Old 9th September 2011, 14:20   #2851
DieselDon's Avatar
Thanked: 132 Times
Default Re: Volkswagen Vento : Test Drive & Review
Originally Posted by rock22 View Post
Hi All !
VW Dehradun SA has just confirmed that Vento with some added features would be available from the next month. The changes he confirmed are as follows.
1. Steering mounted audio controls.
2. A better ICE with Aux / Memory Card slot, but no bluetooth - the same unit used in old Jetta. But he wouldn't cofirm the USB port.
3. White backlit climate control and MID.
4. Some change in headlights and tail-lights.
5. Internal intruder surveillance system would be gone.
Update from Hyd :-
6. Rear Parking Sensors.
Sales guy confirmed on 1,2 & 5. Did not know on 3,4. No Cruise Control. . Should be available from next month.
DieselDon is offline   Reply With Quote
Old 9th September 2011, 15:15   #2852
D'Artagnan's Avatar
Thanked: 127 Times
Angry Re: Volkswagen Vento : Test Drive & Review
Hey guys, while taking delivery of the car I asked the dealer if I could change anything without voiding my warranty. He gave me a prompt reply 'NO', any change made to the car will void of its warranty. I was shocked & aghast to hear this. I wanted to change the horn to roots and put a powerful headlight bulb. The dealer said that I will need to install a relay and cutout for the bulbs which meant that the wiring would get complicated and this would void the vehicle off it warranty he even went forward to say that the Head Unit must also not be fitted outside as it will void the warranty !!
Is this for real or is the dealer playing tricks with me ?
I've two other vehicles an Innova and a Corolla. Toyota never told me that they would remove my warranty if I changed the bulbs and horn.
Shouldn't this be our personal choice I mean the horns and how they should sound should be our choice to change ?
D'Artagnan is offline   Reply With Quote
Old 9th September 2011, 16:18   #2853
Is the warrant void even if you get the work done by the dealer itself? or is it only void when work is done outside of a Volkswagen authorized dealer?
sbhasin is offline   Reply With Quote
Old 9th September 2011, 16:25   #2854
noopster's Avatar
Thanked: 9,597 Times
Let me make this simple: A warranty is void when the dealership says it's void.
Technically any change that does not meet with the manufacturer's original spec is a warranty-buster. e.g. I can change the 185/60 R15 OE tyres to another brand of same-spec tyres without voiding it but the moment I go 195/60 or 205/55, for example, poof goes my warranty!
Modifying horns and headlamps surely will void the warranty. I even held back from changing my ICE despite my accessories guy assuring me no wires would be cut. It's a new car, and I want my 2 years to pass uneventfully (inshallah) before I start playing around with stuff.
noopster is offline   Reply With Quote
Old 9th September 2011, 16:30   #2855
TopSpeeder's Avatar
Thanked: 216 Times
Originally Posted by captain_slow View Post
...... he even went forward to say that the Head Unit must also not be fitted outside as it will void the warranty !!
@Captain_Slow: If you have just got your car, Congrats for that.
They told me the same, when I drive the car I never felt the need for changing either of this. Headlight and Horns are good.
My suggestion is you can drive for some kms and decide later instead of changing in day one.
TopSpeeder is offline   Reply With Quote
Old 9th September 2011, 17:28   #2856
Thanked: 186 Times
Update from Volkswagen Downtown, Bangalore. They have received the information on the changes
1. Steering mounted controls
2. ICE will support USB and Aux
3. Reverse parking sensors
He was not aware of other changes. And expects new pricing to be updated next week.
prabhuferrari is offline   (1) Thanks Reply With Quote
Old 9th September 2011, 17:40   #2857
el lobo 6061's Avatar
Thanked: 1,015 Times
I wanted to change the horn to roots and put a powerful headlight bulb. The dealer said that I will need to install a relay and cutout for the bulbs which meant that the wiring would get complicated and this would void the vehicle off it warranty .
I have had my VW Vento TDi HL bulbs changed over to 90/100 Philips and had PMP relays installed. The dealer knows about it and has said nothing about warranty void. The bulbs of the Vento should be changed as soon as possible as the one that comes with it are of no good.
The horn of Vento is the best why would you like to change it?
el lobo 6061 is offline   (1) Thanks Reply With Quote
Old 9th September 2011, 17:46   #2858
Thanked: 364 Times
Technically warranty will be void if the original specs are tampered with, but then it all depends on the relationship that you build with your service advisor in the workshop. The electrical warranty will be void, if you upgrade your bulbs, music system and suspension warranty will be void if you upgrade your tyres and so on.
