| Post-1950 Vintage Cars & Classics from year 1950 onward. |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Oct 2007 Location: Bangalore
| Taking Santosh's suggestion, I've decided to move this to its own thread... My objective with the restoration is to return the car to period correct stock condition. I also try to actually fix as many of the parts as I can vs. replacing them. Sometimes it is cheaper to buy (perhaps even smarter), but I get greater satisfaction from getting the old part working (or looking better) -- this quirk does suck up a lot of time though, but that's just ok with me. (Though I forgo this on all safety related parts) ![]() I'll post in separte sections the different areas that I work on. Some may be repeats, but for the reference of other enthusiasts, I'll repost. Byas |
| | #2 (permalink) |
| Senior - BHPian Join Date: Jul 2007 Location: Bangalore\GOA
| i think this car has been posted on the forum sometime back not sure if its the same its the one with black convertible roof right? i remember seeing this car on road many times does it have any traces of rust on the body,i mean below the rear door or something?
__________________ I am a good bad boy |
| | #6 (permalink) |
| Senior - BHPian | We have lot many guys doing this in Bangalore. No 1 spot belongs to Vijayalakshmi No 2 spot belongs to Mr Naveed near J C Road. There are still so many guys out there who do a decent job, But you need to be very specific in getting your job done the way you want it, Not the way they want to do it. 100% of my car chromes were rechromes.
__________________ Save money today for a better car restoration tomorrow :)- Pavan Kadam |
| | #7 (permalink) |
| (with corrected links) Interior & Seat Upholstery: The seats are still clad in the original black basket weave upholstery and are rundown. Actually, the drivers side is really bad, but the other seats are tired, but “ok” (as in not torn). See picture below, which does show the full extent of the tear on the drivers seat. I also planned to paint the gear shift and e-brake handle. The door panels are also pretty worn with the door pocket elastic pretty stretched out, the panels are missing the vapor barrier behind it and missing many clips. The original floor covering is a combination of carpets around the edges with molded rubber floor mats over the front and rear. The one in the rear has broken up into 3 pieces, while the one in front is in better shape though still with some tears. The top and headliner need to be replaced, but I intend to do that last – once I get the car mechanically into shape. The speedo has dust inside and the switches/knobs have faded and the fan switch is missing. The convertible also has a special rear view mirror which has an interior light integrated and the mirror can be raised to get better view when the top is down. This has been missing since we got the car in 75. Pic of interior: ![]() The simple things to do were cleaning the switches, grab handles etc and then repainted the faded markings. Later on I was able to get new inserts with markings for the switches. I used the ones for the fresh air, but kept my painted ones for the headlights and wipers as they looked better. Switch knobs before/after: ![]() ![]() Grab handles before/after: ![]() I cleaned out the interior door panels, reglued them with 3M #77 spray, put in new elastic for the sagging side pockets, new door clips and seals, installed a vinyl vapor barrier with 3M #75 spray which gives a “post-it” like tackiness that allows the barrier to be removed an replaced without tearing (very useful product). I then moved on to seat covers. I wanted to get exact replacements so I called around. There seem to be only 2 manufacturers remaining TMI and Topline (Both in the US). However, since my beetle is a RHD Euro model, the seats are diff from the US ones where the seats had headrests starting in 68. So, I had to special order it. Santa brought me the replacement covers for Christmas. I started with the driver side seat: ![]() On pulling off the covers, I discovered that the frame/springs for the back rest on both front seats were broken and distorted. So I had to straighten out, find a welding shop and have welds put back in. ![]() I had not ordered replacement foam, so I intended to reuse the foam (actually a rubberized horsehair like material). On the seat bottoms, I used some burlap to prevent the springs from cutting into the foam and added some more foam using sheet foam. After some trial and error, they came out looking pretty good. For covers that only cost about $120 for a set, I think the results were great. While I had the seat apart, I took the opportunity to clean and repaint the adjsut mechanism and to install new plastic slider bushings, etc. Here's a pic of the interior with the new seats, painted gearshift & e-brake, redone door panels etc. ![]() Pic of the Dash ![]() Some other pics ![]() ![]() ![]() Byas |
| | #8 (permalink) |
| Distinguished - BHPian ![]() | Fantastic job my friend and a great car I might add. Looks like a 1975 Karmann Convertible with Fuel Injection. There should be a Karmann Badge on the front fender, which it has. These cars also came with only one tail pipe as against the customary Beetle twin pipes on either side. One question, was this bought from Bombay as it seems quite like the one I saw some time ago. If it is then I know whom you bought it from and also it had a lot off bird poo marks (acid) and paint drops on the red paint. Thank God you bought it and restored it to this level if it is that car. If not then anyways your work is commendable. This is what a car enthusiast is all about. Kudos brother.
__________________ W110-115-116-123-124-129-201 |
| | #9 (permalink) |
| V-16, Thanks! It's a '71 1302LS. The 75 (actually 73 on) would have had curved windshields. My father bought it thru STC from the first owner in 75 -- a german lady. I came back to India about a year and a half ago and took on this restoration in Oct 07. Color is the original Iberian Red (a repaint from several years ago I believe). Byas |
| | #12 (permalink) |
| Senior - BHPian | Excellent job,byas! Some TLC,and the car has come a long way with the interiors looking so much better. Good work,I must say! OT: Just a bit curious..Being from B'lore,I'm quite impressed with the neighborhood that you took the pics at. Looks quite a bit like the ones here in the US. |
| | #13 (permalink) |
| Team-BHP Support ![]() | @71Convertible: I have to admit that when I began reading this thread, I thought to myself - here's another DIY-enthu chap all set to work on an old family car, who's soon going to get bored, frustrated, give up and finally scrap the car. However, on reading the rest of the thread - it's clear you really are passionate about it! Excellent job, especially on the interiors - the restored car looks beautiful! Most people would hand the job over to a shop and have them work on it but putting your sweat & blood into it gives satisfaction like no other. |
| Thread Tools | |
Similar Threads | ||||
| My Used Cars Saga | ramzsys | Long-Term Ownership Reviews | 21 | 18th June 2009 10:41 |
| My VW Beetle Restoration-DREAM COME TRUE | PAVAN KADAM | Post-1950 | 156 | 1st June 2009 08:02 |
| The SAGA of Low_Bass_Makker | low_bass_makker | Sound Off and Show Off | 1400 | 5th January 2009 00:32 |
| beetle 1966 restoration help needed | carbug | Post-1950 | 23 | 29th March 2008 19:52 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552
Of course its a 71, your Handle suggests it!! Thats really dumb of me.
