Go Back   Team-BHP > Team-BHP > Team-BHP Advice > On owning a car
On owning a car Help articles related to owning a car
Thread Tools
Old 31st January 2008, 05:23   #226 (permalink)
mithun's Avatar
Is there any advantage in going for Paint sealant coating ?
I've seen some dealers advertising that in their service centers !
__________________
Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly.
Old 4th February 2008, 11:30   #227 (permalink)
gandolf_thewise's Avatar
hey guys
i think its great the way car care has been so thoroughly explained by team - bhp members. ITS BEEN REALLY HELPFUL. i a in abit of a dilema . I own a maruti swift vxi azure gray . Like so many other helpless car owners a person on a cycle decided to liven up my driver side rear door . Now there is a nice dent on my door with the paint chipped off. I got my car door painted from sai service in mumbai the paint matching has been great but the polish has sufferes. Its looks very poorly finished . Not as bright as the normal doors. Very smudgy feel to it. can i do anything to improve or correct this ??? any place in mumbai where this can be done and the approximate price .??? would really appreciate help on this front
gandolf_thewise is offline   Reply With Quote
Old 4th February 2008, 11:54   #228 (permalink)
androdev's Avatar
why don't you go back to them asking for a better finish? i am sure they should offer a finish that matches with the factory finish. more than the polish, it looks like they did a poor job of clear coat. my suggestion is to take it back to the same people and ask them give it a better finish. i think some inexperienced fellow worked on your car. i had a similar problem recently in bangalore.. they gave a lousy color match, they used a hair brush to do the base coat and a terrible clear coat finish (with foggy finish and dust particles in clear coat). i complained to them (not gently).. and they put their best man on the job this time and the final finish was perfect.
so my advice is.. identify all the problems (wash the car and watch the finish closely in bright light), take it back to the same body shop and complain. and see how it goes. as long as they put their best employee on the job, u can be sure u get very good results. refinishing is an extremely skilled job.
androdev is offline   Reply With Quote
Old 5th February 2008, 08:33   #229 (permalink)
hey androdev
thanks a bunch for the prompt replies . I will def get in touch with the service centre. Many a times i have had people telling me that it is just not possible to get a true factory finish as the entire car is painted at the factory using diff technology as against a single door or any other body part for that matter.Is it true ? Also i forgot ot mention that the colour looks smudged only from certain angles and that too from a distance prob more in dull light then in bright light....dont know if that helps !
Old 5th February 2008, 13:28   #230 (permalink)
smsrini's Avatar
[quote Is there any way to clean up the car without damaging the paintjob?
>>> Get your lancer workshop to do a quick rubbing job if nothing else works. They have something called 3M diamond polish, which takes care of stubborn stains/tar marks 90% of the time.
Also, can any preventive measures be taken when going on the highway to avoid this situation? Maybe some coating on the front that prevents the bugs from sticking?[/quote]
>>>> Apply a healthy dose of wax polish or dab on a thin film of vaseline which should be easy to clean with soap/pressurized water later on....The idea is to put a thin film ontop of the paint to seal it off.
smsrini is offline   Reply With Quote
Old 5th February 2008, 15:36   #231 (permalink)
androdev's Avatar
Originally Posted by gandolf_thewise View Post
hey androdev
It is difficult to get 100% color match, unless the body shop knows the correct paint formulation (as u know they mix few paints to get the color match). But most body shops of any decent repute give you a good color match, unless rest of the car is too faded. So color match is a gamble at times.
But the finish and gloss/shine can be better than the factory finish if the body shop is sincere. The trick is to get their best man to work on your car. I learned it the hard way. My suggestions:
1. Make a list of problems you found and make sure you can show the same problems to the body shop fellow when you take the car there. Mostly you have to park the car in such way that the amount of light on that panel highlights the defects.
2. Take the car and show the problems to the body shop fellow. He has to be convinced of your problems, otherwise they wont be sincere in their rework. Make sure they are paying attention to your problems. Do not fight - but try to talk to senior staff till you get their attention and commitment to solve your problem. Try to strike a deal with the top manager and not the painter.
