Go Back   Team-BHP > Team-BHP > Team-BHP Advice > On owning a car
Old 12th June 2015, 15:06   #676
dcs
Thanked: 15 Times
Default Re: Maruti Zen MPFi Fuel efficiency issue.
Dear Rahul,
Thanks for the revert, please find the answers in Brackets.
Also, like I said, there has been absolute no change in anything that might affect the Fuel Efficiency. Also, neither the car, nor me are New to each other. That makes it a point of concern. Have driven this car in most challenging conditions (road, traffic, service and all) but have never faced a situation that I can not relate to.
  1. Have you confirmed correct tyre pressure? (Still the same pressure- 28 PSI)
  2. Please check the fuel hoses for leakage. (no fuel spill, no fuel Leaks, double checked)
  3. When did you last change the spark plugs? This too could be the reason. ( Spark Plugs Changed on Last Service)
  4. Is air filter cleaned / replaced at required interval? (As always- Yes)
  5. Did you change the make and grade of the engine oil recently? (No, still running on the same rating)
  6. When you start the car in the morning, do you see white smoke for a minute? (No)
  7. After a cold start, the idling speed of the engine is higher but it settles down after a few minutes. Please tell whether the idling speed is steady or varying after it settles down? (nothing abnormal detected)
All Cheers
dcs
dcs is offline   Reply With Quote
Old 24th June 2015, 00:18   #677
Thanked: 196 Times
Question Toyota Fortuner AT - sudden drop in fuel efficiency/mileage
Make: Fortuner AT 2013
ODO: 51600 kms
About a month ago, I got the 50,000 km service done from Galaxy Toyota, Moti Nagar, New Delhi.
While I haven’t kept a diligent track of the actual fuel consumption but once in a while I look at the in-dash information panel for information. It always showed 11.1 km/l.
To my surprise it showed 11.1 km/l even after I did 3700 kms trip to Leh/Hanle last year. Because there was no dip, I was happy.
However, while on a visit to Ajmer last weekend, when I checked the in-dash display, it showed 10.9 km/l.
I assumed the drop would have been because of excessive hot weather combined with both front and rear ac running during the daily commute to and from office. I do a daily run of about 65 kms.
To my surprise when I checked today evening the display showed 9.9 km/l. It has further dipped and it now shows 9.8 km/l.
You may ask – is there anything different that I have done over the past month or so?
To best of my recollection - answer is ‘no’.
For me, I have used the same petrol pump for nearly a year. In fact, the same machine.
I have not changed the route taken to office or back. There is though slight traffic build-up in the evening - about a 2 kms stretch on NH 8. For those from Delhi NCR the stretch is from top of IFFCO Flyover to erstwhile Toll Gate/Rajokri flyover. Other than that there is no other noticeable aspect.
That said, while returning from Ajmer, I had put in fuel at a pump besides the highway. The fuel range, then, was showing at 15 kms. Is this somewhere to blame with impurities at the bottom affecting the efficiency?
During the Ajmer trip I also noticed that the reserve light indicator had stopped working. I took the car to Galaxy Toyota this Sunday and they reset the indicator. At least this is what they told me. I am yet to test the indicator. They also said to switch off the ignition when tanking up.
One more thing, I put in Nitrogen about a month ago. Could this affect the efficiency?
Sorry, another aspect - they changed the break pads during the 50,000 kms service.
Should I be worried and take the car to service station immediately? Or, wait another week, tank up full, check and then decide?
I am leaving for Gwalior (en-route Bhopal) this Thursday afternoon and wouldn’t want to be stranded on the highway!
Thoughts from experts or Fortuner owners on the forum are welcome.
Ps: I feel it is time I started my own ‘ownership report thread’. Good to share experience.
Last edited by Traveller Nayak : 24th June 2015 at 00:18. Reason: Mods: please do move this if it belongs under a different head. Thanks.
Traveller Nayak is offline   Reply With Quote
Old 24th June 2015, 01:16   #678
Thanked: 530 Times
Default Re: Toyota Fortuner AT - sudden drop in fuel efficiency/mileage
ODO: 51600 kms
While I havenít kept a diligent track of the actual fuel consumption but once in a while I look at the in-dash information panel for information. It always showed 11.1 km/l.
