Old 30th March 2012, 13:02   #526
KkVaidya's Avatar
Thanked: 271 Times
Default re: Restored Fiats (Super Select & Others)
Originally Posted by Stanher View Post
He says the engine head has a hole in it, but apart from that it's mechanically fit.
This is a beautiful car & lucky one too being in original condition.
For the hole in the engine head, can you please throw some more light? I am surprised to read that for an engine "made in Italy"! Is that a hole he can see or just that he found out because of water leaking out?
KkVaidya is offline   Reply With Quote
Old 31st March 2012, 10:26   #527
Stanher's Avatar
Thanked: 1,672 Times
As per my friend, its a very small hole, not easy to spot it but some times small drops of water start leaking.
Earlier the mechanics used to block it by applying mseal on it.
Stanher is offline   Reply With Quote
Old 19th April 2012, 22:53   #528
voodoochild's Avatar
Thanked: 175 Times
Here is a lovely 56/57 dukkar that I haven't seen for years - moralfibre caught this picture the other day.
If I remember the glovebox had a nifty period radio fitted. And I love the number!
Saw the same car in Bavdhan, near the Nebula Bar & Restaurant. It seems to be owned by someone who lives there and also has a nice Padmini (couldn't identify model).
Noticed the stereo, but couldn't get a clean shot of it.
Incidentally, the centre light said Made in USA. Was this original on this model?
Cheers,
Rahul
voodoochild is offline   Reply With Quote
Old 20th April 2012, 09:44   #529
karlosdeville's Avatar
Thanked: 8,759 Times
The owner also has a 54/55 Millecento I think with a diesel engine. Maroon, MHJ regd.
The original centre light should be Altissimo, made in Italy, but many similar units are available.
karlosdeville is offline   Reply With Quote
Old 20th April 2012, 11:08   #530
moralfibre's Avatar
Thanked: 6,461 Times
MHJ 5403 is the registration number if I remember it right. I have a couple of pictures of the car when the owners son and his friends drove it to Goa.
Old 24th June 2012, 22:25   #531
Stanher's Avatar
A young (well even younger than me! ) friend of mine has this neat Fiat Millecento tucked away safely at his ancestral house in Secunderabad.
'hope to see her out of her hibernation (in a fit state) soon!
OK so finally the car has seen daylight! My friend was here again for a week and got the car out of the garage. Even helped him get the engine started up once with a borrowed battery.
Sounds fine. But the points, condensor and ignition coil (still the M'marelli one) need replacing.
Also the brakes are jammed, which my friend said he'd attend to when he's back in hyd. maybe in a month or two. By which time he plans to get her up and running for the Deccan Heritage show on 15th august.
Some detailed pics. of the interior...can make out the original (ivory?) colour of the steering wheel. Hubcaps safely stored inside!
Also what looks like an air-intake below the dash?
Old 25th June 2012, 10:46   #532
Thanked: 4,716 Times
Dear Shyam - hello after a long time. Please tell your friend who has the 3 slatted grille fiat to replace the fan belt before he starts the engine, the belt has inverted itself on the pulley. Also, be careful of M seal filled on the cylinder head near the front of the intake manifold, the water can leak from there. A little attention will prevent huge engine expense.
Best regards,
Behram Dhabhar
DHABHAR.BEHRAM is offline   (1) Thanks Reply With Quote
Old 25th June 2012, 11:44   #533
samsag12's Avatar
Thanked: 206 Times
Shyam bhai that Millecento looks very original & well preserved. Nice to hear that you were able to start the car. I am surprised to see a crank hole in the front bumper.
Also those wheel caps look mouthwatering
BTW i think that engine cover gasket is fitted in the wrong way, it should be the other way around. Anyways looking forward to further updates on this car.
samsag12 is offline   (1) Thanks Reply With Quote
Old 25th June 2012, 18:51   #534
Stanher's Avatar
Hello to you too sir, yes nice to hear from you after a long time!
Aah yes, I forgot- we did tell him the fanbelt needs to replaced too. Also I think so does the fan with an original metal one? Any solution to fix the M-sealed crack?
Aah yes, I forgot to mention the crank hole in the front bumper- you sure have keen eyes!
Actually I'm noticing it only now as in earlier pics. of the car, it had the front numberplate fitted there over the hole.
Yes the hubcaps are lovely...but not original to this model. But atleast they are still Fiat 1100...and best of all, dont have the holes through the center!
Engine cover gasket?? You mean the tappet cover?
Old 25th June 2012, 20:32   #535
samsag12's Avatar
Thanked: 206 Times
Indeed, caps look NOS, seems they were never fitted on the car, and yes i meant tappet cover gasket. Is it fitted the wrong way?
Old 25th June 2012, 21:35   #536
Stanher's Avatar
No I dont think so..have seen it fitted this way, with the filler cap pointing towards the radiator, in all old fiats (that I've come across) so far?
Old 25th June 2012, 21:49   #537
samsag12's Avatar
Thanked: 206 Times
I think you didn't get what i meant to say, i was referring to the tappet cover gasket( used between cover and engine head) and not tappet cover. Its jutting out from the edges hence asked about it.
Old 30th June 2012, 21:12   #538
anjan_c2007's Avatar
Thanked: 5,186 Times
A must see for all Fiat fans:
anjan_c2007 is online now   (3) Thanks Reply With Quote
Old 6th November 2012, 14:27   #539
Thanked: 396 Times
Default Re: Pics: Vintage & Classic cars in India
This one is a runner and is parked here most of the time.
Mods: Not sure if right thread, could not find a dedicated Fiats' thread!
regards,
Srinand.
srinand is offline   (3) Thanks Reply With Quote
Old 29th January 2013, 02:04   #540
manishalive's Avatar
Thanked: 728 Times
Posting these pictures of 1959 NSU Neckar which I saw at a museum in Mannheim Germany as would be of great interest to all, the car has arrived just a month back in the museum.
Very nice car and in good nick, tough probably refirbished but sympathetically or may be not. The curator for the same was not there :(.
The front view -
The placement of rear view mirror -
The Run in Decal -
The wheel and wheel cap -
The side repeater (note the two tone)
The Sun roof
The logo -
The Neccar and the Bosch centre light -
The carello head lamps-
The Dealer Plate -
manishalive is offline   (7) Thanks Reply With Quote
Restoration - 1963 Fiat 1100 Super Select karlosdeville Post-War 100 12th April 2018 12:46
My 1962 Fiat Super Select - the journey begins. SuperSelect Post-War 382 4th May 2017 20:00
1964 Fiat 1100 Super Select - A little makeover for her 50th Anniversary celebrations! dudesam24 Post-War 16 24th November 2016 12:30
Fiat Super Select sunilgee Post-War 9 5th January 2010 16:33
Bridgestone Select SUPER - Faridabad tsk13 Tyre & Alloy wheel Section 4 28th November 2009 20:18
