Old 2nd December 2011, 15:48   #4051
Thanked: 67 Times
Default Re: Fiat Grande Punto : Test Drive & Review
I just saw a new ad in the TV while watching One day match that Punto now start with just 3.63 lakh only. What diesel Punto active should start with given petrol Punto at 3.63 L ?
Linea start with Just 5.55 lakh.
jacksons is offline   Reply With Quote
Old 2nd December 2011, 22:34   #4052
Twiny's Avatar
Thanked: 47 Times
I got to read in the manual, in petrol/diesel engine starting procedure, just before cranking it is mentioned to press the clutch fully without touching accelerator. Why do you think need of a full press of clutch pedal?
Twiny is online now   Reply With Quote
Old 2nd December 2011, 23:01   #4053
Turbokick's Avatar
Thanked: 237 Times
Exactly what I marked. It was 3.87 lakhs for punto few days back. Further price cut ?
I guess the slow selling petrol fiats are getting the extra discount. Diesel should be atleast 1 lakh higher for equivalent models. 5 lakhs for active ?
Turbokick is offline   Reply With Quote
Old 3rd December 2011, 21:55   #4054
aditya116's Avatar
Thanked: 49 Times
Hi twiny,i dont think pressing clutch is absolutely necessary before starting(i may be wrong),saw it only in some maruti vehicles.
Another question to regulars- my engine has freed up after 10k and now hear a particularly nice whoosh after 2-2.5k on tacho.heard mainly with windows slightly down and think its quite sharp for people outside as often grabs their attention.have not noticed it on friends puntos or other MJDs.I know it must be turbo spooling/waste gate but does noisier one precludes any problem?
Also thanks to poor roads in kerela,my ride quality has come down slightly.also noticed slight jitteriness in handling while lane changing at good speeds.mentioned this to SA while on a trip to dealer for some other reason and he didnt agree to a service job for just check up of suspension.any pointers?
aditya116 is offline   Reply With Quote
Old 3rd December 2011, 22:31   #4055
nkg77's Avatar
Thanked: 141 Times
Sounds like there is some leak in the tubes to the turbo, that's why you are getting that sound. Book an appointment with TASS and get both your issues checked.
nkg77 is offline   Reply With Quote
Old 4th December 2011, 01:03   #4056
Thanked: 207 Times
Hardly there seems to be a connection with Starter motor or else, neither the Punto features a Clutch lock system(=Clutch should be depressed to crank the engine).
IMHO, Fiat is just specifying it as a Safety measure for accidental In-Gear cranking of the engine.
CRtorquefan is offline   Reply With Quote
Old 4th December 2011, 11:28   #4057
Thanked: 67 Times
Quite right, its only precautionary majors so, someone doesn't knock anything in front or back close to the car.
Old 4th December 2011, 11:54   #4058
raj_5004's Avatar
Thanked: 2,061 Times
Depressing the clutch has another important reason too, it makes it easier to start the car. Even when the vehicle is in neutral, the starter motor still has to crank the engine as well as the gearbox. However, if you depress the clutch while starting, the gearbox is detached & all the starter motor has to do is crank the engine. This reduces the load on the starter motor & thus wear on the components.
raj_5004 is offline   (7) Thanks Reply With Quote
Old 4th December 2011, 20:01   #4059
Thanked: 67 Times
Thanks Raj for this great information and now on I will try do that. Thanks again
Old 4th December 2011, 20:13   #4060
aditya116's Avatar
Thanked: 49 Times
Heres one useful feature i think not posted before.got this from a colleague when my fuel cap jammed and i had to pry it gently(ended up breaking the small plastic part which keeps it locked in place).
If your fuel tank lever refuses to open and offers resistance, just pop open the boot and on the inside behind to wheel arch is located this thread which directly unlocks the lever.
My colleague got this info from the dealer after facing similar problem.anyway had to spend 700 rupees (not to mention the waiting for a simple part which took 2 months) as they couldnt fix just the small plastic rod and had to change the entire fuel cap housing.they have made a poor job of fitting it and needs a precise slap from me to get it shut.such lackadasical attitude is only seen these TATA-FIAT dealers.
And one more thing,the OE graphics are available also in silver contrary to the red the have put up in the website.
aditya116 is offline   (2) Thanks Reply With Quote
Old 4th December 2011, 20:46   #4061
swiftnfurious's Avatar
Thanked: 6,571 Times
I heard depressing clutch fully while cranking also saves some amount of fuel in buses - might apply for cars as well. Since then I always make sure to crank while the clutch is fully pressed. Even if the saving is not much, let's all contribute to it.
swiftnfurious is offline   Reply With Quote
Old 4th December 2011, 21:42   #4062
raj_5004's Avatar
Post deleted. Please follow the rules from announcement section.
11. Team-BHP maintains a strong stand against drinking & driving, underage driving and street racing. Posts that don't abide by this view, or containing ANY alcohol content (in text or pictures, directly or indirectly), will not be entertained on the forum. This rule affects all posts from 1st Jan 2009 onwards.
raj_5004 is offline   (4) Thanks Reply With Quote
Old 8th December 2011, 19:15   #4063
gp_fanatico's Avatar
Thanked: 21 Times
Post Re: Fiat Grande Punto : Test Drive & Review
1. Any significant change in acceleration beyond 2K rpm? Increase in black smoke emission? Increase in NVH levels? These are few symptoms of Turbo problems. TASS can verify it by connecting the examiner.
2. Re-Check Tyre pressure and wear, wheel alignment and balancing.
gp_fanatico is offline   Reply With Quote
Old 8th December 2011, 22:05   #4064
Hormazd tweets that Evo upgrade has been indefinitely postponed! Looks like a bad move. So what do they plan to do in between to keep the brand alive?
Old 9th December 2011, 14:53   #4065
samsan02's Avatar
Thanked: 17 Times
Default Seat Height Adjuster Lever
Hi Anyone Replaced the Seat Height Adjuster Lever, It comes in the emotion pack variant. Mine broke when the Carnation folks messed it up while I had given them for a wash.
I just checked with service center the part is available but costs 3.5k, would it cost so much just for a lever.
Any inputs will be greatly appreciated.
Samsan02
samsan02 is offline   Reply With Quote
Fiat Abarth Punto - Test Drive & Review nkrishnap Test-Drives & Initial Ownership Reports 231 10th January 2018 13:48
2014 Fiat Punto Evo - Test Drive & Review nkrishnap Test-Drives & Initial Ownership Reports 95 5th May 2016 15:07
Grande Punto Facelift: From baby Maserati to Punto Evo EDIT: Punto 'My Life' on pg.7 sushanthr77 The International Automotive Scene 167 25th November 2011 12:02
Fiat Grande Punto and the new Fiat Sedan; Tata-Fiat JV jkdas The Indian Car Scene 37 4th March 2009 17:01