3. Insist that their best person is assigned to your car. The most important thing! Since the service offered is of poor quality, they must do everything possible to satisfy you. Do not compromise on this one. Meet their 'best man' and explain him all the problems again and if he explains why these problems occurred and assures you a perfect finish, you are making good progress. At the minimum they should be doing multiple thin layers of clear coat on your car with sufficient drying/curing time in between.
4. Make sure they use a paint booth for the job. When the load increases, most shops start painting the panels in dusty corners of the garage (some even on the road side)
5. Ask them to mask/cover the rest of the car as much as possible while they are doing the rework.
7. I even complained to the Dupont Bangalore people (their paints are being used) for the poor color match and finish. They actually sent their specialist to oversee the work carried out by the body shop.
6. Do not leave your car there unless you are convinced that they are going to do it right this time.
Refinish is all about skill and material (Standox paints by Dupont are good) and less about 'technology' so don't believe anyone that says factory finish can not be matched. Color match is hard, but finish and gloss can be matched, can even be bettered.
Disclaimer: I am not an expert in this area. I just had a similar experience as yours and these are my learnings from getting that mess cleared up.
Old 5th April 2008, 14:19   #232 (permalink)
Default TP3C is now "Car Spa"
Originally Posted by moralfibre View Post
Guys, does anyone have the updated website address for tpc3 care? The one listed above has gone down.
No website, Although Tpc3 is now "Car Spa".
Location - Inorbit Mall Basement.
mayurpalav is offline   Reply With Quote
Old 18th April 2008, 20:53   #233 (permalink)
nirmalts's Avatar
Default Rubbing compound Vs Wax
Hello,
Whats the diference between rubbing compound and normal wax polish?
Nirmal
nirmalts is online now   Reply With Quote
Old 19th April 2008, 12:09   #234 (permalink)
I have a few questions?
1. If the car is exposed to sunlight and parked outside without cover, will it cause any damage? as i think most of the paints are designed to withstand the heat!!!
2. My car is parked outside the home and i use it only once in a week. Should I put a cover for it? Usually i was the car once in a week.
snb77 is offline   Reply With Quote
Old 25th April 2008, 16:31   #235 (permalink)
hrsraghav's Avatar
I have a scratch on the headlight plastics. Its not a scratch rather the headlihgt was rubbed against the rear bumper of another car, so the upper plastic layer has been rubbed off. A freind of mine told me that using thinner will help somewhat to regain the transparency of headlight.
Guys this is the only sratch on my car, and its really paining me.
Is there any method by which such scratches can be removed or reduced.
Rudra Ji, please share your knowledge in this regard
hrsraghav is offline   Reply With Quote
Old 25th April 2008, 19:07   #236 (permalink)
androdev's Avatar
This might help.
headlight polishing
Old 25th April 2008, 22:57   #237 (permalink)
hrsraghav's Avatar
This might help.
headlight polishing
Thanks Androdev, quite knowledgable information.
I will try to implement this.
Is there anywhere in Inida from where we can can get 3M car rubbing and car polishing compunds?
Old 26th April 2008, 12:30   #238 (permalink)
PatienceWins's Avatar
I have the same problem. Please advice.
PatienceWins is offline   Reply With Quote
Old 26th April 2008, 15:08   #239 (permalink)
Team-BHP Moderator
Jaggu's Avatar
Its advisable to use car cover to protect the car interior/exterior from the elements, esp the UV rays which will eventually take a toll.
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 26th April 2008, 15:56   #240 (permalink)
Team-BHP Moderator
theMAG's Avatar
Car covers(the good ones) have a tendency to develop micro-scratches on the car paint - use with caution if your car is black.
__________________
If you lose your temper, you’ve lost the argument
Thread Tools
ARTICLE: The Team-BHP Guide to ADVANCED Car Audio navin On modifying a car 23 2nd December 2007 09:55
ARTICLE: The Team-BHP Guide to BASIC Car Audio navin On modifying a car 22 1st December 2007 17:09
An Article From Economictimes (Investor Guide) About Car finetuning Technical Stuff 3 14th September 2006 10:51
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
