Old 23rd December 2014, 10:39   #2461
nkrishnap's Avatar
Thanked: 4,163 Times
Default Re: Fiat Linea T-Jet : Test Drive & Review
Djay99 - You cant go wrong with the Tjet. The 1 lakh odd which you save can be used to fuel the Tjet for the pleasureable drives which the Tjet offers.
PM me if you need any help on the purchase of the car from Vecto.
The Goodyear Eagle NCT5 is pretty average, hard and pretty noise tyre.
nkrishnap is offline   (1) Thanks Reply With Quote
Old 25th December 2014, 15:25   #2462
khoj's Avatar
Thanked: 1,253 Times
I am facing a strange predictament. The temperature display for the airconditioner in our TJet is flashing for the past few days. The manual does not have anything on this and I have not been able to go to the service centre. Does any of you have any idea on this? Could it be an indicator of low battery or something completely different?
Old 26th December 2014, 09:54   #2463
Thanked: 198 Times
What a coincidence, my T-Jet has recently developed the same problem, though it has not affected the cooling or any other functions. I too plan to take it to the service centre sometime soon to get it sorted out alongwith a few other niggles.
........Could it be an indicator of low battery or something completely different?
I thought so as well and since my +4 year old battery was anyway due for a replacement, I got a new battery installed but the flashing display is still there!! Please do update this thread once you have this issue sorted out.
PGNarain is offline   (1) Thanks Reply With Quote
Old 26th December 2014, 10:17   #2464
Thanked: 11 Times
@khoj, do you have an obd tool? Will that be of any help in diagnosing this issue?
tarunactivity is offline   Reply With Quote
Old 26th December 2014, 10:32   #2465
nkapoor777's Avatar
Thanked: 88 Times
Could be due to the battery but to be sure, go to service and get the examiner hooked to clear error codes. Call Exide BatMobile service home to get the battery checked. Or try a jugaad if you want - disconnect negative terminal of the battery and put back after sometime. May resolve the issue.
You would need to hook up the examiner and get the error codes cleared. Pretty common issue since the dying battery would have resulted in some of these. Both my Fiats have exhibited this behavior in the few years I've owned them.
nkapoor777 is offline   (1) Thanks Reply With Quote
Old 26th December 2014, 17:03   #2466
khoj's Avatar
Sure, will do.
Nope do not have it but seems that would be the way to go per nkapoor's post.
On the battery front has anyone upgraded to the next size. IIRC the Tjet has a DIN40 battery. Am thinking of getting a DIN55 provided the alternator has enough juice to charge it, will check that out in the manual. Will also try and get Sukam's automotive battery this time, recently launched under the brand name 'automate' it boasts of AWT 'all weather technology'.
http://www.su-kam.com/power-solution...tive-batteries
Looks good on paper but availability is an issue. In case I can't find them, will get AC Delco.
Old 26th December 2014, 21:02   #2467
nkapoor777's Avatar
Thanked: 88 Times
I changed to Exide DIN55 in the Tjet some months ago. Works absolutely fine. Stock one is DIN50 by Exide. Two changes to expect if you put DIN55 in - first, the stopper in the battery tray will need to go since DIN55 is slightly larger than the stock one. Second, the battery cover won't fit :-). Don't worry about the alternator charging the bigger battery. Good luck finding the Sukam one. Looks good on paper though.
nkapoor777 is offline   Reply With Quote
Old 11th January 2015, 23:33   #2468
Thanked: 11 Times
I have just completed 500km on my TJet and am facing a loss of power and a jerkiness @ 2k rpm .
I was crawling in traffic in 2nd gear, and the engine stalled with an error message - "Insufficient Engine oil pressure" . This disappeared when I started the engine again .
I also felt a loss of power at 2k rpm and the whole car started to jerk . Pressing the accelerator did not make a difference and it felt like whole engine was stalling, even though it had sufficient accelerator input.
I had filled Shell regular for the second tankful, and had run ~100 km without issues.
Is this a sign of a failing turbo?
Old 12th January 2015, 10:00   #2469
Thanked: 11 Times
Fiat RSA said they need to tow the vehicle to the nearest service center. Apparently, they do not have a remote diagnosis setup to check on error codes before repair .
The first tow ride back to the workshop in less than 30 days ... :(
Old 12th January 2015, 11:14   #2470
deathwalkr's Avatar
Thanked: 495 Times
Oh man that is sad. Please keep us updated.
deathwalkr is online now   Reply With Quote
Old 13th January 2015, 15:58   #2471
djay99's Avatar
Thanked: 491 Times
Sad to hear this man. Hope you get back your car faster.
djay99 is offline   Reply With Quote
Old 13th January 2015, 19:18   #2472
Thanked: 11 Times
Latest news from Fiat service is that there were particles in the fuel ,which was causing the problem .
On checking further, they said that a tube/wire from the fuel pump was burnt and these particles were recirculated into the fuel system , probably causing this issue.
As of now, they are planning to replace the fuel pump / (filter?) , and I need to replace the fuel !
I'm waiting for the official statement ...
Old 14th January 2015, 18:21   #2473
khoj's Avatar
Battery replaced and examiner hooked up and codes cleared but the problem persists. Discussed with Mr. Sharma at Kashyap and per him all of the wiring running to the module needs to be checked and if there are no faults there then the module would need replacement.
Any ideas..?
Old 14th January 2015, 18:30   #2474
nkapoor777's Avatar
Thanked: 88 Times
Any ideas..?
That's a strange one. I am assuming everything is running fine wrt electricals et al. Why the heck would the module need to be replaced then? Get the wiring checked first. Also have a look at the audio wiring and installation bits (wiring, fuses, etc).
PS: which battery did you get? DIN55?
Old 15th January 2015, 00:29   #2475
khoj's Avatar
Starnge as it may sound, the unit stopped flashing this evening. Don't know how or why, it just did.
Got a DIN 44 Amaron Flo. For some reason none of the shops in Kalkaji & CR Park had a DIN 55 except one that had a Sonic (an Exide sub brand) but quoted an absurd price. Funnily enough the sticker on the Exide read 50Ah and the DIN44 is indeed smaller than what went out. Two Exide dealers confirmed(independent of each other) that 50Ah size is not available at all, as did the Kashyap Fiat's store keeper and the on line bhai. So now I have a 46Ah battery doing the job of a 50Ah. Will be happy if nothing flashes for the next 24 months.
My Terrestrial Fighter Jet : Fiat Linea T-Jet+. EDIT: 3 years, 4th Service completed KarthikK Long-Term Ownership Reviews 220 8th April 2015 00:19
Renaissance of my JET - White FIAT Linea T-Jet+ (27,000 Kms Up) Sathya_sc Test-Drives & Initial Ownership Reports 225 4th August 2014 20:29
Fuelled FIRE into my (T)JET - The Fiat Linea T-Jet bnzjon Test-Drives & Initial Ownership Reports 123 12th May 2013 00:16
