Old 3rd February 2015, 16:11   #6496
Thanked: 46 Times
Default Re: Fiat Grande Punto : Test Drive & Review
I have a query regarding my 10 month old Fiat Punto 1.3 MJD Active!
I completed my 2nd free service (15K Kms) on 23/11/2014, and while checking out the manual a few days back, saw that the due date for next service (30K) is written as 24/4/2015 by the guys at FASS.
However, when I checked the service coupon, it mentions that the 3rd free service needs to be done at 30K Kms or 2 years from the date of purchase of the vehicle.
So, what should I go with? The due date given by the guys at FASS or wait for 30K kms before the next service?
Abh1nav is offline   Reply With Quote
Old 3rd February 2015, 16:39   #6497
Thanked: 979 Times
It's 30K or 2 years from the date of purchase, whichever is earlier. I guess 24/4/2015 is the date on which you will complete 1 year of ownership (given that your car is now 10 months old). You do not now need to service the car on that date unless you complete 30K by that time.
However, since you completed your 15K service on 23/11/2014, you may want to check with the A.S.S if your next scheduled service should be on or before 23/11/2015 (i.e., 1 year from the last service).
StarrySky is offline   (1) Thanks Reply With Quote
Old 19th February 2015, 10:22   #6498
sdp1975's Avatar
Thanked: 920 Times
Has FIAT stopped calling customers for feedback after service ? I don't remember receiving any calls in the last 2 years or so .
Even the ASCs don't call up these days asking for a good rating ! I remember previously they used to call after every service urging me to rate them for 9 or above with FIAT. Now they just call and enquire if the car is running fine.
sdp1975 is offline   Reply With Quote
Old 19th February 2015, 17:54   #6499
Thanked: 21 Times
Hi Guys, I came across this very helpful site 99rpm.com for FIAT spares. I know many people are already aware of this. I have one query regarding listing and component sharing between models. Since not all items are listed for all models can i use palio mjd filters for my Punto mjd?
saurabh041086 is offline   Reply With Quote
Old 16th March 2015, 08:06   #6500
Previous Gen. I have the 2008 model. I am quite sure that my car does 100 kmph @ 2200 rpms. From the new Swift's review by GTO, even it does 100 kmph @ around 2300 rpms.
Hi swiftnfurious,
Thanks. I have a swift petrol and it does 100 kmph at 2750 RPM in top gear. I hope this is normal and I also happened to drive my brother - in - laws hyundai verna 1.4 petrol which does 100 kmph at the same RPM in top gear.
Warm Regards,
Sajeesh
SAJEESH is offline   Reply With Quote
Old 16th March 2015, 12:35   #6501
sdp1975's Avatar
Thanked: 920 Times
What's the average life of brake rotors ? I went to change my pads today at Vecto motors and the SA told me to replace the rotors. Car is at 78K. Rotors are smooth, however they have worn off mildly - probably 1-2mm on each side from what I can visually see.
I ignored my SAs advise and only changed my pads. Googling shows that rotors should last a lot longer. Why spend 3K on replacing the rotors unless needed ? I find this unnecessary replacement really frustrating with FIAT.
Also, the new pads are a bit spongy and lack bite compared to my older , I guess some time is needed for them to 'bed in' ?
Old 16th March 2015, 13:39   #6502
Gannu_1's Avatar
Thanked: 9,905 Times
Have you considered resurfacing the rotors on a lathe? You can shave off a couple of mm leaving an even surface and the rotors can be reused for at least another 20-30 k km depending on your driving style.
An FNG might charge 1000-1500 Rs for resurfacing the rotors and the labour charges associated with the work.
Gannu_1 is offline   (1) Thanks Reply With Quote
Old 16th March 2015, 13:46   #6503
sdp1975's Avatar
Thanked: 920 Times
The wear-off is uniform throughout the entire surface of the rotor - I don't see any uneven wear. The entire surface has worn-off about 2mm from the edge of the rotor. So do I really need to replace or turn it on a lathe ? A uniform wear of 2mm+2mm = 4mm on both sides should leave enough thickness for the rotor to function properly.
I really don't have any problems - except that FASC asks me to change it everytime I visit them ! . They tell me that braking will be compromised and I find it hard to buy that argument.
Old 16th March 2015, 13:51   #6504
Gannu_1's Avatar
Well, most service centers do say that. The try to fleece uninformed customers this way.
If braking performance is unaffected or if you donít feel any juddering while braking, you donít have to replace or resurface the rotors.
Old 18th March 2015, 01:31   #6505
swiftnfurious's Avatar
Thanked: 6,470 Times
Off-Topic:
Originally Posted by SAJEESH View Post
....Thanks. I have a swift petrol and it does 100 kmph at 2750 RPM in top gear. I hope this is normal and I also happened to drive my brother - in - laws hyundai verna 1.4 petrol which does 100 kmph at the same RPM in top gear.
Do NOT worry! Petrol engines revv much higher (compared to diesel variants) for the same speed & gear combinations.
swiftnfurious is offline   Reply With Quote
Old 30th March 2015, 14:58   #6506
sdp1975's Avatar
Thanked: 920 Times
Thumbs up Re: Fiat Grande Punto : Test Drive & Review
Some good news for FIAT owners who don't want to visit the ASC .
99rpm website has started to sell FIAT spares again - all spares starting from oil,filters, brake pads , clutch are available.
sdp1975 is offline   (3) Thanks Reply With Quote
Old 31st March 2015, 20:56   #6507
Thanked: 53 Times
Any info about the current discounts available on the Emotion Pack 1.3 MJD ?
sreejith.j is offline   Reply With Quote
Old 9th April 2015, 19:27   #6508
sdp1975's Avatar
Thanked: 920 Times
I visited Harish @Pride cars for a clutch hardness problems and he asked to me to get the driveshaft oil seals ( 1 for left, another for right, total =2 ) along with the clutch kit .
I couldn't find this part on 99rpm for the Punto MJD although I can see oil seals for other cars like the Indica Petrol. Also , is it necessary to change the oil seals with the clutch kit - I don't think there's any observed leak. Any pointers will be appreciated
Old 9th April 2015, 19:44   #6509
Thanked: 13,387 Times
How old is the car and what does the odometer read now?
Changing the oil seals will ensure the car is reliable even though you aren't noticing any leakages. No harm in getting them changed. Those oil seals shouldn't cost you much IIRC.
a4anurag is offline   (1) Thanks Reply With Quote
Old 9th April 2015, 19:53   #6510
sdp1975's Avatar
Thanked: 920 Times
Car is 5.5 years old and the odo reading is at 79K. I'll enquire at FASC if they'll sell the seals OTC.
Fiat Abarth Punto - Test Drive & Review nkrishnap Test-Drives & Initial Ownership Reports 231 10th January 2018 13:48
2014 Fiat Punto Evo - Test Drive & Review nkrishnap Test-Drives & Initial Ownership Reports 95 5th May 2016 15:07
Grande Punto Facelift: From baby Maserati to Punto Evo EDIT: Punto 'My Life' on pg.7 sushanthr77 The International Automotive Scene 167 25th November 2011 12:02
Fiat Grande Punto and the new Fiat Sedan; Tata-Fiat JV jkdas The Indian Car Scene 37 4th March 2009 17:01
