Closed Thread
Old 14th July 2008, 21:14   #406
karlosdeville's Avatar
Thanked: 8,812 Times
Those Jalwa horns (if they indeed are) were a knock off of the Japanese Mitsubas, which were in turn a knowck off of a Claxon model. They sound simply superb, and very period. They were available new in the 70s for a princely sum of 74 rupees. I paid around 500 I think for my set 5 years back. Get the red tops powdercoated, they will look stunning.
karlosdeville is offline
Old 14th July 2008, 21:43   #407
Thanked: 1,642 Times
Originally Posted by musicmanaman View Post
Why the petrol smell in the car? I too have this problem at times on my Amby Avigo.
I think it is a feature that we mistake for a bug.
Seriously, that Jalwa horn (thanks Quicksilver!) can make you jump out of your skin. JayD gave me the Jalwa treatment while I was directing the car into the parking lot at my apartment, and I was shocked.
Engine is running at a notch higher than 80 after the a/c fitment. Is this natural, or do I need to worry?
Steeroid is offline
Old 14th July 2008, 21:48   #408
Thanked: 17 Times
A notch higher than 80? You mean temperature?
I think we should redirect a bit of cold air to the engine from the AC then. What say?
speedzak is offline
Old 14th July 2008, 22:09   #409
Stanher's Avatar
Thanked: 1,694 Times
Am I glad I have 3 sets of them! :greedy:
500, whoa! I paid like 300 for the last one I bought at madras, first 2 I bought in bulk alongwith many other spares from the same cars, sneaked them away before he could chance to look at them and quote a price.....hehehe!
Stanher is offline
Old 14th July 2008, 22:12   #410
Thanked: 24 Times
My Avigo too gets above 80, on hot days, so your are not alone.
musicmanaman is offline
Old 15th July 2008, 10:44   #411
JayD's Avatar
Thanked: 2,008 Times
Was great to drive around town in igloo last night! Looks real menacing when seen with the lights on,and one almost expects two machine gun holding gangsters sticking out of the windows!
The Horn was freakin loud and was fun scaring most of the people on the road, even though we dont have a vid of it, the effect was kinda the same as this one
JayD is offline
Old 15th July 2008, 12:52   #412
muneemmk's Avatar
Thanked: 18 Times
Man somebody should upload a video of what this baby can do on the road. And Who has the formula for the paint that is currently on the car , what make and what clear coat went into this beauty ?
muneemmk is offline
Old 15th July 2008, 22:45   #413
JayD's Avatar
Update: The car is now in the workshop to get some issues fixed, stuff like, the rear right leaf, which needs a lil work, the Window winders all need to be reset, and a lil rattle there a little squeak here etc. The work will hopefully be done in two days.
Also, when the Ac is used, the car's temp goes up very fast to the danger level, what can be done to solve it?? The Radiator is the largest one possible, tho Nikki suggests we get a 4 core radiator fixed. Need to check that option out, any other suggestions??
JayD is offline
Old 15th July 2008, 22:55   #414
iraghava's Avatar
Thanked: 156 Times
Is she running a single fan or a dual fan setup? Are the fan(s) working properly? If it's a single fan setup is it a dual speed fan or a single speed one?
iraghava is offline
Old 15th July 2008, 22:56   #415
Thanked: 2,470 Times
Hey guys,
If the engine is done up recently, doesnt it require some more of a run-in, i think once it settles down later the temperature rising would not be of an issue.
The usual practice would be the condensor is fitted in front of the radiator, which anyways blocks direct air to the radiator.
I've seen a landy get an additional fan for the radiator as well as the condensor. Both fitted seperately and cooled seperately.
Sorry if i have quoted this wrongly, havent been able to peek into the engine room of Steers Landy.
PAVAN KADAM is offline
Old 15th July 2008, 23:02   #416
JayD's Avatar
She has a single Fan, and its working fine, IIRC, its a single speed one.
Hey guys,
Pavan, The engine is not new, so i dont think it needs to be run in. The eng is real smooth and powerful too.
Before the A/C was fitted, the temp was 80+/- 5, but now, after 5 mins of A/C use, it starts climbing to 120!!
The condensor is in front of the radiator, and yes it blocks the air to the radiator, we need to do something about the additional fan ASAP.
JayD is offline
Old 15th July 2008, 23:35   #417
bluestraveller's Avatar
it would also make sense to see if the temperature gauge is working properly. I'm not sure if its a new one.
bluestraveller is offline
Old 15th July 2008, 23:59   #418
JayD's Avatar
Its a brand new one alright, and it works correctly too.
JayD is offline
Old 16th July 2008, 00:12   #419
iraghava's Avatar
Thanked: 156 Times
That's the problem JD. The single speed fan is not enough to handle the temperature with the additional load of the A/C. She needs to either be fitted with dual fans or a dual-speed fan (if that can handle the load). Dual fans however, are much more effective & recommended.
iraghava is offline
Old 16th July 2008, 00:23   #420
Stanher's Avatar
Dual fans?? 'havent heard of these before! 'am curious to know what they look like- pics. anyone?
Stanher is offline
Closed Thread
My '57 Hindustan Landmaster Restoration. EDIT : Project complete. PICS on pg.11 JayD Post-War 218 7th August 2013 15:58
Project Landmaster jagadeesh.b Post-War 33 22nd August 2012 14:56
Wanted Landmaster Nandyk Shifting gears 6 22nd June 2010 00:22
A Fiat & Amby Landmaster: 2 perfect beauties found in Coimbatore Rtech Post-War 44 12th March 2010 23:46
Landmaster Project - Part II Steeroid Post-War 516 22nd June 2009 13:38