Having said that, if any changes that you are making to your car are reversible (eg-as long as the wires aren't cut), you can still cover parts in warranty if need be. There are enough means and ways to do it.
When I took delivery of my car, I was told to ensure no original wires are tampered with. my warranty would be intact, period.
bala80 is offline   (3) Thanks Reply With Quote
Old 9th September 2011, 19:22   #2859
coolkid's Avatar
Thanked: 56 Times
Originally Posted by Rachit.K.Dogra View Post
Hi Guys,
I have received the new Quotation from the dealer.
Ex Showroom: 9:82 (Earlier it was 9:48)
So the difference comes out to be 34K.
Also, If you intend to buy the car without this increase you can only buy from the lot that the dealer has. Deliveries are expected to start next month for this changed one. There is 3K increase in the insurance also.
The colour I want is nowhere in stock in complete NCR as well as CHD. I guess I will have to just get the new One.
What happens to the people who have already booked the car? The rate at the time of booking applies at the time of delivery as well, right? My car is due in March next year (yes, I was given an eight month waiting period) Do I have to pay the revised tax alone or would the new ex.showroom price be applicable to me?
coolkid is offline   Reply With Quote
Old 9th September 2011, 21:36   #2860
khoj's Avatar
Thanked: 1,258 Times
The total price applicable at the time of delivery is the one that has to be paid. This will include all of the price rises and tax increases in-between the booking and delivery dates.
Old 9th September 2011, 22:33   #2861
D'Artagnan's Avatar
Thanked: 127 Times
No he was very specific about getting the job done by the company only
I do feel its a bit cruel to control the buyers without offering them to make small modifications. The lights throw just isn't good enough, low beam is adequate but high has poor visibility. :Frustrati I just don't feel its right after paying a huge price your not allowed to make small changes.
TopSpeeder. Thank you very much.:D I don't prefer the sound of the Vento horn. A lot of people like it but I just don't see it. This is just my personal choice :) The throw of the headlights is just not enough specially under rainy conditions. The fog lamps must be switched on at all times as headlights just don't seem to cover down the road, and surprisingly the dial that controls the headlight positioning has only 3 positions :eek:
I agree with you the lights must be changed the power output is just not good or better focusing is required. I like the roots horn just don't like the one that comes in the car. This is just my personal opinion :)
bala80 I just feel like changing some things as its a new car I wanna load it up with goodies and just beam in pride with it. But this kinda control that even basic accessories cannot be changed is quite harsh on the buyer.
Like I've mentioned before I've two Toyota cars both top line and the company never told me about voiding my warranty, and I've put a lot of goodies for both the cars.
I want to change the Head Unit and probably fit a good one with a good screen that I can enjoy on long drives. But I've been told to not do such a thing. How has your experience been so far with the car ?
Note from the Team-BHP Support Team : Please use "Multi Quote" option for quoting Multiple posts, instead of creating another back-to-back post.
Last edited by .anshuman : 9th September 2011 at 23:44. Reason: See note in the post.
Old 9th September 2011, 23:54   #2862
Thanked: 107 Times
Very true. If you want to claim warranty, keep the silly originals so that you can fit them back. Do not cut wires - use connectors to mate with the original wiring. In case of trouble just put it back. Again if your relationship with the dealer is good - near impossible these days - you can get away with many things.
If you have a specialist garage and plenty of luck to help you, you can take the risk of ignoring your warranty.
basky is offline   (1) Thanks Reply With Quote
Old 10th September 2011, 00:06   #2863
Thanked: 107 Times
The lights are a disaster waiting to happen. You will have to take a decision on warranty or safety. I chose the latter with HID for the spots. Will upgrade the main light with projectors when I get hold of a good set.
The ICE is horrid seemingly because of a marketing decision on not to make the Vento too upmarket and feature rich.
Old 10th September 2011, 09:24   #2864
naveen.raju's Avatar
Thanked: 3,726 Times
My friend upgraded his lights to 100/90w from the showroom. The SA said it wont void the warranty.
naveen.raju is offline   Reply With Quote
Old 10th September 2011, 10:10   #2865
Thanked: 202 Times
Wow from the showroom with relays? Which city which dealer? Sorry can't see location from iPad app
Frontosa is offline   Reply With Quote
Volkswagen Polo : Test Drive & Review GTO Official New Car Reviews 4018 10th July 2018 10:55
Volkswagen Jetta 1.6 Litre Petrol (Trendline) Test Drive, Review & Photos Karizma Fan Test-Drives & Initial Ownership Reports 40 18th February 2010 20:45
