Old 27th March 2014, 08:42   #1126
ampere's Avatar
Thanked: 7,648 Times
Default Re: Maruti Ritz : Test Drive & Review
This is I know so please correct me if I am not correct.
That is true. But the actual braking will still happen based on the status of pads right? Whether the action comes in early or its a late, depending on the pedal play should not be dependent on braking as such? (Again my thoughts. Will leave it to experts)
Old 27th March 2014, 08:45   #1127
a4anurag's Avatar
Thanked: 10,705 Times
AFAIK, both our views go hand-in-hand and IMO you are right. Brake pads in good condition + no air bubbles = best braking.
Anurag.
Old 27th March 2014, 09:18   #1128
Sheel's Avatar
Thanked: 4,006 Times
Brake pads wear out quite fast if used in rainy/dusty conditions. Water eats into brake pad's life. For me, it has stood true on Motorcycles.
Second being, braking efficiency won't suffer (drastically) because of brake pads being close to the Brake Wear Indicator. But if the brake pad is worn out, apart from reduced braking efficiency, it will play havoc with disc plate & destroy them.
To release air bubbles, I tie a cloth very tightly to the brake lever of my Motorcycle, the next morning, I have super sharp, progressive braking. Unsure about a Car though.
Last edited by n_aditya : 27th March 2014 at 13:46. Reason: acronym expanded to brake wear indicator
Old 27th March 2014, 09:29   #1129
CrAzY dRiVeR's Avatar
Thanked: 10,442 Times
Theoretically- no. Because the effort provided is utilised for two types of work- 1. To compress the air bubbles in the system. 2. Actual braking.
Old 27th March 2014, 09:34   #1130
a4anurag's Avatar
Theoretically - no. Because the effort provided is utilised for two types of work- 1. To compress the air bubbles in the system. 2. Actual braking.
You put it in a simpler and precise way. Thanks.
So to compensate for point 1 the driver needs to apply more pressure to get the 2 in action.
Anurag.
a4anurag is offline   (1) Thanks Reply With Quote
Old 27th March 2014, 13:02   #1131
Prodigy07's Avatar
Thanked: 164 Times
They are trying to fleece you.
How is the braking now? Spongy or sharp as new?
Anurag.
The braking is sharp. But they are not as sharp as the Hyundai's.
The service advisor says the reason for the wear and tear is due to alloy pattern. More number of spokes will lead to less wear and tear.
OT - I find the brakes better in the Ritz than my Ertiga Vxi (2200 kms till date)
Prodigy07 is offline   Reply With Quote
Old 27th March 2014, 17:03   #1132
Thanked: 8,265 Times
By bleeding the brakes, I think only brake play will reduce. However the braking won't change. That entirely should depend on the pads.
Yes it does. Though the braking efficiency won't get affected, it is the amount of pressure on pedal that will vary.
A Ritz Zdi that I drove (crazyfordriving) gave me immediate hint that the brakes were very spongy and lacked the bite. It surely was not normal even though the car had run less than 20,000 kms.
I instantly suggested brake fluid bleeding which even the manager at the workshop declined initially upon test driving the vehicle.
It was only later that the SA acknowledged the lack of bite and sponginess that bleeding was done and things were precise after that.
I have had a case with my WagonR itself where the life on pads show another 10k easily but It is lacking that efficiency. I have mostly (or always) got the pads changed much before its life span as I could easily feel the surface of the pads were harder than usual.
paragsachania is offline   Reply With Quote
Old 8th April 2014, 16:39   #1133
Prodigy07's Avatar
Thanked: 164 Times
This is the new issue that has cropped up in my Ritz VDi ABS since last Friday. As soon as I reach 60 km, there's a wierd loud 'Vroom' kind of sound coming from the rear. The sound is similar to a FFE. But this is really very irritating. I suspected the ICE wire to be the issue. But this sound comes even when the music system is switched off. Beyond 70 km the sound is just unbearable. Can someone clarify?
Old 9th April 2014, 10:34   #1134
a4anurag's Avatar
Is the wiring touching the body and getting short causing electrical interference? How did you wire the rear speakers from the HU? check that path for any abnormalities.
Hope this is not wheel bearing issue?!
Anurag.
Old 9th April 2014, 13:57   #1135
Prodigy07's Avatar
Thanked: 164 Times
Anurag.
Anurag, The issue is not with the ICE. I can confirm. Not sure if it's a wheel bearing issue. What else could be the problem?
Old 9th April 2014, 14:10   #1136
ank.nsit's Avatar
Thanked: 156 Times
AFAIK, the whistling sound at greater speeds indicate wheel bearing issue only.
ank.nsit is offline   Reply With Quote
Old 9th April 2014, 14:13   #1137
Prodigy07's Avatar
Thanked: 164 Times
Oh! How serious is this issue? Should I get it checked ASAP? Also, would like to know the cost of replacement and if this would be covered under warrantly. I have upsized the wheels. The car runs on 195/60 R15 Michelin Primacy LC tyres.
Old 9th April 2014, 14:33   #1138
swiftnfurious's Avatar
Thanked: 5,628 Times
This is the new issue that has cropped up in my Ritz VDi ABS since last Friday. As soon as I reach 60 km, there's a wierd loud 'Vroom' kind of sound coming from the rear... Beyond 70 km the sound is just unbearable. Can someone clarify?
Sounds like bearing issue itself.
It's serious and please get it changed immediately. I am told that if the bearing busts, it can lead to some serious damages to the car & wallet.
It's NOT covered under warranty and should cost around Rs. 800/- or so
Edit::
Please check this.
https://www.team-bhp.com/forum/long-...ml#post3023078
swiftnfurious is offline   (1) Thanks Reply With Quote
Old 9th April 2014, 15:09   #1139
a4anurag's Avatar
Please get the wheel bearing's changed ASAP!
Costs between Rs 700-800. I had replaced the wheel bearings in my Ritz at 60K service and this is NOT covered under warranty.
Anurag.
Old 9th April 2014, 16:31   #1140
  • Wheel bearing noise is more like a resonating grinding noise than a whistling sound
  • Wheel bearing noise is likely to increase or decrease proportionately with the vehicle speed
  • While going at a steady speeds, zig-zagging (*conditions apply and we all know that), will also change the tone of the noise at different turning angles
  • Let us say the bearing noise is prominent when driving at certain speed, you could shift to neutral and then see if the noise stays the same and decreases as you decelerate (It simply means the bearing noise from wheel has no connection with engine RPMs)
Maruti WagonR : Test Drive & Review Eddy Official New Car Reviews 658 21st February 2017 15:13
Maruti Swift : Test Drive & Review GTO Official New Car Reviews 2789 29th January 2017 22:50
