Old 15th November 2010, 15:59   #1186
Thanked: 187 Times
Saw a Manza cab yesterday.
Has Manza made it to the yellow-board list in tata dealerships?
Tata Indigo Manza : Test Drive & Review-mz.jpg
WindRide is offline   Reply With Quote
Old 15th November 2010, 17:39   #1187
Thanked: 443 Times
Originally Posted by sidindica View Post
This rendering looks shockingly good for a manza CS. Tata, get this one and replace the dowdy 13 year old indica derived indigo CS.
Considering the long wheelbase of Manza (2520 MM), a Manza CS seems unlikely. Indigo CS wheelbase is only 2450 MM.
directinjection is offline   Reply With Quote
Old 15th November 2010, 23:16   #1188
Thanked: 2,217 Times
Merely cutting the tail will not make the Manza under 4m length. If they 'cut' it that much, it will become the original hatch version - the Vista. To make it a 'CS', they may need to cut the nose also
Tata need to use a 1.2L Petrol engine also to get the excise benefit, which will definitely downgrade the 'Manza' brand name. Can any one think of an SX4 'CS' version with a 1.2L engine?
So, please Tata, say tata to this idea.
romeomidhun is offline   Reply With Quote
Old 16th November 2010, 12:00   #1189
Thanked: 443 Times
Come to think of it, if they keep the wheelbase the same as that of Vista (2470 MM), Manza CS might just be possible. I believe the Manza uses a longer front bumper so that too could be replaced. Instead of a conventional three box, they could consider a notchback a la Accent Viva or Skoda Octavia if that helps in reducing length.
By the way, is there any news of Manza station wagon?
Old 17th November 2010, 02:16   #1190
Thanked: 146 Times
Default Tata to launch new Indigo Manza CS
Tata working on MANZA CS.
Link: Tata to launch new Indigo Manza CS | Rush Lane
Tata Motors planning a Indigo Manza CS? | Indian Autos blog
I do not think it is a very good idea. Instead they should comeup with nano based sedan under 4m.
airbender is offline   Reply With Quote
Old 18th November 2010, 15:33   #1191
Maverick79's Avatar
Thanked: 527 Times
OH! how disheartening. Manza too in taxi segment. Anyways, even in India, Corrolla's BMWs and Mercks are being used as taxis. So dont worry. Ofcourse their percentage is fractional.
Maverick79 is offline   Reply With Quote
Old 23rd November 2010, 11:41   #1192
Thanked: 175 Times
Originally Posted by drsnt View Post
check the earth connection from battery and clean it. it might be loose or dirty and causing malfunction...just my opinion but nothing harm in trying it
You were right drsnt. There was no problem with the cooling system of the car. There was a problem with the earth connection which fixed three problems in my car. Temp meter gauge was misbehaving, internal lights were flickering and RPM meter was misbehaving. As of now there are no issues. It took TASS 6 hours to fix this. I won't blame them for time as they were doing to work in very methodical way. For the help of other members in forum, let me explain what happened.
The temp meter in my Feb 2010 manza was going into the red zone. When I observed this for first time, assuming the car was overheating, I turned off the engine and opened the bonnet. It was all normal in there. Water/coolant full, no steam, engine temp seemed okay (to my hands of course), no smoke or smell. Then why was the needle in red? I cranked the car in idle while the bonnet was still open. The needle was still above the half mark and engine sound was fine but fan radiator did not start. At that temp, I expected the fan to start in high speed. I turned on the AC and both fans started. Went to office and parked the car. Next saturday went to TASS. Till then drove only with AC on.
They first connected the OBD tool to read the actual water temp. To our surprise, the water temp after some high revs was only 97-98 while the temp guage was going in red. At about 99 the fans also started and now the guage was at the end of red. So we knew that the engine is fine, the car actually never got heated, it was the guage acting up. It was a good releif for me! Now the temp meter could be going wrong either due to bad temp sensor or bad meter iself. They first changed the temp sensor but the problem remained, then also changed the meter, still the problem remained. Finally it turned out to be faulty earthing connection which caused this. I had also seen the internal car lights flickering which I reported to them. That also got fixed after fixing the earthing. RPM meter in the car used to fluctuate sometime, which has not happened for few days now. At the start up, the ABS light used to remain on for 10-15 secs earlier. I used to this that may be ECU takes time to ensure ABS system is fine. Also it used to go off after 10-15 secs so I did not bother earlier. After fixing the earthing, it goes off in 1-2 secs.
