Closed Thread
Old 22nd June 2008, 19:22   #226
greenhorn's Avatar
Thanked: 1,317 Times
about the ICE, We've been through something like this once , but it seems all the good stuff in that thread has been discussed here already
http://www.team-bhp.com/forum/ask-gu...tionality.html
If you dont want too much trouble, the blau London MP48 is kinda okay- will go with your tan interiors as well
Size:  57.5 KB</div>   <div style=
greenhorn is online now
Old 22nd June 2008, 20:07   #227
karlosdeville's Avatar
Thanked: 8,100 Times
Originally Posted by Steeroid View Post
Karlos can you try and find that crank-start hole cover on the bumper that was there on the original pic you sent me? If I'm not mistaken that is one of the pieces they havent been able to find.
Please help me finish the paperwork so we can move towards getting it registered ASAP.
Will definitely keep an eye out for that cover, though I have no leads at the moment.
Regarding the paperwork like I said earlier Im waiting just for you to give me the requisite address. Without that I cant do anything.
karlosdeville is offline
Old 22nd June 2008, 21:37   #228
Jaggu's Avatar
Thanked: 7,471 Times
Steer the car looks STUNNING!! Congratz, thats the bestest Bday Present for dad, the delay is now well justified.
Jaggu is online now
Old 22nd June 2008, 21:44   #229
Rudra Sen's Avatar
Thanked: 4,092 Times
UPDATE: The car has been modified to a multi-PCD setup so yes it can take Gypsy wheels. They will take pics with Gypsy rims tomorrow.
What exactly they've done to get this?
Rudra Sen is offline
Old 23rd June 2008, 04:51   #230
iraghava's Avatar
Thanked: 153 Times
I'll do some research on the best suited tyres & update here later today. What was the stock size anyway? Karl?? Even Imperial is fine.
iraghava is offline
Old 23rd June 2008, 09:09   #231
Mad Monkey's Avatar
Thanked: 308 Times
Originally Posted by vid6639 View Post
Well if your planning on some serious stuff, you may as well do the damping now when the car's stripped. The whole roof, floor board, boot, doors, spare wheel well. That is if it's some serious high end stuff going in there.
You could use that damping spray (I think Wurth) which I think Mad monkey had done on his RS.
I used WURTH sheets and ABRO underbody spray ....
used the underbod spray in the door panels and the boot as well ....
ABRO Industries Inc. : Product List
@steer. there is an ABRO Distributor in mumbai . let me know if you want his details.
Mad Monkey is offline
Old 23rd June 2008, 15:11   #232
rjstyles69's Avatar
Thanked: 789 Times
Steer is this your Landmaster by any chance ? Spotted it at Daniel's Auto Garage opp' Johnson Market today.
rjstyles69 is offline
Old 23rd June 2008, 16:03   #233
JayD's Avatar
Thanked: 1,996 Times
I don't think its his car, this one has a mysore regn. His should be pune reg right?
JayD is offline
Old 23rd June 2008, 17:19   #234
egangsta's Avatar
A car same as the one in the pic was for sale and i think it was in Auto Car India. Has the same rims. Cant say if its the same car.
egangsta is offline
Old 23rd June 2008, 17:45   #235
Thanked: 3,508 Times
I don't think so Riju. Steer's Landmaster is painted deep gloss Maroon.
Sankar is offline
Old 23rd June 2008, 18:39   #236
muneemmk's Avatar
Thanked: 17 Times
I Left my job at Toyota for rebuilding my car, even then it took 9 months and btw steer all the mods and work that went into your car till date have also been done to my car and for your info my car took 3 months to get painted from the "ready for painting setup"
After the work at Koyas Just Bring the Car down to Cochin, will assemble the rest from here, would be much more easier.
Just my openion and what power steering did you guys finalise for the car ? my car has rack and pinion from OHC and Power steering pump from Ford Escort
muneemmk is offline
Old 23rd June 2008, 21:05   #237
rjstyles69's Avatar
Thanked: 789 Times
This landmaster also looked like it was under restoration and sorry for going OT folks I was ignorant about the color on Steers landmaster. Sankar thanks for the correction regarding the color.
Peace and the discussion continues .
Old 24th June 2008, 01:14   #238
iraghava's Avatar
Thanked: 153 Times
Originally Posted by muneemmk View Post
My car has rack and pinion from OHC and Power steering pump from Ford Escort
Be careful with this rack, they are notorious for premature failures.
iraghava is offline
Old 24th June 2008, 02:05   #239
muneemmk's Avatar
Thanked: 17 Times
My Power Steering Haven't Failed ever since it got installed , although it's making weird noised now and then and slight vibrations . But the car which got fitted with the same thing just before mine drinks Power steering fluid like petrol it's rack got dismantled 8 times before that guy threw it away and got another one. Identified the problem as the rack has lost it's polish from bracing(to increase rack lenght) to decrease the turning radius.I was lucky as my Rack wasn't cut instead the Tie rod Arm's Length have been reduced. ! Phew......
Sorry but am i hijacking this thread ?
my car runs on 165 sized 15inchers on stock rims, forgot the profile.It's MRF. I am thinking about changing the PCD to that of Swift so that i can get a good pair of Alloys and better Tyre options. don't know weather it will foul with the wheel arches. but i would recommend against getting the PCD changed to Gypsy if Steer is thinking bout getting some classic looking alloys cause the alloys available for gypsy rims are extremely oversiezed for Amby's and Landos.
muneemmk is offline
Old 24th June 2008, 07:32   #240
You sure you want to do that. Because the Swift has a 4 bolt pattern instead of the Amby's 5 bolt patterns. Amby weighs more than the Swift, one stud less on each wheel might be a bad idea. Another important question - The original Amby wheels are they hub centric or lug centric?
Sankar is offline
Closed Thread
My '57 Hindustan Landmaster Restoration. EDIT : Project complete. PICS on pg.11 JayD Post-War 218 7th August 2013 15:58
Project Landmaster jagadeesh.b Post-War 33 22nd August 2012 14:56
Wanted Landmaster Nandyk Shifting gears 6 22nd June 2010 00:22
A Fiat & Amby Landmaster: 2 perfect beauties found in Coimbatore Rtech Post-War 44 12th March 2010 23:46
Landmaster Project - Part II Steeroid Post-War 516 22nd June 2009 13:38
