Old 20th August 2010, 19:54   #346
Thanked: 2,470 Times
Originally Posted by 67Bug View Post
Mr PK have you by any chance raised the front and the rear suspensions of your bug as the height (both front and rear) seems to be more than what is normally should be?? Unless your wheel rims are not that of Original bug..
FRONT:
Stock, bought brand new suspension part including the torsion blades at the front. Only the shock absorber are from amby, It's new so maybe at its right height.
REAR
Almost everything is stock again, except for the suspension sway bar, i have used coil spring suspension. The camber is bit -ve at the rear, which will be done when i have time.
Originally Posted by ajay99 View Post
you are ""spot on"" in that observation. '
If it is original VW rims it will be having the VW logo embossed on the rims.just check for that.
Also the original german shock absorbers for front were FICHTELL-SACHS and the rear shocks were BOGE
I need to scrape the rims to answer your question, But i am not willing to do that.
I dont have that kind of money to get the German shocks, i am happy with the Indian one's. Thank you
The height is perfect, unless you guys are used to seeing some dropped down cars.
Also the tyres are radials and smaller, maybe that might look a bit different.
Old 20th August 2010, 21:27   #347
Thanked: 182 Times
FRONT:
REAR
What is your Tyre size? If it is radial (which is what it is) it should be 165 SR 15. If you have the original specs tyres and the original suspension with new leaf springs the distance between top of the tyre to the fender should be 6-8 inches (max) anything more than that will have a -ve impact on the cushioning of your car and may damage your suspension in the long run. Coil spring suspension was not a part of your model so avoid if you are planning to get it to originality. If you are unable to afford the original german shocks go for the Fiat ones they will fit fine and if still does not work there is a problem with your suspension as the height is way too different than what it should be and may also impact your chassis. Happy to lend you a front suspension as I have a spare one which I had bought for experimenting but never got time to do any.
67Bug is offline   Reply With Quote
Old 21st August 2010, 13:14   #348
Thanked: 982 Times
The front shocks(dampers) were changed from 1965 models and requires a mounting kit which consists of bushes,metal washers etc.you can use Koni or COFAP shock absorbers if you are looking for a cheaper alternative.I doubt whether fiat dampers will fit the front .
here are the pictures of the rear and front (second picture)shock absorbers
by they way are the german OE NOS shock absorbers really too expensive vis-a-vis indian ones??
ajay99 is offline   Reply With Quote
Old 25th August 2010, 22:23   #349
some more add-ons as on today.
I am loving it
Old 8th September 2010, 20:12   #350
Very funny to spot your own car on roads, unaware.........!
My bro had taken it out very early last Saturday morning, and i was surprised spot it by around 8pm near Jayanagar, driving around in heavy rains.
Also, i have a slight problem at hand, i have noticed the engine oil becoming thin once its old and hot, during this moments of driving,the engine starts sounding harsh during idle. But on normal speeds the engine noise becomes normal.
Need a correct grade engine oil now.
Old 8th September 2010, 20:24   #351
Thanked: 982 Times
Is the oil pressure warning light coming on when the engine is hot?
then your assumption is correct. You could use a more viscous oil like 20/50 instead of 20/40.
also you could use an VDO oil pressure gauge as an accessory fitment which lets you know the correct oil pressure .
Another thing you could use is a cylinder head temperature gauge(VDO) which comes with 2 types of sensors (dipstick and screw )
Old 8th September 2010, 20:43   #352
The engine temperature is normally OK , but the problem arises when.
1) The oil becomes old
2) Once the car runs more than 100 kms at a stretch on a single run, the engine noise becomes coarse, Also the oil thins.
Yes, you are correct, i need to use more viscous oil or maybe a thicker oil.
Old 10th September 2010, 21:06   #353
svsantosh's Avatar
Thanked: 1,444 Times
Raghav-aavare, why not try synthetic? Anyways, this car is for life in your case, might as well walk the mile to make it super smooth. At least the next rebuild will get delayed by double the normal period?
svsantosh is offline   Reply With Quote
Old 11th September 2010, 11:21   #354
Sir........!
I had used synthetic oil on the Bug during my last service.
VW Manual recommends oil change every 6 months or 3500 kms whichever is lesser
So the oil change interval of 6 months is mandatory irrespective of type of oil used. In that case, synthetic oil may last me double the time......... I am confused.....?
2 more months before i do my regular engine oil change.
Also will be replacing transmission oil ,, this time with a 140 grade Castrol.
Old 11th September 2010, 13:47   #355
Thanked: 982 Times
Sir........!
It is always better to use the prescribed oil,(not synthetic).
Also as far as possible try to use the same brand oil which you are using, unless the engine is rebuilt and filling it for first time
Old 11th September 2010, 20:18   #356
Thanked: 96 Times
Pavan,
Regarding your engine noise -- check your valve clearances and make sure they are within spec. Looser clearances become noisier as the oil heats up and thins.
BTW, The Quartz 7000 is a semi-synth -- a mix of synth and regular oil -- not a 100% synth.
B
71Convertible is offline   Reply With Quote
Old 11th September 2010, 20:31   #357
Originally Posted by 71Convertible View Post
Pavan,
B
Hi Byas,
Tappet settings done.
Pressure relief valves checked
Need to know what oil to use............?
Guide
After the oil change, my next set of work will be "Getting rid of those Scorpio door handles and replacing it with the Original Push Button type VW Door Handle"
Old 12th September 2010, 11:51   #358
Thanked: 96 Times
Castrol 20W50 or equivalent should be fine.
Look forward to those door handles.
B
Old 12th September 2010, 12:51   #359
B
Will check for 20W50 grade engine oil tomorrow. Thanks Byas.
Well, the door handles are with me, look at the attached pics
Also, Byas, I have the ORVM's, but the mounts are not available, and i dont know where to source them.
Old 12th September 2010, 21:04   #360
manishalive's Avatar
Thanked: 734 Times
Pawan,
Castrol is a very good brand, but how we are going to ensure that we get genuine and not fake. A question worth asking. I always try to buy oil at petrol pumps and use Shell. The logic is simple, they have bigger things to play with rather than small and slow moving goods like "Oil".
Secondly try to Look for API SJ or SL or SM service class oils. API SG and SH are kind of obselete.
Similarly for Diesel Engines API CI4, which is latest. CF4 and CH4 are normally available.
Newer classification have better oxidation protection, protection from high temperature engine deposits, foaming, acid formation, sludge control and rust and corrosion protection.
Restoration: 1967 Chevy Impala V8 Rustbucket PAVAN KADAM Post-War 109 4th September 2017 04:22
Restoration of MRF6466 - my 1967 Fiat 1100D DHABHAR.BEHRAM Post-War 152 10th April 2015 19:21
1967 VW SplitBus Restoration. EDIT : Delivered ! PAVAN KADAM Post-War 28 24th July 2014 15:19
My 1967 VW Fastback restoration- Destiny's Child PAVAN KADAM Post-War 13 18th January 2012 23:06
1967 Volkswagen Beetle-Build your own paper beetle Naren4140 Shifting gears 4 5th December 2009 05:16
