Old 1st November 2015, 01:31   #7996
Thanked: 160 Times
Default Re: Volkswagen Vento : Test Drive & Review
Originally Posted by aneezan View Post
I got a Vento 1.5 TDi as a replacement while my car is at the VW service station. The car sounds horribly loud. I am not sure whether this is the case with all the 1.5 Diesel engines, but the sound almost matches a tractor.
Might be because this is an abused car.
The 1.5 TDI is very quiet, especially once you're on the move. Must be a well abused car.
Originally Posted by el lobo 6061 View Post
1.6 TDi has a tractor like noise. Once inside cabin, its hardly noticeable with windows closed and music playing at volume 6.
Have you had the MFMA (the injector adaptation that reveals any faulty injectors) undertaken on your engine. The tractor like noise vanished after the adaptation was applied. It still sounds like a diesel, of course, especially when outside, but is an huge order of magnitude quieter than before, and the tractor like sound has all but vanished.
bosporus is offline   Reply With Quote
Old 1st November 2015, 18:50   #7997
el lobo 6061's Avatar
Thanked: 1,009 Times
After all the 4 injectors were replaced, there is very less tractor like noise. Above that, engine has become a lot more responsive then before.
el lobo 6061 is offline   Reply With Quote
Old 2nd November 2015, 17:42   #7998
msd63's Avatar
I own a 2010 Vento 1.6 TDI, have done about 35k Kms. Recently I am hearing liquid splashing sound from the right rear end. Couldn't locate any water bottles under the seat. Is it diesel splashing? I have started to hear it after I went over a speed hump at a higher speed than desired because I did not see it. What is it? Can anybody throw some light on it? Can do without the additional sound effect!
msd63 is offline   Reply With Quote
Old 2nd November 2015, 19:39   #7999
srishiva's Avatar
Thanked: 905 Times
My Vento's AC stopped working today morning. Thought its humid and kept decreasing the temperature in the morning only to discover its not cooling !
Had to endure fogging of windows driving in heavy rain in the evening :(
srishiva is offline   Reply With Quote
Old 2nd November 2015, 19:45   #8000
Thanked: 111 Times
I guess its the diesel in the tank splashing. I hear it in my rapid and figo.
kiran_cr is offline   Reply With Quote
Old 2nd November 2015, 20:36   #8001
Thanked: 195 Times
Originally Posted by sunsetorange View Post
My vento (2013 TDI HL is stuck in chennai and I've returned to Trichy
It was lying at my cousin's place there. The service station guys from VW Chennai (Sundaram motors) came and had a look.
Awaiting repairs tomorrow.
Update : The car is back!
The service centre people at Sundaram Motors made a thorough inspection and finally identified the problem as a blocked fuel pump.
It was changed and the cost was Rs.5500, which was covered by the extended warranty.
sunsetorange is online now   Reply With Quote
Old 2nd November 2015, 21:14   #8002
Rachit.K.Dogra's Avatar
Thanked: 730 Times
Hey Guys,
I don't know if its an issue with my car or not. I experienced these 2 things in last winters as well and again have come up in these winters. These 2 things are only winter specific.
By the way my car just completed 4 Years and is around 61K Kms.
One big cause for these issues is I think my daily running is very less. My office is about 3 Kms from my home so probably most of the times during weekdays the engine even does not warm up properly.
1) Longer first crank of the day: During winters my car needs a longer first crank. This was last year as well when I had just changed the battery a couple of months back.
2) Very tractor like engine noise for the first few Kms. Also perceivably sluggish engine response for the first few KMs. It feels that the turbo takes time to spool up and there is huge turbo lag. For example the car just wants to die lets say on a speed breaker.
All these things crop up only in winters and as soon the weather becomes warmer things go back to normal.
Any pointers on what can I do to get around these things? or can it be a possible issue that I should get checked?
Rachit
Rachit.K.Dogra is offline   Reply With Quote
Old 2nd November 2015, 22:21   #8003
msd63's Avatar
My suspicion is water in one of the doors. The vehicle was caught in a downpour yesterday. I will have a look in the AM to see if there are any drain holes for the doors. Has a similar thing happened to anyone?
Old 3rd November 2015, 08:44   #8004
Thanked: 14,300 Times
All the doors along with the rubber beading will have small holes for channelling the water out. Check if holes are open or clogged.
Old 3rd November 2015, 17:18   #8005
msd63's Avatar
Thanks. I just tugged at the beading and water started to flow out. Have to wait and see if the problem recurs.
Old 4th November 2015, 13:32   #8006
Thanked: 1,066 Times
Just check if the accumulated water has resulted in rust, as that portion of the door is the first to start rusting. If you see any sign of rust, get it cleaned and painted fast.
Aroy is offline   (1) Thanks Reply With Quote
Old 5th November 2015, 20:24   #8007
Turbohead's Avatar
Thanked: 278 Times
Small query
1. With the engine off and the windows open, is it normal to hear the gears engaging?( while changing gears with the clutch pedal depressed). Can someone confirm it?
2. What is the oil consumption after 1st service?
Turbohead is offline   Reply With Quote
Old 6th November 2015, 16:28   #8008
Turbohead,
1. Yes you do hear the sound.
2. Oil consumption? It was never below the danger limit and ideally last till second service where they completely change oil.
prabhul is offline   (1) Thanks Reply With Quote
Old 6th November 2015, 16:52   #8009
Yes.
Depends on driving style and kilometers covered. Mostly after first service, engine oil easily lasts for 15,000 Kms without refills.
el lobo 6061 is offline   (1) Thanks Reply With Quote
Old 6th November 2015, 17:01   #8010
Turbohead's Avatar
Thanked: 278 Times
Before first service we filled about 600ml (at the service centre). After first service we filled more than 700ml (on our own).
What are the factors that can cause oil consumption? Lugging the engine? I happened to learn driving in this car (after the course from the 'driving school') ( after first service) and stalled the car approximately 40 times. Is that a factor?
Volkswagen Polo : Test Drive & Review GTO Official New Car Reviews 4013 15th May 2018 12:34
Volkswagen Jetta 1.6 Litre Petrol (Trendline) Test Drive, Review & Photos Karizma Fan Test-Drives & Initial Ownership Reports 40 18th February 2010 20:45