It is surprising that the display ALWAYS showed 11.1 kmph in past! Maybe there was some electronic / computer problem, the calculations had stopped but the display was showing the last calculated value from the memory. This might have been fixed during 50000 km service or when they fixed the reserve indicator. Hence now you see different value.
You will be surely aware that the FE shall be calculated on tank-full to tank-full basis. Value on the display is an instantaneous value just for your approximate reference.
[b]
The impurities in the fuel shall be arrested by the filter inside the tank. If the filter is clogged or broken, you will see some jerks / momentary loss of power while driving.
[b]
Nitrogen will not reduce the fuel efficiency. Insufficient tyre pressure will surely reduce the fuel efficiency.
[b]
If you let me know the fuel efficiency on tank-full to tank-full basis, I can advise on the need to visit ASS. For a big vehicle like Fortuner, fuel efficiency of 9 kmph shall be considered good IMO.
Rahul Bhalgat is offline   (1) Thanks Reply With Quote
Old 24th June 2015, 01:56   #679
Thanked: 196 Times
I am going to tank up tomorrow evening for the trip to Bhopal. I will keep a track and come back with the information. Thanks much.
Old 24th June 2015, 11:14   #680
Thanked: 196 Times
Update:
as of this morning the display mileage has gone down to 9.7 km/l
Old 11th September 2015, 00:00   #681
Thanked: 118 Times
Default Re: ARTICLE: How to get the maximum Fuel Efficiency
Bangalore is generally cool and the A/C need not run at the coldest always. Hence, I vary the temperature setting according to the weather to save fuel.
rohanak1 is offline   Reply With Quote
Old 28th November 2015, 22:57   #682
Thanked: 46 Times
This article on The Guardian gives some tips on saving fuel.
http://www.theguardian.com/environme...permiling-tips
Among other things, it is mentioned in the article that an engine will be more fuel efficient once it has warmed up and it takes about 8 km of driving for an engine to warm up. Is it applicable to the tropical climate of India? In Kolkata, where the average temperature is > 30 degree centigrade on most days of the year, how long should I drive for a petrol engine to warm up?
I wanted to ask another question to the petrolheads here. The Alto K10 has manual climate controls with 4 blower speeds, 5 temperature settings (cold, cool, neutral, warm, hot) and another control for direction of air flow. Will "blower speed 1 + cold" consume more fuel than "blower speed 2 + cool"?
wishnipon is offline   Reply With Quote
Old 28th November 2015, 23:41   #683
Awaiting Email Confirmation
Thanked: 319 Times
Fuel efficiency is max after the gearbox warms up which is upwards of 8 km and more. Gearbox oil viscosity is a great determinant of fuel efficiency.
Regarding your ac query; please check how many seconds the compressor stays engaged on a very hot day with the car parked in a ventilated garage in the different modes you mentioned. The compressor state decides the fuel efficiency since it takes up at least 2 horsepower in small cars with all the other electricals gadgets that come on when the compressor is compressing the refrigerant.
drpullockaran is offline   (1) Thanks Reply With Quote
Old 29th November 2015, 01:48   #684
Thanked: 46 Times
8 km is too much for me. I regularly commute to two places which are like 2.5 km and 4 km away from my my residence! I often give a ride to a friend to drive a few extra kilometres. But even then, this 8 km mark is tough to achieve!
Old 29th November 2015, 02:17   #685
Thanked: 14,777 Times
Infractions: 0/1 (5)
That figure is almost true for me at least.
After I start off for the day (the first drive after a long stop), the coolant temperature is around 25 to 30 degrees C depending on the ambient temperature. My car (both Ritz VDi & Swift ZDi) takes around 7-8 kms to reach its operating temperature (87 degrees C).
I don't ran the turbo spooling RPM too in these kilometers, I keep it between 55-60kmph in 5th gear. One the needle is at its operating temperature, the drive is regular.
In winters the distance to reach the operating temperature zone is around 9-11 kms whereas in summers the same is achieved in 5 kms.
PS : I have checked the data using ELM327 adapter through Torque App.
