| Post-1950 Vintage Cars & Classics from year 1950 onward. |
| | Thread Tools |
| | #62 (permalink) |
| Senior - BHPian | Pls find some more pics added. Side view. ![]() Front view, see where the spare tyre sits, damn neat. The front dicky is actually very useful. i can have 2 family size suitcases and still a lot more than i felt could go into it. Guys these pics were taken when i didnt have the original bumpers. I got hold of them only 3 yrs later since i had the car. ![]() The engine room has some mods after this pics, the delco has given way for technologically advanced CDI and the Austin air filter gives way for the original VW Fuel filter. ![]() The interiors are basic on the original seat frames for the 1967 model. Gone in for Grey shade as they complemented well with the outer color. Planning to change the upholstery some time by mid 2009. Reason: patterns on seat are not original. ![]() This guy can easily seat 5 adults. Space may look less but has better leg and head room than a Wagon-R.
__________________ Save Money today for a Better Car Restoration Tomorrow ...:) |
| | #63 (permalink) |
| Senior - BHPian | These are some latest pics. ![]() The all round body beadings are hand made. ![]() Anything more on this thread, any specific questions or request pls put them on i'll still continue. cheers: Need to wash and wax my car for tomorrows event. Bye for now guys.
| | #65 (permalink) | |
| Senior - BHPian | Quote:
but these non-original bumpers that you had look like Fiat 1100 ones....do you still have them lying around? Incidentally, your car just happened to remind me of a Beetle in similar colour (although I'm afraid Ive no idea what model) an Indian friend of ours had in the US when we were there for a year in the 80s...I have a very faint memory of having a ride in it (I was only 4 or 5 then! )....Oh and yes a 60s (though I'd prefer an even older one) beetle has definitely been in my list of dream cars! ![]() | |
| | #68 (permalink) |
| Senior - BHPian | Thank you Khanak and Stanher. Just back from our 1st year anniversary Rally -Flagged off by Mr Andrea Prinz(CEO VW) who was here from Germany. Great Drive. Will post some pics very soon.
| | #69 (permalink) |
| Senior - BHPian | Guys Want to let you guys know that this Bug has been running continously since the rally and suddenly i've started to feel much comfortable in this than any other car at home. This fella has been decent enough on the mileage also and i feel that the engine has just opened up now. Bangalore Beetle Club has done a lot to these cars. Its got the respect its due for.
| | #70 (permalink) |
| BHPian Join Date: Oct 2007 Location: Bangalore
| Pavan, Great job on your car. Good to see u & car at the rally. One comment on your rear suspension -- where you're replaced the torsion bar suspension with a coil suspension. One of the advantages of the torsion bar is that it is a progressive spring. The linear coil spring that you have (progressive ones are avail too) necessitates the extreme camber your car has on the rear wheel. Even with torsion bars, the pre-68 VWs (pre-IRS) were susceptible to tuck-in of the rear suspension under certain conditions. The extreme static camber your car has makes it even more possible. Going back to torsion bar or using a progressive coil spring would be better. Byas |
| | #72 (permalink) |
| BHPian | Raghavendra, If you remember (in the BBC rally), I asked you about the angle of your rear wheels ie., they are a little slant and not perpendicular to the ground. Will going in for torsion bar\progressive coils fix this as well apart from camber?
__________________ Cheers Santhosh |
| | #73 (permalink) |
| That angle is the camber. +ive camber is when the top of the wheel extends outwards and -ive camber is when it protrudes inwards from the car centerline. The swing axles beetles should have some I think 1-2deg of +ive camber and the IRS has 1-1.5deg -ive camber in stock settings. Byas |
| | #74 (permalink) |
| Senior - BHPian | Byas and Santosh. There's a 3 cm +ve camber on my car on the LHS, This i am not able to find time to set it right. Since everyone's now behind my back i am getting the camber set exactly as the RHS. Probably next time you guys see my car, all will be well by then. And about the Heat ranges for the VW Spark plugs i am still on search for these. But mico plugs dont work well with Beetles as per my 12000 kms report. The best set of Plugs that's worked well for my car is: 1) 4 electrode Bosh plugs 2) Normal Denso plugs. Will put up the heat ranges in my next post.
| | #75 (permalink) |
| Senior - BHPian | Byas, Check this out. Hot or Cool Plugs, what does the heat range of a spark plug mean to your Beetle engine?[/FONT] The spark plugs’ heat range is an index of its capacity to dissipate thermal energy. The different characteristics of automotive engines regarding operating load, compression, engine speed, cooling, and fuel make it impossible to run all engines with a standard spark plug. The same spark plug may get very hot in one engine type, but may reach only a relatively low temperature in another. In the first case, the air-fuel mixture would ignite on the glowing parts of the spark plug projecting into the combustion chamber (pre-ignition) and, in the second case, the insulator tip would soon become so badly fouled by combustion deposits that misfiring would occur. To ensure that the plug runs between the desired temperatures, plugs with different heat capacities were developed. The so called “heat range”, which is assigned to each spark plug, is used to characterize these heat dissipation capacities. A plug with a lower heat range number (BOS-W7AC) indicates a cooler plug that quickly dissipates heat to the engine block and cooling system, while a higher code indicates a hotter plug that retains heat. By properly selecting the heat range of the plug, it ensures that the plug will operate between the plug’s designed operating range of 500-900 degrees Celsius. In this range, the spark plug will be self-cleaning, yet will not be hot enough to pre-ignite the air/fuel mixture. regards.
| Thread Tools | |
Similar Threads | ||||
| Yamaha RZR.. dream come true | DeepakMenon | Motorbikes | 14 | 7th July 2009 02:49 |
| Dream Come True - Our Dream Machine Safari Petrol 2.2 VTT @ 35,000kms | kdeepakk | Test-Drives & Initial Ownership Reports | 56 | 13th April 2009 13:20 |
| Alto - My Dream Comes True | Heman | Test-Drives & Initial Ownership Reports | 44 | 14th March 2009 15:55 |
| This Is Dream Comes True (Palio 1.6) | payam | Test-Drives & Initial Ownership Reports | 31 | 10th April 2008 19:58 |
| beetle 1966 restoration help needed | carbug | Post-1950 | 23 | 29th March 2008 20:52 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599
