Go Back   Team-BHP > Team-BHP > Team-BHP Advice > On owning a car
Old 1st July 2017, 12:14   #466
sudev's Avatar
Thanked: 1,988 Times
No wax on glass ever! I'd say you found the culprit
sudev is offline   (1) Thanks Reply With Quote
Old 1st July 2017, 13:52   #467
Thad E Ginathom's Avatar
Thanked: 6,872 Times
Default Re: ARTICLE: Safe Driving in the Rains
Clean/polish your glass with a cream glass polish, not just a regular liquid cleaner. I've been usiong Auto-Glym since for ever. I just got some CarPro CeriGlass, which, if used on a polishing machine, will actually take out small faults from the glass. ...
Service centre just polished my windscreen. It was mutually accepted that it probably would not get rid of a large stone chip (so, in some ways a waste of money) but, apart from that... wow, it is clean and smooth!
Sadly, Chennai is seriously lacking in rain for real-life testing just now.
Old 2nd July 2017, 21:37   #468
Thanked: 83 Times
Originally Posted by sumeethaldankar View Post
Unfortunately the problem came right back the next day (night actually). The Sonax does help a bit. It clear's the effect fast while driving than before but I am unable to pin point the root cause. I have been using Formula 1 wash and wax to wax the car and use it on the glass as well. I had used it last 1-2 months ago. Can this application cause the haze effect ?
Any wax will cause the haze. I used the Proklear glass treatment two monsoons ago. Nice beads of water that fly off the windscreen at high speeds, almost no need to use wipers -- fine. But haze after wiper blade does its job-- no good ! Disappears instantly, but still irritating. In your case it can be either Proklear or the Formula 1 wax, I think ! The lesson I learnt is to simply drop a piece of body soap (the last bit you cannot use) into the washer fluid tank -- free and does the job adequately !
SnakemanJohny is offline   (1) Thanks Reply With Quote
Old 2nd July 2017, 23:40   #469
Hmm... so now I have a windscreen which is mostly not too bad. A perfect test bed! so I can try out one of "nano" glass treatments. If it is good, then do the same on the new screen, whenever that happens.
Old 26th July 2017, 01:54   #470
Tgo
Tgo's Avatar
Thanked: 256 Times
Default Re: ARTICLE: Safe Driving in the Rains - Stray Cattle
Wanted to add a phenomenon related to cattle observed in parts of Rajasthan, UP and MP during rains.
While travelling in rains during rains, I've seen a lot of stray (let loose/orphaned) cattle sitting on the roads. This becomes specially dangerous in the dusk/night when the 'holy' obstruction is invisible till it comes within the headlight spread, leaving very little reaction time for corrective measures.
-Cattle Logic-
They prefer sitting on the dry sections of the roads where mud/slush and insects don't trouble them and constant traffic wafts these bugs away from time to time.
Tgo is offline   (1) Thanks Reply With Quote
ARTICLE: Guidelines & Tips for Safe NIGHT Driving GTO On owning a car 121 22nd June 2017 17:14
ARTICLE: Safe Driving on Indian Highways & Ghats GTO On owning a car 277 12th February 2017 13:16
ARTICLE: Guidelines & Tips for Safe Driving in FOG SS-Traveller On owning a car 68 7th June 2016 15:52
Driving in the Rains - Tips normally_crazy Technical Stuff 210 20th April 2010 19:17