+1.
a4anurag is online now   (1) Thanks Reply With Quote
Old 30th November 2015, 18:03   #686
gpa
gpa's Avatar
Thanked: 282 Times
Sorry about going OT, but I noticed that my Brio takes about 2 kms to come up to the operating temperature of 91-92 deg C on the Torque App. I thought diesel cars run hotter and hence should take much shorter time to get up to operating temperature.
Old 30th November 2015, 20:06   #687
Thanked: 165 Times
+1 to that.
In a petrol car/bike, I drive at lower RPMs for the first 3-4 kilometers and use engine braking / down shifting to slow down. After 8-9 kilometers, I can feel that the gear box oil has warmed up as gear shifts become smooth and power delivery becomes instantaneous.
Swapnil4585 is offline   (2) Thanks Reply With Quote
Old 9th February 2016, 18:01   #688
sachinkudva's Avatar
Default Low Mileage & Black Smoke issue with Fiat Punto 90 HP Diesel
Hey all,
I have a 3.5 yr old Fiat Punto 90 HP Diesel car. The car was fantastic for the first 3 years after which as part of my big 60,000 KM service I decided to get the clutch kit and gear cable replaced. This was in June 2015.
From August-September onwards I started noticing a lot of issues with the car.
1. Heavy Black smoke from the exhaust while accelerating.
2. Reduced Mileage. (came down to as low as 10-11 Kmpl in city conditions.)
3. Reduced Pick-up.
Now for the first issue, this was solved by replacing 3 faulty glow plugs. (all under warranty). This reduced the black smoke issue drastically but I can still see more smoke than I ever noticed in the first 3 years of usage. I feel like I am driving a city taxi!!!
For reduced pick-up, the Fiat guys told me to replace the ECR valve in my car. They found the Turbo to be fine. Luckily I got this too replaced under the extended warranty. The pick up is back to its normal but ever since this replacement was done, my Check Engine light has been glowing.
The low mileage issue never got sorted.
One observation was that when I drove to Goa in December, I got a mileage of 18 Kmpl in the straights. So I guess this has to be a clutch issue!
I have given my car to the service centre (Vecto Motors, Hosur Road) like 5-6 times in the last 2-3 months. These guys are just not able to fix the check engine light issue and the low mileage issue.
Regardless to say, driving a diesel car at 10-11 kmpl in city is hurting my finances pretty bad. I even lodged an official complaint with Fiat and now they are coordinating technically with the Vecto motors guys.
Has anyone faced the above issues and any idea what can fix the same?
I still have like 6 months left in my extended warranty and would like to fix these issues before that lapses.
Also any pointers on the best Fiat service centre in Bangalore. Someone I can trust will point out the exact issue and help me fix it permanently.?
Would love to have some assistance here.
FYI, I have now run ~ 75000 kms in 44 months. Which is pretty moderate usage I guess.
Thanks a lot in advance.
sachinkudva is offline   Reply With Quote
Old 9th February 2016, 18:37   #689
2500cc's Avatar
Thanked: 243 Times
Default Re: Low Mileage & Black Smoke issue with Fiat Punto 90 HP Diesel
I Had similar issue in scorpio, after multiple visits to the service, we found the vacuum pipes had given up. Have the technicians inspect them. Also, get the Air filter checked.
2500cc is offline   (1) Thanks Reply With Quote
Old 9th February 2016, 19:40   #690
sandeepmdas's Avatar
Thanked: 790 Times
This could be a trivial question:
Have you tried refueling her from different petrol bunks or are you using the same one since August-September? Since you got a mileage of 18kmpl in your Goa trip, chances are you might have refilled from a outlet that's not your usual one. So no harm checking the quality of fuel first, if you ask me.
sandeepmdas is offline   (1) Thanks Reply With Quote
Article on how ARAI conducts its fuel-efficiency tests vishnurp99 Technical Stuff 28 3rd May 2016 12:18
Where to get fuel (lid /cap) stickers to Avoid confusion at Fuel Station? kspv Modifications & Accessories 20 18th March 2010 01:06
Swift ZXi Climate control_improve fuel efficiency pranil Technical Stuff 21 13th March 2006 18:16
