| On owning a car Help articles related to owning a car |
| | Thread Tools |
| | #79 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
I guess getting it washed at a service centre is the only way out.
__________________ "You can discover what your enemy fears most by observing the means he uses to frighten you." - Eric Hoffer | |
| | #80 (permalink) |
| BHPian | At service centers they use diesel to remove those black tar stains. I have successfully used kerosene to remove those. But I am afraid that doing so, will reduce the natural shining of the paint, and you may need to wax it after cleaning using diesel/kerosene.
__________________ Swift VDi, May 2007, 54K+ kms |
| | #84 (permalink) | |
| Senior - BHPian | Quote:
Although i have two more questions. I use Amway silicon glaze Auto polish on the car, and has been satisfied with it. But haven't seen any others using it. Is it good enough? Also, i used to use Amway car wash and that also was highly satisfactory. Now my bottle is almost over. Should i go in for Sonax instead?
__________________ I'm far from perfect. I hope i can improve. Thats why i'm here! | |
| | #85 (permalink) |
| BHPian Join Date: May 2006 Location: mumbai
| Hi guys I have noticed a couple of spots under my bonnet (XETA) which have caught rust. Anyway that can be avoided from increasing. Also the wiper's rings and some hinges have got spots of rust on them. Would like to spot and cover them completely. During the recent downpour in Mumbai (Saturday), the water seeped in through my car door and the carpet had soaked a lot of water....it literally took me 4 hours to squeeze & dry technique to clear the same. However on Monday morning I still saw the carpet oozing out some more water ..... the same happened on Tuesday. What I have done thereafter is kept loads of newspapers and got them to soak the water from the carpet.... I think it will take me another couple of days to sort the carpet out. What I need to know is: 1) What should be the immediate action after the carpet is soaked in water? What hazards could the car have post a downpour like this? 2) I have got to know that there willbe bad odour in the car from now on...what is the best way to avoid it? |
| | #86 (permalink) |
| BHPian Join Date: Feb 2005 Location: Bangalore
| How much ever you clean the floor carpet the water and the smell is very difficult to remove off. You can remove the carpet and dry it in shade , if you dry it in sun the carpet will change shape and become like papad!. And the odor is one big task. Most important is that the water between the carpet and the vehicle floor should be removed other wise it will lead to rusting . So if you are OK to spend a little bit more , you can change your floor carpet. |
| | #87 (permalink) |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: Mumbai, India
| @saildrive: Go to Car Spa at Inorbit Mall parking lot in Goregaon. They will dry and clean your carpets, whilst still in the car, and charge you 300 bucks. It will take 1.5 hours though, so please plan your visit.
__________________ We do what we have to do in order to do what we want to do. |
| | #88 (permalink) |
| BHPian Join Date: Feb 2005 Location: Loveland, OH (cincinnati area), jabalpur, chennai
| should a new car immediately undergo a wax treatment? are there any other things that can be considered? ( I was offered valuguard car protection for 700 odd dollars).
__________________ ______________________________________ with great power, comes great responsibility. bigger the car, longer the cleaning time. |
| | #89 (permalink) |
| BHPian Join Date: Dec 2006 Location: Kolkata
| I also have a problem of wet carpet due to heavy rains in Kolkata. What I did is : took a Scotch Brite sponge mop (the one used for cleaning kitchen slabs etc) - its very absorbent. squeezed out as much water as i can. removed the plastic moldings inside the car near the door that holds the carpet in place. lifted the carpets as much as possible. soaked the water underneath. then got my vacuum cleaner fitted inside the car in such way that it blows the hot air towards the wet areas. the outlet air of the vacuum cleaner is quite hot. run the vacuum cleaner whole day long with a gap of 15minutes after every 1 hour. my car is almost dry now thanks to the sunlight and my vacuum cleaner. however if you have a wet/dry type vacuum cleaner - you can suck the water out with minimum effort - then you can fix a table fan inside the car while keeping the car in the sun. this will certainly help. Ported_head wrote: "@saildrive: Go to Car Spa at Inorbit Mall parking lot in Goregaon. They will dry and clean your carpets, whilst still in the car, and charge you 300 bucks. It will take 1.5 hours though, so please plan your visit." Anyways is there any such facility in kolkata? Anybody knows? Also how much should it cost to replace all the door gaskets of a Zen? _______ Arup |
| | #90 (permalink) | |
| Quote:
i don't think new cars have any protective films on them. i have to get is as soon as i can, if required. luckily i fall in extremely lucky types . my other car is pathetic though (black).
__________________ ______________________________________ with great power, comes great responsibility. bigger the car, longer the cleaning time. | |
| Thread Tools | |
Similar Threads | ||||
| An Article From Economictimes (Investor Guide) About Car | finetuning | The Indian Car Scene | 16 | 31st August 2009 17:22 |
| ARTICLE: The Team-BHP Guide to BASIC Car Audio | navin | On modifying a car | 25 | 24th August 2008 13:21 |
| ARTICLE: The Team-BHP Guide to ADVANCED Car Audio | navin | On modifying a car | 23 | 2nd December 2007 10:55 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608
