| On owning a car Help articles related to owning a car |
| | Thread Tools |
| | #121 (permalink) | |
| BHPian Join Date: Sep 2007 Location: Bombay
| Quote:
The visibility drops to ZERO. ![]() ![]()
__________________
| | #122 (permalink) | |
| BHPian Join Date: Oct 2008 Location: Bangalore
| Quote:
![]() EDIT: @supercars, the visibility reduces only if you have not completely rubbed out the soap. I had no problems with this across 4 monsoons. It is a tedious process, however. Last edited by Roy.S : 19th July 2009 at 20:55. | |
| | #123 (permalink) |
| Senior - BHPian Join Date: Aug 2008 Location: Bangalore
| He might even rear-end your car if he's following close (bumper to bumper) if you suddenly step on the brakes.
__________________ Maruti Suzuki Alto (May 08) - 23,000 KMS Hyundai Santro (Feb 05) - 59,000 KMS Last edited by gpa : 19th July 2009 at 21:02. |
| | #124 (permalink) |
| I thing he mentioned about rubbing liquid soap till it disappears and the glass is clear so as to not leave the thin film that you are referring to.
__________________ Maruti Suzuki Alto (May 08) - 23,000 KMS Hyundai Santro (Feb 05) - 59,000 KMS |
| | #125 (permalink) |
| Post deleted by the Team-BHP Support : Please do NOT SPAM the forum. One-liners that add absolutely no value to the thread are strictly prohibited on Team-BHP. We advise you to visit our board rules section before proceeding any further.
__________________ Maruti Suzuki Alto (May 08) - 23,000 KMS Hyundai Santro (Feb 05) - 59,000 KMS Last edited by GTO : 22nd July 2009 at 11:13. |
| | #126 (permalink) |
| BHPian | Most of us already know this. Cold air has less capacity to hold moisture. So if temprature is low outside, the temperature of the window glass will be low (even on the inside). This results in the cooler air near the glass (inside). As a result of cooling of air, its capacity to hold moisture reduces. The balance of the moisture is what we see as mist (inside). Try pouring cold water in a steel vessel on a hot day, you will notice mist on the outside of the vessel. Last edited by fi.robin : 21st July 2009 at 22:50. |
| | #127 (permalink) | |
| Team-BHP Support ![]() | A member NSK123 dropped this useful note by us: Quote:
__________________ GTO Work backward from your imagination, not forward from the past!
| | #128 (permalink) |
| Senior - BHPian Join Date: May 2007 Location: Vadodara
| I dont know if they are discussed before this or not. If yes, mods, delete this post. 1) Lights : Rather than having 100W headlamps with poor focusing, its better to have 65W but with proper focusing. Get this done in your presence. Anyother thing and you will end up in a tizzy. 2) Wiper Blades : I think Bosch has a wide range. I suggest two sets, a) Standard set : The set that came as standard with the car. b) A seperate set of better wiper blades. During monsoon, change the standard set to better wiper blades. As soon as monsoon is over, take out the set of better wiper blades, pack them in plastic bag, and store them. Put back the standard set. This helps us by having a normal set that is just about OK for driving in seasons other than monsoon and we have a separate set for monsoon. This way one need not change the blades every two years or so. Both 1) and 2) in our Baleno are quite useless. Came to know about their shortcomings in recent expresshighway drive where it was raining like hell. Bulbs are 60W but poor focusing means they are useless.
__________________ Never Dream because broken dreams hurt the most.There is no market for emotions. EVENTUALLY FATE DECIDES EVERYTHING. |
| | #130 (permalink) | |
| Quote:
Suppose I install Bosch wiper blades and then dont change them after monsoon. Then after the summer season, the wiper blades are rendered useless due to intense heat. Rather than letting this happen, I will put in the older standard set to let it be there for summers. If with this little job I am able to extract maximum life out of wiper blades, why not ? And its pleasure to work on the car too. Now comes the main reason. Finding Bosch wiper blades. For me its tough. I mentioned this name at MASS ( Kiran Motors ) and reply to me was " There is nothing like Bosch wiper blades ". Was cursing that guy all the way on NE-1. Other problem is getting fake parts. May be this is applicable to me as I want minimum wastage and I dont have to worry every year.
__________________ Never Dream because broken dreams hurt the most.There is no market for emotions. EVENTUALLY FATE DECIDES EVERYTHING. | |
| | #131 (permalink) |
| Team-BHP Support ![]() | @aaggoswami, are you simply defending your earlier statement or really mean what you wrote. And just for the record, it takes 2 minutes to change a wiper blade. Esp those with bosch locking mechanism.
__________________ Ever catch yourself listening to a nice song on the radio and dedicating it to your car. |
| | #132 (permalink) | |
| Quote:
This is not a very developed place as far as automotive knowledge goes. A kid standing on front seat and father is driving car, a kid in lap, kid playing lose in the car with the parent driving, so now you get extent. I am tired of bad quality parts. M800 wiper blades installed two months ago are now not useful. Even highly educated persons dont know what is high beam and low beam, and most of the time they are driving with high beams on. I have posted what I am now doing and I think it is the best solution for me. You can get three range of Amaron batteries of same capacity but warranty and cost are different. Apparently fake products are a lot in this city. The day MASS told me about Bosch wiper blades, I was shocked. If its my mistake, I would readily accept it. We will now have two set of wiper blades for each car.
| | #133 (permalink) | ||
| BHPian Join Date: Oct 2004 Location: Mumbai
| Quote:
![]() A very simple solution exists to warn the vehicles behind you, instead of using the Hazard lights. Just switch on the headlights or the parking lights. Because with that, the tails lights get switched on too, and that really helps. (I have seen some idiots driving in tunnels or other poor visibility situations without headlights because they can see the road in front of them clearly, but without realizing that the vehicles behind them do not see them clearly. Also I guess, some of them are trying conserve on fuel! The virus also has spread to Mumbai-Pune expressway tunnels). This ridiculous practice exists perhaps only in India. If one tried it in other places, the driver would be give a ticket. I have not seen any traffic authority ever trying to discourage such practices.
__________________ none | ||
| | #134 (permalink) |
| BHPian Join Date: Oct 2008 Location: INDIA
| Last week during a Very Heavy Rain in the hilly highway near koothattukulam(MC Road,kerala) around 20:00hours visibility levels stooped very low despite having 100/90 headlamps.I wonder whether a Fog lamp will help in such scenario much?moreover ,parking is not an option in those parts of MC road.I have never experience such a heavy rain BTW!. All cars and other vehicles uses Hazard Lights since it was the only option to be seen by other vehicles!
__________________ Get GNU/Linux ever learning procedure of becoming a defensive driver. |
| | #135 (permalink) |
| Senior - BHPian Join Date: Jun 2007 Location: Chennai
| A rear fog lamp should be of very high intensity compared to hazard lights --- and a big nuisance to follow in ordinary visibility. Of course, people should be driving at a speed where they can stop within their visibilty, even if that means crawling, but I guess that is too much to ask. |
« ARTICLE: Resale Value - The Silent Killer
ARTICLE: What to do if you are stuck with a lemon (Defective car) »
| Thread Tools | |
Similar Threads | ||||
| Safe Driving | throttleking | Street Experiences | 19 | 19th August 2009 23:08 |
| Driving in the Rains - Tips | normally_crazy | Technical Stuff | 204 | 11th August 2009 11:43 |
| Safe driving: 10 deadly mistakes | navin | The Team-BHP Meet Section | 0 | 10th December 2008 11:49 |
| Tips for driving throguh rains !!! | funkydevil | Street and Travel Experiences | 1 | 5th June 2008 20:09 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
