Old 4th April 2011, 23:55   #3301
SumitBahl's Avatar
Thanked: 219 Times
Default Re: Fiat Grande Punto : Test Drive & Review
Originally Posted by asdon View Post
Hi Sumit, have you installed Fog lamps too? and one more question, after installing the central locking does it work for 5 doors or 2 doors?
It works on all 4 doors. Boot does not need to locked separately, once you slam it, its locked!
Yes, I have installed fog lamps too. Cost: Rs. 2200-2400 with install.
SumitBahl is offline   Reply With Quote
Old 5th April 2011, 10:23   #3302
ms001's Avatar
Thanked: 63 Times
Is the fog lamp circuit independent of the ignition switch?
what kind of switch did you install for the fog lamps
ms001 is offline   Reply With Quote
Old 5th April 2011, 10:27   #3303
headers's Avatar
Thanked: 464 Times
The fog lamp in my FGP-Emotion Packs are via ignition switch. I switch off the ignition and all lights go out!
Old 5th April 2011, 10:30   #3304
ms001's Avatar
Thanked: 63 Times
yes because emotion has factory fitted fog lamps.
for active which does not come with factory fitted fog lamps its a different story altogether
Old 5th April 2011, 10:31   #3305
SumitBahl's Avatar
Thanked: 219 Times
Yup, its independent of ignition switch. One needs to turn off the fog lamps separately after switching off the engine. It a normal on/off switch tucked away on top of a chubby hole on right side of driver seat, right next to the ignition.
If anyone knows how to link it with the ignition switch, do let me know!!!
Old 5th April 2011, 10:35   #3306
headers's Avatar
Thanked: 464 Times
To link it with the ignition switch, check whether the switch is capable of taking the load. It is a simple job.
If the ratings are different from Active to EP, then just change the ig coil to the one that comes in EP.
Else your ig coil will burn out in no time!
Old 5th April 2011, 15:51   #3307
Thanked: 85 Times
when oh when will we get the Punto 1.4 T JET ? With a sports kit thrown in , it should still be in the manageable 7 lakh category. (ex Delhi)
JishD is offline   Reply With Quote
Old 6th April 2011, 16:30   #3308
asdon's Avatar
Thanked: 293 Times
Did you buy the fog lamps from Fiat Showroom? Here in Bangalore they are asking for 3500/-.
asdon is offline   Reply With Quote
Old 8th April 2011, 16:11   #3309
SumitBahl's Avatar
Thanked: 219 Times
Yup, from the dealership itself. Got them fitted before I took the delivery.
Came with all the necessary wiring, switch etc.
Old 10th April 2011, 08:42   #3310
raj_5004's Avatar
Thanked: 2,064 Times
I have a doubt -
Why cant we centrally lock the doors from the driver's door as soon as the car is started (and not moving)? the lever refuses to go in.
I am aware that the door autolocks above 20 kmph, but what if i want to lock the doors when the car is standstill. Amusingly, you can reach out to the passenger door & lock the doors when the car is standstill.
Old 10th April 2011, 09:41   #3311
Thanked: 245 Times
Has any 1.4 E Pack owner got the A/C kit replacement from Rama Motors, Okhla,New Delhi? The dealer claims that the kits havn't arrived yet. Same story for a long time.
coolkurt is offline   Reply With Quote
Old 10th April 2011, 17:32   #3312
binaiks's Avatar
Thanked: 838 Times
You can very well do that! I have done that many times - especially when I stop at signals and doors have not been locked. I guess its got something to do with your door latches itself.
binaiks is offline   Reply With Quote
Old 10th April 2011, 18:11   #3313
hemanth.anand's Avatar
Thanked: 7,000 Times
@Raj_5004,
Get it checked because I do it very frequently and it works.
hemanth.anand is offline   Reply With Quote
Old 10th April 2011, 19:31   #3314
raj_5004's Avatar
Originally Posted by hemanth.anand View Post
@Raj_5004,
Guys, are you sure it works when your car is standstill? Please try this-
1) Unlock your car using remote
2) Sit inside!!! (Start the car but dont move it)
3) Try locking the car using driver's door lever
It does work when the car is moving, even in my car.
Old 10th April 2011, 19:40   #3315
binaiks's Avatar
Thanked: 838 Times
Yes! It does work in my car. Please get your door lock checked.
Fiat Abarth Punto - Test Drive & Review nkrishnap Test-Drives & Initial Ownership Reports 231 10th January 2018 13:48
2014 Fiat Punto Evo - Test Drive & Review nkrishnap Test-Drives & Initial Ownership Reports 95 5th May 2016 15:07
Grande Punto Facelift: From baby Maserati to Punto Evo EDIT: Punto 'My Life' on pg.7 sushanthr77 The International Automotive Scene 167 25th November 2011 12:02
Fiat Grande Punto and the new Fiat Sedan; Tata-Fiat JV jkdas The Indian Car Scene 37 4th March 2009 17:01
