Go Back   Team-BHP > Under the Hood > Team-BHP Directory > Other Cities
Old 21st August 2013, 11:23   #91
Thanked: 237 Times
Default Re: Sagar Auto Care - Pune
Originally Posted by MaxTorque View Post
Saturday visited Shetty's Au.....s why I am coming back here, but this time the precious mechanic should not touch my car".
My experience with Shetty garage is pretty bad. I had major dent and paint repair job done at his garage. I found charges are pretty high and Owner just don't go into depth for analyzing some problems. His setup is pretty good though but I am not happy at all. My friend also gave his swift after recommendation here and he came out with lot of cursing. Spares parts are charged more than Tata Motors Service Center.
sushantr5 is offline   Reply With Quote
Old 21st August 2013, 12:58   #92
Thanked: 637 Times
Are you talking about the Shetty's MAS at Aundh? Somehow your experience is contrary to the general opinion we had. Anyways now we need to more cautious.
Thanks for the input.
MaxTorque is offline   Reply With Quote
Old 1st September 2013, 02:56   #93
LP640's Avatar
Thanked: 41 Times
Hi. I know this thread is regarding Sagar auto care, but I guess most of you might be knowing about Shetty brothers as well. Here is my experience.
I got my car repaired after a frontal accident at Shetty's Maruti service Aundh.
I got my fender, bonnet and bumper changed. The quality of paint looks quite good as of now. Let's see how it is in the long run.
Other than paint, nothing else was pleasant. I was told the was ready. When my friend went to took delivery, the car was dusty, even from the inside. There was also a lizard lying dead on the rear shelf.
I had HID projector setup in my headlights for low beams. As a result of accident, headlamps were damaged but the projectors were fine. So I told them not to touch the HID setup, remove and keep the old headlamps in the boot and just put high beam bulbs in the new headlamps. The managed to damage my one high beam bulb (I had got the pair from Germany) and also both HID xenon bulbs are damaged. The flange that holds the HID bulb to projectors is missing in both the bulbs. I have no option left other than purchasing new HID bulbs.
The AC has stopped working. There is no cooling. It was working when I gave car for repair, which was nearly two weeks after the accident.
For some reason, the one rear door so not getting opened from outside. I thought may be the linking rod might have fallen off. When I opened it up to see whats wrong, I see the door handle itself is broken! I have no idea how can someone break a door handle.
Bumper was not aligned to the bonnet. The bumper was tilted to one side. There was nearly an inch of gap between grille (grille sits on bumper) and bonnet on left side of the grille. I was told the reason for this was because I opted to buy a local made bumper. Later when I opened up the bumper to see if I can correct the alignment, I saw the bumper rail was bent and was at fault.
I have to say Mr. Shetty is true and humble. But the work done by his mechanics is simply not acceptable.
LP640 is offline   Reply With Quote
Old 1st September 2013, 11:21   #94
Thanked: 637 Times
It is a really bad feedback about Shetty's Aundh. Looks like Mr.Shetty's team spoiling the garage's reputation. We should be more careful now.
Old 2nd September 2013, 21:21   #95
shivasi's Avatar
Thanked: 135 Times
Well it seems things haven't changed with this garage. I went to this place in 2011 (I think) for a regular service of my Wagon-R. I also had an issue with the front window not rolling down properly. I took the car back in the evening and was told that the issue was fixed and was charged Rs500 for this and was told that the door was opened to fix it. It kinda worked for a few days and the problem reoccurred. Since I was staying in Chinchwad at that time I did not want to drive back to Aundh again. So I went to this service center in Nigdi(Shalu Agency) who to my surprise opened the inner cladding to show me that only some lubricant was dropped in and the plastic protective sheet was intact with the adhesive still in place. I have never gone back to the Shetty garage since and will never go!! What a cheat!!
shivasi is offline   Reply With Quote
Old 8th December 2013, 16:10   #96
comfortablynumb's Avatar
Thanked: 1,001 Times
Went to Sagar today after a really long time. A full wash + interior cleaning of the Scorpio cost me Rs.350.
