Go Back   Team-BHP > Under the Hood > Team-BHP Directory > Other Cities
Old 4th November 2015, 14:27   #556
rakesh_r's Avatar
Thanked: 738 Times
Default Re: Trusted/Untrusted Petrol Pumps in Pune
Originally Posted by Amazing View Post
PS: I am not willing to try this Essar stuff in my Linea D (multijet), till some experts assure me :-)
Am using System D in my swift D since past two years and the MJD likes it.Engine becomes smooth with good throttle response.I normally avoid filling premium fuel unless specified by the manufacturer.
rakesh_r is offline   Reply With Quote
Old 11th April 2016, 14:10   #557
Thanked: 41 Times
Which petrol pump in Hinjewadi would be preferable for normal unleaded petrol - Samarth HP pump opposite Fortune or Shell pump towards Hinjewadi chowk? I am planning to refuel in Pune for my Mumbai-Goa road trip as I can pay only with credit card for my company car (not sure if other highway pumps will have card machine in use).
manish84 is offline   Reply With Quote
Old 11th April 2016, 14:33   #558
Thanked: 440 Times
Default Re: Pune : Roads, traffic conditions, route queries and other assorted rants.
Originally Posted by FINTAIL View Post
A couple of places- near suburb dearest, Baner.
A] The Baner Petrol Pump.
https://plus.google.com/105243038577...ut?hl=en&gl=in
Okay- About a month or so ago, they did try to pull a fast one on me- First time ever. Anyways- I generally used to tank up at Autolines. For Nitrogen though, this pump is good. I generally used to frequent this place.
I pass by it everyday, but I never go there (Mauli Petrol Pump) and if I absolutely need to fill up, I do just 100 to get me safely to better pumps in the city.
Back in 2010, my FE went from 13+ to 6 after filling up there. 2 years back while on Baner Road, my car's Fuel warning light up, it was raining and traffic was bad, I decided to top up here to be on the safer side. The car ahead of me filled up only 200 (as per the meter), but this guys took 500 rupee note and didn't return back anything. The lady driver of the car just ride away. When I moved in to fill up. I filled just 100 and moved on.
I always make it a point to step out and watch the "reset to zero" and the final count. Never ever topup while sitting in the car.
freedom is offline   Reply With Quote
Old 11th April 2016, 15:07   #559
Thanked: 669 Times
For these bunks, you will have to leave NH4 bypass & drive towards hinjewadi. And doing that on a weekday in heavy traffic is a task and it's not a straight forward right turn towards hinjewadi from NH4 bypass.
Couple of options, first one is Shell bunk before hinjewadi/bhumkar chowk (right side, opposite Indira institutes) by taking service road near punawale and get onto other side via under-bridge.
Second option is Shell bunk at warje. It's on service road just before warje flyover & it's on left side for you so entry/exit won't consume much time.
sukiwa is offline   Reply With Quote
Old 11th April 2016, 15:15   #560
noopster's Avatar
Thanked: 9,576 Times
If Hinjewadi (Shivaji) chowk is on your daily commute, use the Shell pump located there. It is also 2/- cheaper than the Shell station along NH4 in Wakad. Be sure to be there early (they open at 8 am) because after 9, you will find it tough to merge back into the traffic.
It's a good pump, my regular top-up place for regular unleaded. Cards accepted so you should have no problem.
noopster is offline   Reply With Quote
Old 11th April 2016, 15:55   #561
Thanked: 41 Times
Thanks for the inputs. I am staying in Fortune Hinjewadi the previous night. So will chose between Shell Hinjewadi or Shell Warje depending on when I get free. Is Hinjewadi Shell's price cheaper than the Warje one?
Old 11th April 2016, 16:28   #562
mikon's Avatar
Thanked: 375 Times
Yes it is.
And they open from 0600 hrs to 2230 hrs.
mikon is offline   (1) Thanks Reply With Quote
Old 13th April 2016, 08:37   #563
Thanked: 669 Times
On sunday, I had to wait till 7am on more than one occasion for them to start their operations.
sukiwa is offline   (1) Thanks Reply With Quote
Old 13th April 2016, 08:52   #564
pjbiju's Avatar
Location: Karamattom, Aluva, Kotagiri, Yercaud, Hospet, Indore, Nashik, Pune (now)
Thanked: 465 Times
Which petrol pump in Hinjewadi would be preferable for normal unleaded petrol - Samarth HP pump opposite Fortune or Shell pump towards Hinjewadi chowk?...
Yes it is.
As others have suggested, Shell Hinjwadi is the one to use. They now have a board saying that they are OPEN 24 Hours and I just confirmed it by calling them on 9850883647.
pjbiju is offline   (2) Thanks Reply With Quote
Old 13th April 2016, 09:33   #565
Thanked: 440 Times
How and why are they selling at a lower cost?
I thought the highway one would be cheaper as its outside the PCMC limits. Right? Is the Hinjewadi one in the "Gram Panchayat" zone?
With the LBT on fuel abolished, is fule outside Corporation limits cheaper than city due to BS3 vs BS4?
A few years back the approach road for Tathawade Shell was in a bad shape. I used to avoid it and instead goto Hinjewadi when heading towards Mumbai.
Old 13th April 2016, 12:17   #566
noopster's Avatar
That's probably why. The BP pump in Phase 2 (near Wipro circle) is also 2/- less than other PSU pumps.
Old 26th June 2016, 20:25   #567
akshay380's Avatar
Thanked: 655 Times
Guys is petrol cheaper outside pune Limits? If yes any trusted pump on Pune Bangalore highway?
akshay380 is offline   Reply With Quote
Old 25th July 2016, 11:13   #568
sajo's Avatar
Thanked: 1,063 Times
Shell Hinjewadi seems to have started pulling the "Sorry sir, Power Only" trick. The price difference per liter is over Rs 10, but the actual benefits are quite minimal.
sajo is offline   Reply With Quote
Old 26th July 2016, 08:22   #569
Thanked: 669 Times
Is this only in rush hours? I haven't faced this when I fill-in petrol in afternoon, be it at hinjewadi, tathawade or warje.
Old 26th July 2016, 09:53   #570
kutoos's Avatar
Thanked: 121 Times
I faced this on Saturday Noon. Sorry Sir we have Power. I started to drive off when a reluctant manager directed me to another pump. Filled it at Rs 66.8 which is only 1 Rs more than Autolines HP.
kutoos is offline   (1) Thanks Reply With Quote
Trusted Petrol Pumps in Bangalore v1p3r Bangalore 1228 24th June 2018 18:53
Trusted Petrol Pumps in Delhi NCR sheetumanu Delhi NCR 299 19th February 2018 15:01
Trusted petrol pumps in Mumbai amitsingh08 Mumbai 246 7th August 2017 19:02
Trusted Petrol Pumps : Ahmedabad cmdalvi Other Cities 9 26th August 2016 12:47
Trusted Fuel Stations / Petrol Pumps : Mysore MCR Other Cities 0 9th July 2010 21:10
