Old 19th May 2015, 14:10   #1381
a4anurag's Avatar
Thanked: 10,705 Times
Default Re: Maruti Ritz : Test Drive & Review
Originally Posted by etrast75 View Post
Have any ritz petrol zxi owners experienced issues with the clutch not being smooth? My ritz is about 2 years old and has run 10K kms.
Get the clutch opened and checked if the plates are fine or not. If not get the clutch plate and release bearings changed for a smoother operation.
Get the fluid re-filled to be sure there is no air entrapment. IF guys @ MASS have said all is well, take the car to an FNG and get things right.
a4anurag is online now   (2) Thanks Reply With Quote
Old 19th May 2015, 15:58   #1382
Thanked: 141 Times
Thanks..Ritz Petrol has a cable clutch AFAIK. No fluids I guess.. Lets see what the MASS guys say this time around. Since the vehicle is just out of warranty , they may make the xtra effort to diagnose the problem properly this time around.
etrast75 is offline   Reply With Quote
Old 19th May 2015, 18:43   #1383
a4anurag's Avatar
Thank you for correcting me on the clutch part.
Do get the clutch pedal play and if required do get the transmission oil changed if not done from long.
a4anurag is online now   Reply With Quote
Old 19th May 2015, 21:49   #1384
Thanked: 18 Times
How important is EGR cleaning with respect to ddis engine ? EGR cleaning have not been done on my 40k run Ritz vdi till now. Will it have an impact on the engine?
speedgun is offline   Reply With Quote
Old 19th May 2015, 22:55   #1385
a4anurag's Avatar
Needs cleaning if there is excessive smoking, low FE and sluggish performance.
I have clocked 46K kms I'm my Swift ZDi currently but haven't got the EGR cleaned. I didn't feel the need hence have avoided it this time.
Old 20th May 2015, 10:46   #1386
Thanked: 18 Times
Thanks Anuraj for clarification ,even I dont fell any sluggish in pickup or excessive smoke. So will hold on EGR cleaning for now.
Old 20th May 2015, 14:04   #1387
a4anurag's Avatar
If there is no drop in FE and performance, then you can safely postpone the cleaning of EGR.
MASS will try and push you to get it done but bluntly refuse.
Old 21st May 2015, 14:58   #1388
nijelj's Avatar
Thanked: 290 Times
Originally Posted by abhi3284 View Post
if i rev the Car hard, as in put the Pedal down quicker, i see lot of Black Smoke coming out from the exhaust.
Is this normal or some treatment needs to be done to fix this ?
My colleague who has a May 2014 Ritz Vdi has the same problem if he presses the accpedal down faster too. On enquiring at MASS, they said it was due to poor quality of Diesel that he is using, and that he should use Shell diesel. Willing to try it out, he filled diesel at Shell for another 6 months, with no improvement.
He had given for the 3rd service yesterday and the often repeated 'poor diesel' excuse came out. They even have two cans on display, one filled with normal diesel and another with shell diesel. He asked them to check out the entire air circuit for any oil traces. They called him in the evening yesterday, saying that they drained the diesel and saw that the diesel is of poor quality. They are claiming that they will fill 10trs of shell diesel in his car and prove it.
My friend is going to check for the same smoke in the test drive Ritz and also will keep an eye on the smoke from his car for 2 more days. Lets see how that turns out.
Another colleague who has the same complaint in his Ritz went up to the highest levels of Maruti management , with no success. Tired, he has now chosen to ignore the smoke screen that he leaves behind during an overtaking maneuver
nijelj is offline   (1) Thanks Reply With Quote
Old 21st May 2015, 17:25   #1389
Dieselritzer's Avatar
Thanked: 378 Times
Hi, I have a June 12' Ritz VDI @37XXX Kms. Recently, whenever going over even the smallest bumps a sound comes from the rear as if something is hitting a metal or plastic piece. First i thought something in the boot was moving around, but thats not the case. Will have to take it to MASS.
Also, i have stock bridgestones (Non Alloys). What should be the next upgrade? I would like to get better gripping tyres for some spirited driving.
Dieselritzer is offline   Reply With Quote
Old 21st May 2015, 18:00   #1390
saket77's Avatar
Thanked: 3,343 Times
Check the parcel tray. A parcel tray which is not held firmly will bounce when the car goes over bumps.
Coming to the tires, since you have already clocked 37K+ kms, they must be due for a change. For better grip, you need soft compound tires. The downside is that they wear-off quicker. Michelin is one name you can trust for the purpose. There are some good tires by Bridgestone too (not the OEM ones) which are softer and will offer better grip than your OEM tires.
