Old 17th August 2012, 22:17   #31
Thanked: 54 Times
Default Re: Project Landmaster
Hi Bulldogji,
Now that the car is with the tinkerer, I can't treat the rust spots. After it comes from the tinkerer, I will do it. Can you tell me if I have to scrape the whole metal to treat the rust pits or what is the method to be used.
Thanks & Regards,
Jagadeesh
jagadeesh.b is offline   Reply With Quote
Old 17th August 2012, 23:30   #32
rajeev k's Avatar
Thanked: 1,750 Times
Originally Posted by jagadeesh.b View Post
Hi Rajeev In my case it did not happened. check out the below picture.
I have marked the size of the Landy/Amby original battery box in the first picture.
Why I say this is because the recessed shape, marked in dots, is outside the battery tray in Landy/Amby.
While diesel engines are mounted bigger batteries are needed and hence the mods. I am talking about those black hard rubber batteries.
rajeev k is offline   Reply With Quote
Old 18th August 2012, 13:29   #33
Thanked: 944 Times
Hi Jagadeesh, you will have to revert to bare metal, apply the rust inhibitor and then start the paint process. If you contact either 3M or wourth locally, they will send a technician across to advise. Well worth the effort to prevent agony at a later date. Your primer coats can be easily removed so I suggest you make the effort.
Bulldogji is offline   Reply With Quote
Old 22nd August 2012, 14:56   #34
rob_ox's Avatar
Thanked: 20 Times
The Gearbox’s in Landmasters & Ambassadors were the same but the Gearbox shield on Landmaster was of aluminum & that of OHV ambassadors Cast Iron.
Were the gearboxes the same until the final column change gearlever car? What year was this changed to a floor change?
The Rear Parcel Tray is available in market & we can also fabricate it.
Very interesting!
What other repair panels are available? e.g. bottom of door frames, floorpan where it meets the sills, Front cross-member, rear edge of front guard etc.
These parts can be fabricated here in NZ, but it is expensive because each one is custom built, but they do fit perfectly!
Regarding the Rear Differential it is the same as that of the earlier model Morris Oxford. the Indian Land \masters had the same body of 53-Morris Oxford but the engine(Side valve), gearbox & differential from the Earlier Model(Pre-53). Can you please upload the photos of your Rear Differential?
Hmm! That would explain why the Landmaster/Ambassador brake master cylinder does not include a hydraulic clutch bore too - the MO Oxford did not have this.
There are quite a few differences between the Landmaster and the series II Oxford. I am learning a lot - thank you
I have taken a couple of (not very good) photos - the diff/axle is a BMC "B" series, as used by MGA, Austin Cambridge A50-A60. This is handy as I am going to swap the crownwheel & pinion (4.875:1) for an A60 one (4.3:1) to reduce the engine revs at 'high' speed (60mph).
rob_ox is offline   Reply With Quote
My '57 Hindustan Landmaster Restoration. EDIT : Project complete. PICS on pg.11 JayD Post-War 218 7th August 2013 15:58
Wanted Landmaster Nandyk Shifting gears 6 22nd June 2010 00:22
A Fiat & Amby Landmaster: 2 perfect beauties found in Coimbatore Rtech Post-War 44 12th March 2010 23:46
Landmaster Project - Part II Steeroid Post-War 516 22nd June 2009 13:38
My Landmaster Project Steeroid Post-War 524 30th July 2008 23:27
