Go Back   Team-BHP > Indian Cars > Vintage Cars & Classics in India > Post-1950
Post-1950 Vintage Cars & Classics from year 1950 onward.
Thread Tools
Old 23rd February 2008, 18:31   #166 (permalink)
Cyrus43's Avatar
ok guys...after a LONG hibernation im bak...comps working again...
this is how the car looks like--
Note from Mod: Cyrus, this is your last warning. Avoid...typing...like...this, and recheck the post for typos/SMS before posting
__________________
Street Tech Performance.
Last edited by Rehaan : 24th February 2008 at 00:40. Reason: Please see note in post.
Cyrus43 is online now   Reply With Quote
Old 25th February 2008, 20:17   #167 (permalink)
Hello Anirban - on brakes, it is the TVS Girling. The front wheel cylinders had leaked off completely. The hoses were not OEM so were expanding under pressure (poor Bawaji must have been taken for a BAKRA by his garage for years, sob sob, same old story for me, nothing new).
I have also replaced the accelerator pedal (no silly play and stickiness now). Yesterday I replaced the carburettor. Threw away the choke plate (it has a nasty habit of closing at the most in\opportune times). The carburettor was leaking (which one does'nt) so fitted the Bicsa (a-la the 5507 sale). Threw away the dynamo (Karl - it was not working at all, the armature had burnt, even the mounting threads had disintegrated, it was just hanging in there, otherwise I would have just given it to you for some long awaited "concours" of yours), and fitted an alternator. Just cutoff all the silly and dirty wiring. Threw away non-working horns. Replaced battery terminals. Fitted a brand new battery. There was no battery bracket, which was organised in 5 minutes. It took me just 30 minutes to get the complete electricals sorted out. The headlights now work better. I don't think these headlights ever worked like this. I now have to go to my trademark 140 watts daylight, which I will do shortly. Adjusted the steering play once again, aligned the steering wheel etc.
Now next in line - radiator. I will use the same radiator but I will overhaul it completely with hose connections suitable for non-AC application. Then the suspension and then tyres. The suspension on this car is soooooo funny. Oversize control arm on RH side, standard control arm on LH side. 20 mm shims on RH side. No shims on LH side. You must see the nonsensical handling to believe it.To garage owners - BAKRA banao lekin koi limit to rakho !
Now BLB1144 has started moving. Water from the tailpipe is a foregone conclusion. I will fit the Mikuni and see how it works but for that I have to fit a fuel return line, which I will do shortly.
Whew !
Best regards,
Behram Dhabhar
DHABHAR.BEHRAM is offline   Reply With Quote
Old 25th February 2008, 22:02   #168 (permalink)
Cyrus43's Avatar
the car still doesnt move...try to take a flyover in 4th..it just refuses...and it does natak even it third...
RUBBISH...there are no headlights in this car...there are reflectors with candels in them...
and the steering wheel is still not alligned...
Whew !
Best regards,
Behram Dhabhar[/quote]
hope the mikuni comes soon...this car DOES NOT go the way 5507 used to...that thing was a rocket..too bad that engined got ruined...
__________________
Cyrus43 is online now   Reply With Quote Received Infraction
Old 25th February 2008, 22:06   #169 (permalink)
1100D's Avatar
Same story everywhere. Even on our car we found the right side coil spring having an extra turn welded to the coil spring, the left side had an oversized lower arm.
Since I was taking my time-off to oversee the suspension assembly, I could note what had been taken off our car. This was in 2005. Convincing the mech about going my way was a mommoth task. He says all these engineering principles works in showroom cars not cars that have sustained abuse over time, just told him, it does not work because he does not have a level floor anywhere within his garage. Few days later took Dad's vintage theodolite and bubble level to prove to him. He was like completely bonkers.
He did the change and the car was slanting to one side, and was pointing it to me, told him , that I will give him the feedback once the thing comes back home, where it showed perfectly level.
Speaking of it, I havn't found any single garage where you have qualified mechanics as well as level flooring in Kolkata.
