Old 6th April 2016, 16:07   #451
ACM
ACM's Avatar
Thanked: 2,892 Times
Default Re: Ford Endeavour : Official Review
Originally Posted by sknair View Post
Navigation is messed up, dealer would need to remove the MID system and send it to mount electronics in chennai to upgrade the system and will provide the map SD card, it could take a week to 10 days for this and would cost about 1.2 lakhs, totally worthless. use your smart phone google maps, would be better.
Yep the navigation is offered just for the sake of offering. I really don't see anyone going for this option.
Ford has goofed up on this aspect. SatNav is a basic option in a vehicle of this price range and should have been built in. Else it should allow for Google based navigation picking up from the Android or Apple Phone
ACM is offline   (1) Thanks Reply With Quote
Old 6th April 2016, 16:46   #452
Harshavarthan's Avatar
Thanked: 110 Times
Is anyone aware what sort of Bulbs have they used on Headlamps ? can we change with something like this ?
Also will it be possible to have some better sound setup - perhaps changing front speakers?
Even I was thinking about the same. If the stock speakers alone be replaced with a better ones which has good clarity without meddling the wiring. Any suggestions
Have also decided to change the stock bulb with Osram Night breaker unlimited once I get my truck this month end.
Harshavarthan is offline   Reply With Quote
Old 6th April 2016, 19:27   #453
sknair's Avatar
Thanked: 122 Times
I still don't see the March sales data being posted? did anyone see the post yet?
sknair is offline   Reply With Quote
Old 7th April 2016, 02:39   #454
ecosport rules's Avatar
Thanked: 1,351 Times
Originally Posted by Valhalla1979 View Post
Off road in the Palar river bed, the sand mode was very resilient and helpful. Basically what I found is that it engages the front wheels and changes gear at a higher number of RPM. In very fine and loose sand, diff lock helps, but not by much. In fact, I found that in very fine loose sand, the car has a lot of difficulty moving from a standstill. When you engage the 4x4 Low, it asks you to put it in rock mode. So, with a bit of fiddling about, I got it into 4x4 low on rock mode and was able to move.The MRF Wanderer tires were exceptional in this terrain and soaked up all the little bumps with ease.
Sand mode in terrain management system should have alone sufficed.Didnt it?
44 Low will not suit sand because of crawling speeds which are meant only for rock.
Also high speed with steering turn and the low ratio gear box engaged,will result in winding up of transmission, so to prevent this, the car keeps it in 1st gear only
Navigation system for the Endeavour has become a joke in the automotive market.
The other day we landed at Maruti to drive the Brezza.
The sales guy said "Sir, Brezza comes with complete navigation with maps, not like Ford where you spend 1 lakh"
Which varient of re Endeavour is yours?
If it has the projector with HID'S, you don't need to change the bulb.
ecosport rules is offline   Reply With Quote
Old 7th April 2016, 09:09   #455
Sheel's Avatar
Thanked: 5,647 Times
Appears it did not, hence it was required to put the off road selector in 4 Low mode.
Ok, I had a go in the 3.2 Trend for a TD, there are knobs to select 4L, won't going into sand mode & selecting 4L helped? I didn't try anything then.
And what is with Navigation? We have asked the dealer to flash navigation and it hasn't been denied yet. Let us see how things go.
Old 7th April 2016, 09:44   #456
ACM
ACM's Avatar
Forget Builtin Navigation for the ford Endeavour. Won't happen with just a flash. 1.2L is not worth it. The dealer team does not know what is required to be done.
Too expensive otherwise. Use Google Maps on Large Screen Phone and get voice through Integrated system.
Old 7th April 2016, 12:07   #457
Thanked: 110 Times
Mine is Titanium and I was saying about the high beam. I believe projector's are only for low beam and so can't change that.
Harshavarthan is offline   (1) Thanks Reply With Quote
Old 7th April 2016, 12:11   #458
htanna's Avatar
Thanked: 12 Times
Harshavarthan - I would suggest that you don't haste in. Drive the vehicle and then decide if you really need the upgrade. Like me, you may feel the urge to add more lamps instead of upgrading the existing ones. So hold off till you access it well against your needs.
htanna is offline   (1) Thanks Reply With Quote
Old 7th April 2016, 12:39   #459
Thanked: 4,143 Times
Have you added something or are thinking ? can you share your thoughts or setup done already.
Turbanator is offline   Reply With Quote
Old 7th April 2016, 12:50   #460
htanna's Avatar
Thanked: 12 Times
I will be taking the delivery tomorrow.
But I have couple of things in mind depending on whether I need to upgrade the stocks. When taking the test drive, I didn't feel like upgrading. But thats what I felt with my Cruze as well and once I started road trips, I felt the need to upgrade them, though it never materialised.
I am thinking of
1. Light bar
2. Nudge bar with more lamps on it.
Lets see. I will update with my findings and assessment.
htanna is offline   Reply With Quote
Old 7th April 2016, 14:48   #461
agbenny's Avatar
Thanked: 120 Times
I am thinking of
1. Light bar
I trust Ford may easily say a warranty breach as the Nudge bar may block ABS sensor. Make sure you don't void it by doing so.
The system doesn't seem to be recognizing any video formats either.
Last edited by noopster : 8th April 2016 at 08:38. Reason: Please don't post back-to-back: use "multi-quote" option instead
agbenny is offline   (1) Thanks Reply With Quote
Old 7th April 2016, 14:52   #462
htanna's Avatar
Thanked: 12 Times
It is listed in the official accessory list. So don't think they can consider it as violation of warranty. But will confirm with the dealer once again.
Old 7th April 2016, 14:59   #463
agbenny's Avatar
Thanked: 120 Times
ok..ok. I thought you are going for an after market one. I see the price is on the higher side, so dropped the idea of going for it.
Old 7th April 2016, 15:56   #464
Thanked: 73 Times
The official Ford nudge bar incorporates sensors - last I checked, so would work with the sensor system.
SuperFlyBoy is offline   Reply With Quote
Old 7th April 2016, 17:50   #465
sknair's Avatar
Thanked: 122 Times
They have a nudge bar with sensors, would require rewiring (front sensor wires would be connected to the nudge bar sensor wires), not worth it.
Preview: Ford Endeavour S2!!! Test-Drives & Initial Ownership Reports 849 16th February 2016 16:25
First official pics-2011 Ford ranger/ Endeavour sidindica The International Automotive Scene 9 28th May 2013 11:53
