Old 11th October 2011, 12:02   #3211
Default Re: Volkswagen Vento : Test Drive & Review
Thanks guys. Another question:When the car is in still and in neutral gear but the engine is running , the RPM is shown as 1000. My foots off the accelator and nothing is pressing it down (re: the 3D mats fiasco someone went through). Is this normal?
anandbangalore is offline   Reply With Quote
Old 11th October 2011, 12:25   #3212
ajay_satpute's Avatar
Thanked: 1,358 Times
I think this is a universal thing, not really a Vento specific. When you crank the engine, the RPM meter has to move to some basic reading. Although, this base RPM reading can vary, it has to show something. It cant be zero. Techies can correct me if i am wrong.
P.S. Here is some tech info I found somewhere
'There is also an unmarked minimum point on the tachometer, below which the engine will quit, or stall. In most cars, this point is between 750 and 1,000 RPM's. When you release the gas pedal, the engine will automatically attempt to settle into this range, which is called the idle speed of the engine. "
ajay_satpute is offline   (1) Thanks Reply With Quote
Old 11th October 2011, 12:50   #3213
ninjatalli's Avatar
Thanked: 1,190 Times
^^ @anand - my vento idling rpm stays at 900. Had put a similar query - got answers that most Ventos are having idle rpm around that range only. So not an issue.
ninjatalli is offline   (1) Thanks Reply With Quote
Old 11th October 2011, 18:08   #3214
nileshch's Avatar
Thanked: 373 Times
My car also idles at 900 rpm. But I noticed that when I was in Ooty for a weekend, the rpm was higher at about 1000rpm. Not sure about the reason for that. Maybe the air is more rareified there?
nileshch is offline   Reply With Quote
Old 11th October 2011, 19:07   #3215
Thanked: 364 Times
Oh no, 100 was hypothetical figure! Just to explain the logic, dont take it too seriously.
By the way, I wasnt aware maximum is 85 kmpl, thanks for the information.
Originally Posted by souravc View Post
Bala , in my car the max is 85 kmpl - has VW shortchanged my pleasure by 15 kmpl and deprived me of the 3 fig magic
Can you please confirm ?
bala80 is offline   Reply With Quote
Old 11th October 2011, 21:42   #3216
souravc's Avatar
Thanked: 427 Times
Thats interesting Nilesh , have to lookup the reason ! Was the idle at standstill or when rolling ?
souravc is offline   Reply With Quote
Old 11th October 2011, 22:25   #3217
souravc's Avatar
Thanked: 427 Times
BTW , I got a sink feeling that the Skoda Rapid is Vento pre-breeze / refresh!
It looks so similar to the Vento and the lack of steering controls , etc makes it eeriely similar to our pre-refresh Vento
Old 11th October 2011, 22:46   #3218
Thanked: 364 Times
Add to that fact that the rumoured price difference is going to be around 30k. It is pre- refresh vento with a skoda badge, nothing more, nothing less.
Seriously, skoda should have atleast changed the interiors. Its very disappointing.
Old 12th October 2011, 03:50   #3219
i bought my car in april, that model does that model have digital speed option.
easterncar is offline   Reply With Quote
Old 12th October 2011, 04:21   #3220
ventolute's Avatar
Thanked: 26 Times
@easterncar. I am sure it should have it. just flick through the MID options.
I remember having seen it in my car. I booked mine in April and received it in May. So being around the same time, and I rem having seen it.
ventolute is offline   Reply With Quote
Old 12th October 2011, 09:59   #3221
TopSpeeder's Avatar
Thanked: 211 Times
I got mine in March 11, I have the digital speedo.
Like ventolute mentioned, just flipping MID should get you that.
Also I heard this is only available in HL.
TopSpeeder is offline   Reply With Quote
Old 12th October 2011, 12:29   #3222
noopster's Avatar
Thanked: 9,218 Times
Digital speedo is there from Day 1.
Just flip through the MID options by using the button on the side of the wiper stalk. It is there somwhere between total distance covered and instantaneous fuel consumption.
It is a simple digital display with km/hr next to it. If there is a phi symbol it is average (for the trip), else it is instantaneous.
I hardly use it since the needle display is pretty awesome. But used it once to check my door autolock speed (happened between 13 and 18, so assume it is 15 kmph!)
Edit: am referring to Highline only, not sre how much functionality the TL MID has (maybe Mikon can confirm)
noopster is offline   Reply With Quote
Old 12th October 2011, 15:19   #3223
nileshch's Avatar
Thanked: 373 Times
This was at idle, both at cold start as well as standstill after a long run. When I came back to Bangalore, it came down to 900 rpm.
Old 12th October 2011, 18:52   #3224
Thanked: 364 Times
You are absolutely right. This is due to the difference in the atmospheric pressure as the altitude increases.
If you have noticed the idle RPM with and without A/C will also be different due to the increased load on the engine.
bala80 is offline   (1) Thanks Reply With Quote
Old 12th October 2011, 19:00   #3225
el lobo 6061's Avatar
Thanked: 983 Times
Got a call today from VW stating that VW has introduced another 2+2+2 warranty, that is 2 yrs standard warranty + 2 yrs extended warranty + another 2 yrs extended warranty.
The another 2 yrs extended warranty is for the same cost as the 2 yrs extended warranty that is Rs. 11,xxx.
So now VW Vento can have 6 yrs of warranty period. So who all intend to purchase another 2 yrs? I'm contemplating whether get another 2 yrs warranty so my Vento would have 6 yrs of warranty, a piece of mind for a German car.
What do you all say?
el lobo 6061 is offline   Reply With Quote
Volkswagen Polo : Test Drive & Review GTO Official New Car Reviews 3998 15th December 2017 13:37
Volkswagen Jetta 1.6 Litre Petrol (Trendline) Test Drive, Review & Photos Karizma Fan Test-Drives & Initial Ownership Reports 40 18th February 2010 20:45