__________________
________________________
Every Ferrari is always a Fiat
1100D is offline   Reply With Quote
Old 25th February 2008, 22:36   #170 (permalink)
1100D's Avatar
Panel behind the front bumper, did it ever come out of the factory like that?
__________________
Old 25th February 2008, 22:50   #171 (permalink)
Cyrus43's Avatar
no it is not original..the front panel either came with 12 holes all vertical oval shaped thingies..or it was just normal with no holes...
__________________
Old 25th February 2008, 23:14   #172 (permalink)
Stanher's Avatar
I have seen it on a few early/mid 80s fiats.....mightve been some accessory fitting....'can be seen on this one (although there seem to be 2 cars used!) in this song (at 00:54):
Stanher is offline   Reply With Quote
Old 26th February 2008, 22:16   #173 (permalink)
1100D's Avatar
Correction: Horizontal.
__________________
Old 26th February 2008, 23:41   #174 (permalink)
Stanher's Avatar
If you mean the holes as in the 137D/S1, correction again: they are neither vertical nor horizontal- they are more like the start and stop boxes in flowcharts (sounds simpler when you relate it to computer lingo these days, doesnt it? )
Old 27th February 2008, 12:41   #175 (permalink)
Cyrus, BLB1144 has an idiotic fan which is so big that it must be reducing engine power drastically. There is a lot of driveline friction also which we need to eliminate, tyres included.
Dad
Old 28th February 2008, 17:24   #176 (permalink)
Behram/Cyrus- dont know if uve thought but you could use 1144 front doors for LHD to give it the period look.
kavesh55 is offline   Reply With Quote
Old 28th February 2008, 18:01   #177 (permalink)
karlosdeville's Avatar
Whats different in the doors Kavesh? Do you mean the quarter windows? They could be fitted seperately.
__________________
( O \ | / O )
karlosdeville is online now   Reply With Quote
Old 28th February 2008, 18:12   #178 (permalink)
I have no love lost for quarter windows. If I feel like it, I will do it. But Ksvesh's idea is good. My RTO fellow told me that it MAY BE possible that I get the MH01 number on Saturday. I am keeping my fingers crossed. Let's see.
Best regards,
Behram Dhabhar
Old 28th February 2008, 18:40   #179 (permalink)
CBD
Best regards,
Behram Dhabhar
hope you get the number soon and hope that the work on the car starts soon.
you should consider your sons idea about the red and black twins though.
CBD is offline   Reply With Quote
Old 3rd March 2008, 12:00   #180 (permalink)
BLB1144 update:
On BLB1144, I have now changed the timing chain and sprockets, fitted a non-A/C radiator with new hose pipes and all new hose clips, a new water pump, a new "normal production" 4 bladed fan from excel auto, a new water pump pulley. As it was an eyesore, I removed the "silly" wheel caps and threw them out (sorry Karl - they were all damaged). I also added protective plastic hub caps on the wheels to protect the wheel bearings from dust and water ingress. I also changed the two rear tyres. After doing all this work, the engine started on just half a crank, indicating that the timing chain assembly procedure was correct (most people do not know the process, it is quite confusing, so if anybody wants it, please ask. If not done properly, power will not come). The engine makes "normal" sounds now instead of the silly grinding and humming sound which previously came from the worn out water pump and the huge fan. The car accelerates better too.
Guess what ? I picked up a beautiful and totally undamaged aluminium grille for a pittance and fitted it too.
Next in line - front suspension of course. All in a day's work !
Best regards,
Behram Dhabhar
Thread Tools
Indica tilts to the left on engaging hand brake triedeverything Technical Stuff 8 10th July 2009 10:34
Tata Safari Left Hand Drive Spotted. tush The Indian Car Scene 8 23rd June 2009 12:01
Left Hand Drive GreenHex The Indian Car Scene 41 25th May 2009 14:51
Left Hand Drive Cars sunilgee Vintage Cars & Classics in India 3 1st April 2009 16:26
Left Hand Drive Tata Sierra..(sorry no pics) SRK Modifications & Accessories 19 31st January 2009 01:17
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599