Sorry for technical info here but wanted to share the details so they can help others. I did not think one earthing issue could cause so much problem and make us feel that engine is overheating.
Cheers!
amit1234singla is offline   Reply With Quote
Old 25th November 2010, 15:54   #1193
The Manza sounds like a nice car from the review. Only thing is the image of the Indigo cars.
nutcracker is offline   Reply With Quote
Old 3rd December 2010, 18:27   #1194
selfdrive's Avatar
Thanked: 2,492 Times
there seems to be a new colour - 'skyline blue'. this wasnt available when i TDed last month. the SP was pushing for the colour 'grey nair' (her words not mine!)
has anyone seen the blue colour in person yet? it seems to be darker than the oyster blue of the SX4
selfdrive is offline   Reply With Quote
Old 3rd December 2010, 23:01   #1195
harry10's Avatar
Thanked: 617 Times
A problem-
Whenever i press the BT button to link my bb with the car bluetooth it shows on the system- the bluetooth link is busy and you may press escape to exit. Cant figure out the issue. Kindly help!
harry10 is offline   Reply With Quote
Old 7th December 2010, 17:02   #1196
Thanked: 63 Times
Originally Posted by harry10 View Post
A problem-
Dear harry10, I had also encountered this issue on several occasions, although not on BB but on a normal Nokia handset. It has nothing to do with type of phone instrument at all but i presume some linkage/connect issue between the handset & the BT. The only way i am able to sort this out is switch off the ignition completely, take out the key, come out of the BT setting on my handset, get into the BT mode again on the handset, then insert the key & start the ignition. The BT would now ask for a permission to connect or probably the pairing password. Then on it will get connected automatically. It's slightly long procedure, but it seems to work everytime & it's still better than going through the agony of having a full fledged BT system at your service not being able to utilise it.
Nagesh Bhatt is offline   Reply With Quote
Old 8th December 2010, 14:49   #1197
lloydofcochin's Avatar
Thanked: 180 Times
Default Re: Tata Indigo Manza : Test Drive & Review
Dear Manza Owners,
Does anyone know the cost of Oil change & Fuel filter for a 20k service?
Lloyd
lloydofcochin is offline   Reply With Quote
Old 8th December 2010, 15:32   #1198
Thanked: 63 Times
Originally Posted by lloydofcochin View Post
Dear Manza Owners,
Lloyd
Dear IIoydofcochin, i have had a 20k service done recently. Oil change required is appr 4.5 lit ( @ rs 1000/- a lit) + fuel filter & the total cost is around 5500/-, but i drive a saffire 90 ( petrol ) & hope for QJD cost should not differ by much.
Old 8th December 2010, 15:38   #1199
yogeshnaik's Avatar
Thanked: 41 Times
Dear Manza Owners,
Lloyd
Lloyd,
For Tata Manza Quadrajet, at 20K Km service, oil change, fuel filter, oil filter, Air filter, wheel balancing all will cost around Rs. 7500/-
Wheel alignment is done free. The oil used is synthetic, so it costs around Rs. 1000/- per litre.
Thanks to Ms. Deepa, Concorde Motors, Diary Circle, Bangalore for providing this information.
yogeshnaik is offline   Reply With Quote
Old 10th December 2010, 18:14   #1200
Thanked: 42 Times
During the third service I have changed the engine oil for my qudrajet by taking GTO's feedback on the forum. It took 3.2 litres of Mobile 1 0W-40. Oil costed me 3268Rs(including the VAT) and Oil filter was 329.41. Notably they also charged a labour amount of 189 Rs. The service was done at St.Antonys Kottayam . It was okay but nothing compared to the service experience I normally encounter with KHT Motors, Bangalore.
3.2 litres of Mobil 1 0W-40 costed me 32
sajanjohn is offline   Reply With Quote
