Old 13th September 2016, 23:02   #721
//M
//M's Avatar
Thanked: 9,087 Times
Default Re: Restored Fiats (Super Select & Others)
Saw this Fiat 1100 in Mumbai the other day.
//M is offline   (11) Thanks Reply With Quote
Old 17th September 2016, 13:05   #722
manishalive's Avatar
Thanked: 728 Times
Continuing on the discussion of the 1958/59 (?) Fiat Millecento
[*]Millecento badge (front and rear)[*]Boot lid handle 'L' shaped (from Elegant)[*]Fiat badge around ignition switch[*]Large 'drum' air cleaner[*]Cable operated starter[*]Maybe the Delloroto/Weber carb[/list]The premises are simple - it is assumed that the initial cars were closer in specification to the early home market cars. Going through various pictures uploaded in the past, we can see the following.
Continuing this discussion further - Karlos do you have any of these cars Chassis or engine number plates. This would help us identify the serial number breaks.
And I recently saw a car with millicento badge -
This had a cute looking front badge as well, never seen before -
But looking at the VIN plate, this one seems to be a Select -(Am I right here?) Cause the Engine no starts with PA.
I have a 59 Model which has a VIN plate engine no also starting with PA
So assuming, the millicento that I talk of is supposedly a Select. I was unable to check the RC book of the same.
Now coming back to Millicento check this -
This is a 58 Select, with the elegant type air filter. The tappet / rocker arm cover is the correct type with studs and collar on cover bolt holes.
The vin plate reads totally different
The engine number matches the plate.
Further the RC book - mentions a date of 23/05/1958.
Would this then mean this is a Millicento and not a select.
Awaiting for answers from the fiat gurus.
manishalive is offline   (2) Thanks Reply With Quote
Old 17th September 2016, 15:22   #723
Thanked: 982 Times
1958 means it is a Millicento and not a SELECT.
ajay99 is offline   Reply With Quote
Old 17th September 2016, 16:19   #724
Thanked: 728 Times
Ajay, thanks. So the blue car is definitely milicento and the cream one simply modified. How do the vin plate of Elegant look like.
The 1958 Fiat does not have PA (Premier Auto) stamped.
Old 17th September 2016, 18:57   #725
Stanher's Avatar
Thanked: 1,672 Times
That's quite a find!
Where did you see this car btw? In Bangalore or Madras?
Stanher is offline   Reply With Quote
Old 17th September 2016, 20:58   #726
Karthik1100's Avatar
Thanked: 368 Times
Attachment 1555236
The front grill badge is certainly not original. As it is millEcento and not millIcento.
Karthik1100 is offline   (1) Thanks Reply With Quote
Old 18th September 2016, 07:19   #727
Thanked: 728 Times
Thanks, I overlooked this small detail. But then even I spelt is incorrectly 😁.
The car is in Bangalore right now.
Do any one has VIN plate information of Elegant Fiat. Also then this car then should have the millecento badge.
Old 21st September 2016, 14:35   #728
schakravarthy's Avatar
Thanked: 4,127 Times
Spotted today at a garage in Mysore
schakravarthy is offline   (5) Thanks Reply With Quote
Old 21st September 2016, 19:57   #729
Thanked: 54 Times
There seems a Millicento Station Wagon in the background
jagadeesh.b is offline   Reply With Quote
Old 21st September 2016, 20:10   #730
That's a Select.. atleast, it used to be one. See this:
http://www.team-bhp.com/forum/vintag...ml#post4061263
schakravarthy is offline   (2) Thanks Reply With Quote
Old 23rd September 2016, 15:08   #731
Spotted at a garage in Mysore
(PC: Deepak)
Old 3rd October 2016, 17:07   #732
Thanked: 728 Times
Continuing on the discussion held here
http://www.team-bhp.com/forum/vintag...y-india-9.html (Vintage and Classic Cars on Display in India)
http://www.team-bhp.com/forum/vintag...mumbai-85.html (Fiat Classic Car Club - Mumbai)
http://www.team-bhp.com/forum/post-w...er-select.html (Restoration - 1963 Fiat 1100 Super Select)
I was given a special permission to photograph the car standing at the Lal Bahadur Shastri Museum. Not many parts on the car are original and would take a lot to get there, but still a nice one. Here are the pictures -
The front is beautifully done (lenses are not original tough)
The rear re positioned fiat script, note the nice period registration number.
The car sports whitewall tyres. The wheel caps have typical nuts to keep them in place.
Restored Fiats (Super Select & Others)-parliament-parking-sticker-1024x574.jpg
As with many Delhi cars, this one has registration number inscribed on the window glasses as well
The original roof light and grab handle
The original cloth door trim, installed during the restoration.
Old 3rd October 2016, 17:11   #733
Thanked: 728 Times
Continuing further -
The under dash area is not the best spot of this car (understandable for a display only piece)
The engine seems original but with most of the original items replaced.
I was allowed only a little amount of time to picture the beauty. So could not check on VIN numbers and any other details.
manishalive is offline   (4) Thanks Reply With Quote
Old 4th October 2016, 15:16   #734
Stanher's Avatar
I think we can call this car 'Delhi 6'!
http://www.gstatic.com/tv/thumb/movi...21_p_v8_aa.jpg
Stanher is offline   (1) Thanks Reply With Quote
Old 23rd October 2016, 20:16   #735
Spotted by a friend at Indiranagar, Bangalore.
schakravarthy is offline   (3) Thanks Reply With Quote
Restoration - 1963 Fiat 1100 Super Select karlosdeville Post-War 100 12th April 2018 12:46
My 1962 Fiat Super Select - the journey begins. SuperSelect Post-War 382 4th May 2017 20:00
1964 Fiat 1100 Super Select - A little makeover for her 50th Anniversary celebrations! dudesam24 Post-War 16 24th November 2016 12:30
Fiat Super Select sunilgee Post-War 9 5th January 2010 16:33
Bridgestone Select SUPER - Faridabad tsk13 Tyre & Alloy wheel Section 4 28th November 2009 20:18
