Old 27th December 2012, 20:59   #46
Thanked: 2,457 Times
Default re: Monster 1969 VW Beetle Restoration - EDIT : Delivered
Originally Posted by RandomUsername View Post
Sounds awesome
But, why is the rear engine tin missing? The hot air from under the engine should not come back into the engine bay. Make sure this piece and the rubber engine compartment seal are in place.
Thanks, the engine breast plate is missing right now since the A/C compressor is fitted and since the Belt runs through the plate, we have removed them, need to do a little modification on it to fit, but for sure we are fitting them.
Usuallly these Big Block engines are sent as Turn-key engines, its not that easy to start them, they come with loads of added extra's, The External Oil filter and the External Oil Cooler. The biggest problem we faced was the absence of the Plumbing for the same, They sadly never came with the kit and that left us to get them fabricated locally, smart as my mechanic is, we got it right in time before firing the engine and now the only thing pending to start the test run of the car is the Control Pedals, which should arrive via Jalopy Shop ( thebulletboy-Pankaj ) very soon.
The car is now with the A/C mechanic, expecting it to come back in couple of days.
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_1782.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_1784.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_1797.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_1798.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_1799.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_1800.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_1801.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_1802.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_1803.jpg
PAVAN KADAM is offline   (1) Thanks Reply With Quote
Old 4th January 2013, 23:45   #47
Air-conditioning work Done, Mechanicals 100% done, Now the car is at the electrician.
All the local and cheap wiring earlier now are ripped off and will make way for brand new wiring looms from FINOLEX.
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_1879.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_1880.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_1881.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_1882.jpg
Old 5th January 2013, 00:55   #48
Thanked: 1,503 Times
Tappets - CHECK
Timing - CHECK
Carb balancing - CHECK
Fuel pump - CHECK
Merry Christmas to all,enjoy the 150 hp monster
You beauty!
This one looks like real fun, Mr Pavan Kadam. Congratulations!
Steeroid is offline   (1) Thanks Reply With Quote
Old 6th January 2013, 19:19   #49
Ricky_63's Avatar
Thanked: 375 Times
That is one hell of a car ! Something that I have been imagining for a very long time....Sigh !!! Some day :-)
Ricky_63 is online now   (1) Thanks Reply With Quote
Old 7th January 2013, 12:31   #50
Ricky_63's Avatar
Thanked: 375 Times
One question. Can this engine take the Delhi summer at 47 degees centigrade without a problem ? Given that it is air-cooled.
Old 7th January 2013, 20:17   #51
Usually any Air-cooled VW's can take Delhi's 47 Degrees without a hitch, only thing is, it has to be Tuned well, more-over this particular engine has an external oil cooler placed under the car with an active Fan running all the time, so we will not have any issues to say.
Some more updates as on date.
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_1966.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_1968.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_1977.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_1978.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_1980.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_1982.jpg
PAVAN KADAM is offline   (4) Thanks Reply With Quote
Old 17th January 2013, 22:32   #52
Time for the countdown, almost every aspect of this restoration is Re-Checked again.
Last bit of work
1) Carpeting
2) Ambient lighting
3) Detailing
Each work a day, so couple of days before the car gets delivered
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_2102.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_2103.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_2105.jpg
PAVAN KADAM is offline   (2) Thanks Reply With Quote
Old 17th January 2013, 23:06   #53
Thad E Ginathom's Avatar
Thanked: 7,196 Times
I just gave myself a "slide show," reviewing all the pictures from the beginning of the thread and the beginning of your work. Really amazing
Thad E Ginathom is offline   (1) Thanks Reply With Quote
Old 20th January 2013, 16:06   #54
More to follow in its final stages, keep watching this space.
Monster 1969 VW Beetle Restoration - EDIT : Delivered-img_1575.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-img_1577.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-img_1581.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-img_1582.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-img_1584.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-img_1576.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-img_1580.jpg
Old 25th January 2013, 19:07   #55
The car is finally D.E.L.I.V.E.R.E.D Errr...! infact Exchanged. My Beetle goes to his house and i get this home to do the initial Running-In
More to come tomorrow.
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_2219.jpg
Old 26th January 2013, 14:59   #56
SandyX's Avatar
Thanked: 531 Times
Lots of respect for you man. I've been following your builds ever-since i started visiting TBHP. I'm coming to you whenever my sleeper build is gonna start but as of now it's just in my wishlist.
Is this the engine kit you chose for the monster?
1183 Builder's Choice Engine Kits - 150 HP 2110cc
If so, is it an entirely new engine or a beef-up job on the original VW motor? Can it be fitted in some way on the bus?
Hope you could do something about that muffler hanging down at the back. And please do try black mudflaps too. Might look meaner. It's coming out really well. All the best.
SandyX is offline   (1) Thanks Reply With Quote
Old 27th January 2013, 11:10   #57
samsag12's Avatar
Thanked: 198 Times
I have been a silent admirer of this build & salute the perseverance of the Bugstop team to turn this Monster restoration bug into a Super Beetle.
To me each & every aspect of this car is a piece of art be it cosmetic work or mechanicals.
I am sure it will be putting a lot of cars to shame when it completes the Running in period.
Pavan ji another feather in your cap.
samsag12 is offline   (1) Thanks Reply With Quote
Old 27th January 2013, 13:15   #58
Thank you, And, We did not buy the Engine Kit...! We brought down the Whole engine, specs and pics mentioned in the previous page
Thank you Sagar, Here are some more whacky pics of this car.
Monster 1969 VW Beetle Restoration - EDIT : Delivered-img_1603.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-img_1605.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-img_1613.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-img_1624.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-img_1623.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-img_1608.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-img_1616.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-img_1614.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-img_1611.jpg
Old 27th January 2013, 22:58   #59
Default Re: Monster 1969 VW Beetle Restoration - EDIT : Delivered
Super.
Do you have any pics of the upholstery work being done?
Old 28th January 2013, 20:10   #60
Super.
Hmm... let me see, if i can dig out few for you.
Some more pics of the Monster in action today, put in 100 kms today, and the Car is Awesomely Amazing. Only thing thats a let down are the huge vibrations that travel through the chassis of the car from the Growling Engine.
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_2239.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_2240.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_2242.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_2243.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_2245.jpg
Monster 1969 VW Beetle Restoration - EDIT : Delivered-imag_2247.jpg
1970 VW Beetle Restoration - Delivered PAVAN KADAM Post-War 48 29th December 2013 12:17
1973 VW Super Beetle Monster Build off - Delivered PAVAN KADAM Post-War 67 7th January 2013 12:30
VW Beetle/1969 sunilgee Post-War 13 2nd August 2012 12:51
Ducati Monster 796 Vs Yamaha FZ1 EDIT - Bought A Red Monster shayne Superbikes & Imports 130 10th February 2012 15:40
Restoration of my father's 1969 honda c50 samhassnn Post-War 21 2nd May 2009 05:02