While I was waiting, also came to know that they wash car seat covers too; so made an impromptu decision and gave my vehicle's seat covers to be cleaned for the 1st time in almost 4 years. That was another Rs.550, which I thought was quite reasonable considering the number of covers [including the arm-rest and head-rest covers], and the fact that they themselves remove the covers and re-fit them when they are ready. It remains to be seen [have to go back next Sunday to have the covers re-fitted] how the cleaning quality is. If it matches with their vehicle cleaning quality, then I'll be more than a happy chappy!
Cheers,
Vikram
comfortablynumb is offline   (3) Thanks Reply With Quote
Old 26th May 2016, 16:54   #97
sajo's Avatar
Thanked: 1,063 Times
With the current water situation in Pune (inadequate supply and tanker operators who loot) , how are the rates in washing centers like "Sagar" these days ?
I am self washing once every 15 days with extremely hard and nearly dirty tanker water available to me , which is actually leaving behind stains on the glass and the bodywork.
sajo is offline   Reply With Quote
Old 26th May 2016, 17:18   #98
Originally Posted by sajo View Post
With the current water situation in Pune (inadequate supply and tanker operators who loot) , how are the rates in washing centers like "Sagar" these days ? .
Even I haven't been there in quite a while, but you can call and check with Sagar himself - 9822330420
Cheers,
Vikram
comfortablynumb is offline   (1) Thanks Reply With Quote
Old 29th June 2016, 17:16   #99
Paleo's Avatar
Thanked: 30 Times
Cheers,
Vikram
Got my FIGO washed today. Full outer wash, underbody and internal cleaning(vacuum and air) and engine bay. Just Rs 300/
Such an old garage (if I'm not wrong, its some 25 yrs old) and still does the job right.
Polishing etc is extra. And they have some complete higher package at Rs 999 (includes almost everything you can think of)
But for people looking at a quick and clean job - its the best place in town. At the most, work is completed in an hour. And all stations are manned with ample personnel
Paleo is offline   (2) Thanks Reply With Quote
Old 3rd October 2016, 17:28   #100
PetrolRider's Avatar
Thanked: 237 Times
I need to do a small dent repair on my Micra. Can you guys suggest any good body shop near Kharadi or Viman nagar area?
The dent is on rear wheel arch above the bumper join area.
Last edited by PetrolRider : 3rd October 2016 at 17:29. Reason: Some unwanted edit marks
PetrolRider is offline   Reply With Quote
Old 18th March 2017, 13:38   #101
vrprabhu's Avatar
Thanked: 363 Times
Originally Posted by Paleo View Post
Got my FIGO washed today. Full outer wash, underbody and internal cleaning(vacuum and air) and engine bay. Just Rs 300/-
Just back after getting my Palio washed. Rs. 300/- for the full course
Plenty of manpower is a big plus - and no attempts of fleecing by offering other services at reduced cost.
I wanted to do some minor repair, but the owner was honest enough to admit to tell me that there is nothing really wrong and don't fix what ain't broken.
vrprabhu is offline   (1) Thanks Reply With Quote
Old 11th September 2017, 15:22   #102
shivasi's Avatar
Thanked: 135 Times
Based on this thread I drove from Nigdi to Kothrud to get my S-Cross washed. Luckly it was the Ganesh Visargan day and there were no cars for a wash.
I got my car washed and leather cleaned for 450+750. I found it absolutely VFM as compared to 3M where I would easily pay 4000+.
Also had a long chat with the owner. The job done was very professional and I was very happy with the service. Need to mention, TBHPs get a cuppa tea too
Thanks guys for sharing this wash center. I plan to visit once in a month and get a complete wash done.
shivasi is offline   (1) Thanks Reply With Quote
I complained abt my dealer (Sagar Auto), now what? ajayclicks Indian Car Dealerships 9 29th July 2007 00:31
