Old 2nd May 2011, 20:39   #511
Thanked: 2,459 Times
Default re: My 1967 1500cc VW Beetle - Restoration done
Some more work done today...
Old 2nd May 2011, 21:08   #512
IQBAL VEERJI's Avatar
Thanked: 282 Times
Hi Pavan, whitewall rubber lining of rear tyre is peeling off and the tyres are in bad shape ,are you planning to replace them?? Regards.
IQBAL VEERJI is offline   (1) Thanks Reply With Quote
Old 2nd May 2011, 21:19   #513
Sir..
They are White wall INSERTS... Actually fits very well on cross ply tyres and normal radial, but i have oversize Radials and the rear camber on my car is slightly Negative.... Once i set it right, the creases will set in.
Need to do that once my mechanic finds time.
Old 3rd May 2011, 18:54   #514
Default Re: My 1967 1500cc VW Beetle - Restoration done
Last bit of pending work getting done.
Very soon this Fellow will be hope, i am ecstatic
Old 4th May 2011, 09:02   #515
Thanked: 31 Times
Hey Kadam, the Beetle looks simpally perfect man! When time permits do show me this Beetle. I can feature it in Fifth Gear or Top Gear. You decide.
EARTHed is offline   (1) Thanks Reply With Quote
Old 4th May 2011, 09:47   #516
Dude... April is long gone,thank you for your compliments
Getting it polished today, hopefully the car will make it home today.
Do come over on a weekend
Old 4th May 2011, 21:40   #517
Looks like work on my car will never end
Only the Right door done yesterday, Left Door should have been done today, could not see since i got late at office....
Old 4th May 2011, 21:57   #518
Thanked: 282 Times
Sir..
Pavan ji, where you get these inserts and are they OK with radials and how they are stuck to the tyres , finnally HOW MUCH MONEY they cost each,Regards.....
Old 4th May 2011, 22:05   #519
The 15 inch white wall inserts costed Rs.2000/- for a set of 4.
They fit really well on cross ply and normal Radial tyres.
OTOH.... I have been trying to get the period looking Number plates for the car......Anyone can suggest me please...
Old 4th May 2011, 22:22   #520
Thanked: 282 Times
Boss,Where in mumbai cantyre job be done plss.? Period number plates are actually coming from bangalore ,as they say in mumbai, with IND and Halogram they are sold for 1200/- a set in mumbai.
IQBAL VEERJI is offline   Reply With Quote
Old 5th May 2011, 17:16   #521
inderpalgill's Avatar
Thanked: 34 Times
what is this white powder type of thing on the glass,is it for the new rubber too tight-holding the glass?
inderpalgill is offline   Reply With Quote
Old 5th May 2011, 20:16   #522
That is Talcum powder sirjee.
Actually its a good practice to clean off all the rubber parts on the car after every service with Talcum powder.
Finally after a FULL DAY of work on the car today, the Bug came home by evening to the joy of everyone at home.
Old 5th May 2011, 20:24   #523
Stanher's Avatar
Thanked: 1,545 Times
Wow, Pavan!! At last, she's home! 'looks absolutely awesome!! What a transformation! I yam lowwing itt!!
BTW, could you elaborate a bit on how Talcum powder is good for cleaning of the rubber parts? Does it remove oil/grease marks?
Stanher is offline   (1) Thanks Reply With Quote
Old 5th May 2011, 21:39   #524
samsag12's Avatar
Thanked: 200 Times
Congrats on the completion of the work Pavan ji. Bug's looking completely drool maal. Really like those eyelids on the head lamp. Hope now you find some time to help me out.
samsag12 is offline   (1) Thanks Reply With Quote
Old 6th May 2011, 00:04   #525
Well, the merits of using Talcum powder on rubber parts were precisly explained by someone somewhere here on the forum.....
Let me look up and post the link.
Sorry Sagar,
Work and resto's had taken too much of my time.
OK, will explain the Best and the easiest painting procedure.
Painting procedure on a SCRAPED Body Shell
1) Shine the metal on the body shell, you can also use paint remover liquid for deep cleaning.
2) Apply Etching primer on the scraped and dry surface, and let it dry overnite
3) Sand it with 1000 grit sand paper, only to get a smooth surface.
4) Check the body line and the body surface for undulations and dinges.
5) Apply 3M body filler to cover up only the undulations and later sand it down using may be 500 grit or lower as preferred by painter.
6) Once you are certain that the body surface and the body line is perfect, sand down the entire body shell with 1000 grit sand paper again.
7) Apply Dupont 888 or equivalent surfacer.
8) Sand it down with 2000 grit sand paper and again check for Undulations, if you see some, re-do step 5,6 & 7.
9) If you or your painter is sure, the body surface is good to go, check small spots and cover it up with Dupont Tube Patti and dull it with 2000 grit sand paper.
10) On the smooth surface, apply the base coat paint and dull it again using the smoothest sand paper available.
11) Clean the surface with Dupont Tac Cloth and start spraying final coats of paint.
12) Let it dry for the next GOOD 48 HOURS.....
13) If needed, use gloss rubbing compound and silicon polish to get the best finish
Hope this helps......
Restoration: 1967 Chevy Impala V8 Rustbucket PAVAN KADAM Post-War 109 4th September 2017 04:22
Restoration of MRF6466 - my 1967 Fiat 1100D DHABHAR.BEHRAM Post-War 152 10th April 2015 19:21
1967 VW SplitBus Restoration. EDIT : Delivered ! PAVAN KADAM Post-War 28 24th July 2014 15:19
My 1967 VW Fastback restoration- Destiny's Child PAVAN KADAM Post-War 13 18th January 2012 23:06
1967 Volkswagen Beetle-Build your own paper beetle Naren4140 Shifting gears 4 5th December 2009 05:16
