Old 2nd September 2016, 06:43   #1000
Thanked: 135 Times
Ford domestic sales is 8548 units in August. Bifurcation is not available yet but I think it should be around 5k for the Ecosport and 1.5 - 1.7 k each for the Figo and Aspire.
AKTRACK is offline   (3) Thanks Reply With Quote
Old 7th September 2016, 09:54   #1001
Thanked: 102 Times
Arrow Re: Ford Aspire : Official Review
Received this pleasant email from Ford with subject line "Happy Anniversary to you and your Aspire"
Did anyone get this?! curious!!!
thanks enjoy TDCing!!!
Ford Aspire : Official Review-welcome2_kv.png
novicefreak is offline   (7) Thanks Reply With Quote
Old 7th September 2016, 16:35   #1002
mobike008's Avatar
Anyone renewed their Aspire insurance policy?
Can you share the following information?
IDV Value :
Premium Amount :
Insurer Name :
Benefits Covered:
Thanks in advance !!
Old 7th September 2016, 16:53   #1003
Thanked: 102 Times
IDV Value :
Premium Amount :
Insurer Name :
Benefits Covered:
You may refer my post #970 here few clicks!!
http://www.team-bhp.com/forum/offici...ml#post4040529 (Ford Aspire : Official Review)
Copy pasting same again for reference!
hi friends, just a small update from my end, its time to renew my Car Policy &
I opted for New India Assurance at a FNA(Friendly Neighborhood Adviser :-))
It is called " Private Car Enhancement Cover Policy" (simple terms: Nil Dep.)
IDV: 589856/-
Total Rs: 11249/-
enjoy TDCi-ng :-)
IDV Value : 589856/-
Premium Amount :11249/-
Insurer Name : New India Assurance
Benefits Covered: Nil Dep
Own Damage (OD)
Basic Third Party(TP) Cover: Compulsory PA cover for Owner Driver, PA cover for UnNamed Persons, LL cover for Paid Driver
Towing Charges covered is upto Rs1500 (May opt additional upto Rs 10,000 at slight premium ~300 Rs)
RSA is covered by Ford anyways!
enjoy TDCi-ng :-)
novicefreak is offline   (3) Thanks Reply With Quote
Old 7th September 2016, 17:21   #1004
mobike008's Avatar
Own Damage (OD)
Thanks! I'm due to renew by Sep 17th and I got 2 quotes and as you can see there is a significant difference in premium for both even though IDV is same
In the garb of additional cover they are charging exorbitant for 2nd option (Quote on right)
Is there a major difference to both quotes? Inputs please?
Vehicle FORD FIGO ASPIRE AT TIT P FORD FIGO ASPIRE AT TIT P
YOM 2,015 2,015
Expiring IDV 0
Renewal IDV 721,692 721,692
Tariff rate 3.283% 3.283%
Tariff Premium 23,693 23,693
Tarifff Discount 73.40% 73.40%
T-Rate Dis.Amt 17,391 17,391
OD Premium 6,302 6,302
NCB 20% 20%
Ncb Amount. 1,260 1,260
Nett OD Premium 5,042 5,042
Basic TP 2,237 2,237
PA to Owner Driver 100 100
Unnamed PA(60000) 0 0
LL to Paid Driver 50 50
Nett Premium 7,429 7,429
Service Tax (15%) 1,114 1,114
TOTAL 8,543 8,543
Bundle Add-on Rate 0.00% 1.21%
Road Side Assistance 0 375
Bundle Add-on Premium 0 8,732
Total Add on prmium 0 9,107
ST(15%) 0 1,366
Payable Addon Premium 0 10,474
Annual Payable premium 8,543 19,017
Add-on Coverages Depreciation Reimbursement
Consumable Expenses
Return to Invoice
Engine Protector
Key Cover
Old 7th September 2016, 22:08   #1005
d3mon's Avatar
Thanked: 584 Times
I don't know what TATA AIG is up to, but while I paid 12.5K for the first year (with zero dep, 65% NCB), they've sent me a quote for 13.5K for a renewal. Will have to dig into the details to figure out what they've done.
d3mon is offline   Reply With Quote
The Blue Oval comes home - Ford Figo Aspire TDCi Titanium KreativeGeek Test-Drives & Initial Ownership Reports 116 14th July 2017 15:59
My Ford Figo Aspire Titanium+ (Tuxedo Black) witwiky Test-Drives & Initial Ownership Reports 97 10th October 2015 01:18
Ford Figo-based compact sedan - The Aspire JayPrashanth The Indian Car Scene 1062 18th September 2015 18:53
