Go Back   Team-BHP > Under the Hood > Team-BHP Directory > Other Cities
Old 2nd July 2015, 14:02   #46
Thanked: 139 Times
Default Re: Nitrogen Filling Stations-Hyderabad
Originally Posted by zenren View Post
40 and 20 are for all tyres.
Which pump is this in the list above??
Is it - "IBP Petrol bunk, Madhapur (next to Pride Honda)"?
Sounds very reasonable.
Xenex quoted 200 and 50 respectively.
deepv is offline   Reply With Quote
Old 3rd July 2015, 12:09   #47
Thanked: 436 Times
No, this is not in Madhapur. The bunk is Opp TCS while going towards Mind Space.
JoseVijay is offline   (1) Thanks Reply With Quote
Old 3rd July 2015, 22:05   #48
vnabhi's Avatar
Thanked: 1,317 Times
That's the IOC COCO bunk, opp TCS and beside Lemon Tree. In fact, that bunk was there for the past decade, and it was the only one in that area. But it was a small one, and not a COCO outlet, and only a couple of years back expanded into a big one. They take Citibank IOC credit cards, hence all my colleagues go there.
I heard from my colleagues that he does not charge for N2 refills, but they don't mind being tipped 10 bucks for each refill.
Old 4th July 2015, 01:25   #49
Thanked: 139 Times
Hmm .. I usually use back side road of Mindspace (or Inorbit road at times), so wasn't able to understand this one.
10 or 20 is pretty reasonable, BP pump near Kapadia Lane is also like 200 and 50 category one
One more doubt .. on tyre pressure.
I had been using 27-28 with the OE tyres on my Fabia, however with new Michelin XM2's this guy put nitrogen at 32psi and suggested to maintain the same.
My initial experience has been pretty fine in a week or so, as in there haven't been much noises (and/or any vibration) which would have been the case with old tyres (with normal air at 30 or above).
Here also I see most folks using 32, looks like that's the number to go in case of nitrogen.
Old 15th July 2015, 21:10   #50
petrolveins's Avatar
Thanked: 113 Times
Please let me know on the below:
1. Shell petrol bunk near Gachibowli/Nallagandla.
2. Nitrogen filling stations near Gachibowli/Nallagandla.
Searched this thread but could not find any.
Thank you.
petrolveins is offline   Reply With Quote
Old 16th July 2015, 07:30   #51
Thanked: 436 Times
Thank you.
1. Shell has stopped its operations in Telangana and Andhra.
2. I am not aware of Nitrogen filling stations in Gachibowli, and I don't think if there is any in Nallagandla either.
Old 16th July 2015, 10:41   #52
Thanked: 139 Times
Originally Posted by tjacob View Post
Hi-tech petrol pump opposite TCS and adjacent to Cyber Pearl
HP Bunk (Gachibowli)
Our list does have one option for Gachibowli (as above), not sure though where exactly it is.
If this is not an option, then probably the pump opposite TCS near Cyber Pearl would be next nearby option.
deepv is offline   (1) Thanks Reply With Quote
Old 16th July 2015, 18:22   #53
zenren's Avatar
Thanked: 1,725 Times
Thank you.
Closest for you would be Mallikarjuna Petrol station, opp. BHEL gate, which should be around 5km from Nallagandla
zenren is offline   (1) Thanks Reply With Quote
Old 20th July 2015, 13:20   #54
bhappyharsha's Avatar
Thanked: 11 Times
I have a question. Can I re-fill my tyres with nitrogen after driving for say, 10 kms? the concept of heating tyres (inflated) is not applicable for Nitrogen air? I am a little confused.
bhappyharsha is offline   Reply With Quote
Old 20th July 2015, 16:34   #55
zenren's Avatar
With nitrogen, the variance with temperature is usually much lesser and hence a 10km without too much braking would not overheat the tyres and you can go with the same numbers.
In case of air, the tyres would have difference of up to 4-5 psi when hot but it need not be uniform across all tyres, leading to different pressures once it cools down. With nitrogen, I've not seen it increase beyond 1-2 psi even after a 200km trip.
zenren is offline   Reply With Quote
Coimbatore: Nitrogen filling stations FuelInjector Tyre & Alloy wheel Section 8 30th July 2016 01:43
Chennai : Nitrogen Filling Stations classicselva Chennai 55 1st April 2015 16:17
filling nitrogen in tubeless radials mdesai_1981 Technical Stuff 3 7th May 2008 02:02
Nitrogen filling in car tyres sn48001 Tyre & Alloy wheel Section 1 5th January 2007 14:47