Regards.
saket77 is offline   (1) Thanks Reply With Quote
Old 21st May 2015, 18:09   #1391
Thanked: 378 Times
Hi Saket, thank you for a quick reply. I will surely check out the life left in my tyres. Also, the parcel trey has been removed long back. As i said, i checked all the possibilities of any moving/removable parts creating that noise, but i could not. A visit to MASS should fix this.
Just an observation, the torque steer happens to my car a lot lately. If i try to get a fast start from stand still, my wheels tend to steer. Nothing alarming, but just an observation. Also after driving over the amazing roads in Mumbai, the car has developed a lot of rattles. Whomever came with the idea of putting paver blocks on the roads, may he find wisdom in life.
During a visit to Japan, there were roads with paver blocks but i was told that it had a layer of cement under it to avoid it from getting pressed in the ground due to traffic movement. They looked stunning. Here, its a mess and the rains are just around the corner.
Old 21st May 2015, 18:19   #1392
saket77's Avatar
So, it is a candidate of some physical check. Hope that it is nothing more than a lubrication issue. I am not familiar with the suspension system of the Ritz, but if it has a lateral rod, please check visibly if it is not bent.
Torque steer is probably common stuff for FWD vehicles due to inherent design and transverse layout of the engine and drive axle. However, front tires which have lost grip may also lead to it. Will suggest you to check the air pressure too for negating the possibility of over-inflation and unequal tire air pressures. Few other reasons may be incorrect alignment or brake drag on a particular front wheel.
Thanks for the information. Certainly looks good technique to tackle the problem.
Saket
Old 21st May 2015, 20:22   #1393
GrammarNazi's Avatar
Thanked: 1,491 Times
...Another thing i notice is that if i rev the Car hard, as in put the Pedal down quicker, i see lot of Black Smoke coming out from the exhaust.
Is this normal or some treatment needs to be done to fix this ?...
MOST probably (almost certainly) it could just be the unburnt diesel. As long as you feel the surge as the turbo revs, I guess its no big deal, it should be fine.
The ASC is making an invalid arguement, if the Diesel is bad, ask Maruti to make cars for the kind Diesel available in India.
Today its no big deal, but (god forbid) if the injectors get clogged or a major issue crops up tomorrow & the Maruti ASC faults the 'Diesel quality' and denies warranty, then what?
Its a completely invalid argument. If the Diesel is bad, then the impurities should be taken care of by the Diesel Filter.
Here too I'd guess its just unburnt diesel, when the accelerator is excessively depressed, black smoke due to unburnt fuel will come from even the most advanced diesel engines.
If still doubtful, ask him to get the car checked for leaks in the Turbo hose.
Else, all is fine.
(At most, maybe get the EGR cleaned. But as long as the surge in the turbo band is good, IMO leave it be.)
GrammarNazi is offline   (1) Thanks Reply With Quote
Old 21st May 2015, 21:42   #1394
a4anurag's Avatar
Let's see what could be the cause I'm the boot area, provided your boy is empty and has a spare wheel, tool kit, a jack and warning triangle.
I have my suspects on a loose jack place on the metal floor or tool kit rattling. There is a bracket that is provided for placing the jack in it. Hope it is tight in there!?
1) Michelin XM2 - Softer, grip levels are good ;
2) Yokohama Earth 1 - Made for India tyres with good grip and silent too.
3) Bridgestone AR20 - Another good tyre but slightly in the harder side.
I have my doubts on the ball joints OR lower an bushes. Get the bushes changed and drive shaft boots too checked. Any movement in suspension components, can allow the wheels to steer in one direction.
Someone steering components do give the Torque steer.
Also the tyre pressures should be correct in all wheels.
But before get the wheel balancing and rotation done. If there is the steer then get the suspension and steering components checked.
a4anurag is online now   (1) Thanks Reply With Quote
Old 22nd May 2015, 09:30   #1395
bhp_maniac's Avatar
Thanked: 57 Times
Hope the air filter has been checked. It's when the black smoke issue comes up, that I change my filter Normally around 10k intervals. Every time I go to MASS to change the filter, the routine answer comes up. "Sir, the filter looks good, no need to change" and I reply with "Ok, however please change it". It has sorted out my black smoke issue every time. After all its a matter of 250 Rs.
bhp_maniac is offline   (1) Thanks Reply With Quote
Maruti WagonR : Test Drive & Review Eddy Official New Car Reviews 657 20th February 2017 21:48
Maruti Swift : Test Drive & Review GTO Official New Car Reviews 2789 29th January 2017 22:50
