Old 13th March 2012, 09:42   #2476
volkman10's Avatar
Thanked: 19,900 Times
Default Re: Volkswagen Polo : Test Drive & Review
Originally Posted by Cruzerman View Post
Also, is there a gear shift indicator on MFD on 1.2 petrol highline? Please help..
This feature of gear / change indication is not available in any variants of the Polo.
Cheers!
volkman10 is offline   Reply With Quote
Old 13th March 2012, 10:53   #2477
Cruzerman's Avatar
Thanked: 34 Times
Cheers!
You mean petrol variants? I thought diesel highline had the gear shift indicator. Correct me if I'm wrong, diesel Polo owners, please..
Cruzerman is offline   Reply With Quote
Old 13th March 2012, 16:09   #2478
yogeshnaik's Avatar
Thanked: 41 Times
Originally Posted by dineshravindran View Post
There is a small doubt that I have though; once I turn on the ignition a couple of warning lights seem to be on all the time when I checked in the manual;
Fault in Alternator.
Fault in Catalytic convertor.
However, when I turn on the engine these two lights disappear.
Is there any problem with that?
You need not worry about these warning lights. These are ON in ignition mode, after the engine is cranked and becomes alive, these should turn OFF. If they still are ON, then you have a concern.
Good luck and happy miles ahead.
yogeshnaik is offline   Reply With Quote
Old 13th March 2012, 16:37   #2479
Thanked: 41 Times
I have the gear shift indicator in trend line diesel as well. TL diesel of mine has Gear Shift & gear indicator & DTE, where as in my brother's POLO petrol TL, instead of Gear Shift & gear indicator & DTE, it only has outside temp display.
One question for POLO owners: is it possible to get "Live Mileage" display in trendline Diesel? Has anyone done it? Thanks in advance.
nawalsingal is offline   Reply With Quote
Old 13th March 2012, 18:16   #2480
rareone's Avatar
Thanked: 11 Times
Cheers!
Gear / Change Indication is there in the Highline Varaint of Polo.
rareone is offline   Reply With Quote
Old 13th March 2012, 20:40   #2481
volkman10's Avatar
VW dealers have not acknowledged the presence of this feature. Any Polo 1.6 (2011) owners could confirm if this feature is there or not?
Cheers!
Old 13th March 2012, 22:21   #2482
brags's Avatar
Cheers!
This feature is not there in Polo 1.6, its there in the Diesel HL versions
brags is offline   Reply With Quote
Old 14th March 2012, 20:48   #2483
Cruzerman's Avatar
Thanked: 34 Times
Thank you, nawalsingal, rareone, volkman10, brags. So, from your posts, I understand all diesel variants have gear shift indicators on MFD and none of the petrol variants (including 1.6) have this feature present.
One more question to you guys. Is it possible to activate the remote opening & closing of windows on 2011 Petrol HL model? The VW Kochi dealer turned down my request to activate this feature.
Old 14th March 2012, 21:28   #2484
Ricci's Avatar
Thanked: 995 Times
I read about this activation of features on (maybe this or another thread ) and have to ask :
if it's merely an electronic transaction to enable or disable certain features already programmed into the car's ECU/computers , why aren't they enabled from the factory itself ? It doesn't make sense to have the customer find out what is available , then go back to dealer to enable it. Which brings me to the question - how did the first person find out about this ? Is it mentioned in the owner's manual ?
Ricci is offline   Reply With Quote
Old 14th March 2012, 22:33   #2485
Thanked: 364 Times
Nope. Unless the power windows have one touch up/down feature this isn't possible. Don't know about the latest polo's, but the 2011 models didn't have this.
Ricci - This is called convenience operation of power windows and its detailed in your ownership manual.
bala80 is offline   Reply With Quote
Old 15th March 2012, 07:49   #2486
volkman10's Avatar
Polo - IPL edition in the offing!
"Following the successful introduction of the Vento IPL Edition last year, the fifth season of the tournament, beginning next month, will see the launch of select variants of both the Polo and the Vento, Volkswagen said in a release. "
Volkswagen to launch IPL edition of Polo, Vento - The Economic Times
Old 15th March 2012, 08:01   #2487
DieselDon's Avatar
Thanked: 132 Times
Polo & Vento IPL Edition II
Also on TOI & Hindu in Hyderabad.
Volkswagen Polo : Test Drive & Review-1.jpg
DieselDon is offline   (1) Thanks Reply With Quote
Old 15th March 2012, 18:38   #2488
Thanked: 149 Times
Remote opening and closing feature is already there in Polo HL. When you unlock the car hold the button pressed and all windows will roll down. (Very useful in Hot summer as you can roll down the windows as you approach the car) Similarly, when you lock the car keep button pressed for a while and all windows will roll up and close.
This feature is there in my July 2010 Polo. I do not know if they have removed it now but quite unlikely as usually they add features and not remove it. e.g. new Polo HL has electrically operated ORVMS which our model does not have. May be soon they will also add Climate control.
They should add a feature - if the car is locked using remote all windows should roll up automatically.
CANPUSH is offline   Reply With Quote
Old 15th March 2012, 23:10   #2489
Thanked: 364 Times
That's exactly the problem, since they added the electrically operated ORVM's, they removed the one touch up/down function of the power windows. Now, driver doesnt even have controls for the rear power windows in the front arm-rest!
This feature was there is early 2010 polo's but removed in the 2011 variants along with the anti-pinch protection feature of the power windows as well. I guess they have re-introduced all these in the 2012 variants. VW is one manufacturer who is known for deletion of features without any notice, they did a similar thing with the vento too (removed leather wrapped steering, chrome inserts etc).
Old 17th March 2012, 07:16   #2490
Cruzerman's Avatar
Thanked: 34 Times
You are right, bala80. They have removed the one touch up/down feature and introduced electrical ORVMs. I guess the worst part is not having the rear power window controls at the driver side. That's really a pain in the neck!
The user manual has info about one touch up/down power windows and remote opening/closing of windows. But these things don't work on my Polo.
Volkswagen Vento : Test Drive & Review GTO Official New Car Reviews 9116 22nd July 2018 21:20
Volkswagen Jetta 1.6 Litre Petrol (Trendline) Test Drive, Review & Photos Karizma Fan Test-Drives & Initial Ownership Reports 40 18th February 2010 20:45
