Closed Thread
Old 22nd June 2008, 12:50   #211
Vid6639's Avatar
Thanked: 21,086 Times
Well if your planning on some serious stuff, you may as well do the damping now when the car's stripped. The whole roof, floor board, boot, doors, spare wheel well. That is if it's some serious high end stuff going in there.
You could use that damping spray (I think Wurth) which I think Mad monkey had done on his RS.
Vid6639 is offline
Old 22nd June 2008, 13:04   #212
Thanked: 1,642 Times
Originally Posted by low_bass_makker View Post
I would like to go with Sam Bhai opinion. I think the HU is far more than you require. If you are considering only the looks then don't spend on it.
Point taken. It looks killer, though. Can you suggest another HU that looks similar, then? I had one suggestion for a Becker Mexico, which looks retro enough but is BLACK. The interior of the car will be Deep Tan.
Like you mentioned that you need a stealth install. What all equipement you plan to install. For me a car audio setup must consist of the follow this will be considered to the bare minimum for me.
1) HU
2) Front components
3) Subwoofer
4) 4-ch amp
This is the minimuim I will recommend to anyone. So what is your catch.
All those will be there - except a heavy sub. No BOOM BOOM.
Thanks vid - I'll ask about this.
Steeroid is offline
Old 22nd June 2008, 13:06   #213
Sam Kapasi's Avatar
Thanked: 1,473 Times
About the damping: Spray or apply-on or sheets, even if you do not plan to get a killer ICE system, do it anyways.
It will make the car feel even more thunky and solid and will reduce noise levels in the cabin anyways.
Not to mention the wonders it will do for the sound.
Sam Kapasi is offline
Old 22nd June 2008, 13:34   #214
How about this?
Except for the Digital Display, it may fit nicely below the Landmaster dash?
Retrosound Model One Digital media receiver at Crutchfield.com
Steeroid is offline
Old 22nd June 2008, 14:29   #215
The Panasonic HU is available for about $500 on some sites.
My hunt for an alternative continues, with this one from Clarion. I dont quite like it, though:
Name:  Clarion WXZ468RMP.jpg
Steeroid is offline
Old 22nd June 2008, 14:35   #216
v12
v12's Avatar
Thanked: 4,083 Times
How about Becker ?
Becker Mexico Retro 7942 - Navigation / Car Navigation Radio - T-Online Shop
v12 is offline
Old 22nd June 2008, 14:41   #217
srijit's Avatar
Talking
Becker Mexico is about $1200+ right? But it really does look retro
Steer, why dont you do like this guy did?
srijit is offline
Old 22nd June 2008, 15:35   #218
Yes the Becker Mexico is expensive and wont go with the rest of the car.
Here's another I found, perfect for the Landy except for the Chevy label - I'm sure we can do something about that. EDIT: You can order with or without the Factory badges.
Concours Series USA-6 Vintage Car Radio .com
QUESTION: If I'm ordering from the site I need to specify whether the grounding will be Negative or Positive. Which one should I choose?
Steeroid is offline
Old 22nd June 2008, 16:32   #219
Bass&Trouble's Avatar
Thanked: 71 Times
Originally Posted by Steeroid View Post
Requirements:
1. SQ setup.
Originally Posted by Sam Kapasi View Post
If you just want 4 speakers and a nice HU to give you simple clean music, then don't waste your money on this. Just get a simple decent JVC, pioneer, blaupunkt etc HU.
Hey-lo!?! Gentleman wants an SQ system, and you guys are actually discouraging him? So what if the post isnt in the ICE section, we still have a reputation to live up to!
The Retrosound and Concours dont have cd player on-board. Need to connect a cd changer, or use a USB stick (Retrosound only)
All common Indian cars are negative ground. Dont know about your Landmaster. You can check by seeing which of the cables from the battery is grounded.
Is a used Panny valve HU fine?
Bass&Trouble is offline
Old 22nd June 2008, 16:34   #220
Should be fine - thats the one that will go with the vehicle BEST. No two ways about it - anything else will be a compromise.
BTW you can only get used Panny Valve HUs - they've allegedly stopped production of these so the only available ones are used.
Steeroid is offline
Old 22nd June 2008, 17:04   #221
That's it. You may have to change the bolt positions to accommodate Gypsy rim. Unless they've done that already.
Originally Posted by JayD View Post
Steer, instead of the conti rims, go for gypsy ones. They are a better match for this car.
Steeroid, Wouldn't the Conti steel rims be a little small for the Landmaster's wheel well? The Landie have 15" wheels where as the Conti wheels are only 13". If going for Conti wheels then a very high profile tyre would be required to fill those arches.
UPDATE: The car has been modified to a multi-PCD setup so yes it can take Gypsy wheels. They will take pics with Gypsy rims tomorrow.
So what about TYRES? Good old MRF Legend chalega?
Steeroid is offline
Old 22nd June 2008, 18:17   #222
karlosdeville's Avatar
Thanked: 8,839 Times
That paintjob is looking phenomenol. Im floored!
Why have the bootlid hinges been changed to the cheapie modern style thicker ones? If the originals were damaged, hunt for a used set they should be very easy to get.
karlosdeville is offline
Old 22nd June 2008, 18:34   #223
Wait for updated pics tomorrow. They've picked up a lot of original Landy spares, from what I hear. These pics are from Tuesday/Wednesday last.
Karlos can you try and find that crank-start hole cover on the bumper that was there on the original pic you sent me? If I'm not mistaken that is one of the pieces they havent been able to find.
We now have 3 engines - the current carbed Isuzu on it now, GTO's Isuzu and GB (on standby duty) and the super-smooth OHV engine and GB that it came with.
Please help me finish the paperwork so we can move towards getting it registered ASAP.
Steeroid is offline
Old 22nd June 2008, 19:05   #224
jkdas's Avatar
Thanked: 1,436 Times
There is a guy in Bangy who makes tyres for vintage cars. He has lots of cars too. Read about him in KF's magazine when I was on a flight to Bangy.
jkdas is offline
Old 22nd June 2008, 19:08   #225
His name is Pradeep Khanolkar. He will open up a treasure trove of spares - if only Rudra can give us some glossy prints of the MB ads for India. The guy is a Merc freak and has all of Rudra's ads cut out from newspapers /mags and framed all over his house.
Rudy give us some prints na - thats the only way to his heart.
Steeroid is offline
Closed Thread
My '57 Hindustan Landmaster Restoration. EDIT : Project complete. PICS on pg.11 JayD Post-War 218 7th August 2013 15:58
Project Landmaster jagadeesh.b Post-War 33 22nd August 2012 14:56
Wanted Landmaster Nandyk Shifting gears 6 22nd June 2010 00:22
A Fiat & Amby Landmaster: 2 perfect beauties found in Coimbatore Rtech Post-War 44 12th March 2010 23:46
Landmaster Project - Part II Steeroid Post-War 516 22nd June 2009 13:38
