Old 17th March 2010, 14:39   #571
samsag12's Avatar
Thanked: 206 Times
My car has been used extensively for about 17K Kms without oil change.Although many brand oils have been poured into the engine till today. Every packing on the engine of the car is leaking oil. guess it can be rectified by changing them. For the oil, i think if i use the flush agent to flush out the old oil, then pour new one with new filter the engine will run smooth. BTW car's engine is drinking some oil i think as there is some amount visible on tail pipe.
Old 17th March 2010, 14:44   #572
Thanked: 21 Times
Sagar: Looking at your description of your car, I would suggest you to go for a complete restoration of the car.
If not 100% restoration, at least start off with the mechanicals... May be after few months you can do the body work.
arun1100 is offline   Reply With Quote
Old 17th March 2010, 16:45   #573
Thanked: 114 Times
it is pretty evident where you went wrong. Not changing oil on time is THE PRIMARY REASON for reduced engine life or even complete engine failure in cars.If the cars recommended oil change interval is 10k, change it at 8k. if its at 5k then atleast change it by latest 5k. oils are rated by api. api sf is the lowest rating permitted for marutis. the company provides sf oil so do hp, bp and io petrol pumps. its better to go for highest api rating oil available from premium oil manufacturers like gulf castrol and mobil 1 etc.
internationally api sf became obsolete 25 years ago , but i dont know why we are still stuck with it
addendum: the highest rating oil available today is api sm for most modern cars this is the best oil but for cars like the padmini the best oil is the previous api sl. for the reason check this out--API Motor Oil Service Classifications
mycarhasablower is offline   Reply With Quote
Old 18th March 2010, 14:04   #574
john a milne's Avatar
Thanked: 407 Times
In speaking to P.K Chowdhury who sold my 1962 Fiat Deluxe to me, he mentioned that he thought that the car had been imported.
I don't think so as it has the bench seat and the original upholstery was similar to Indian built cars.
However to leave no stone unturned, I am posting the Engine #103d-000 PA 28141B & Chassis #103D-876180.
Can anyone confirm if these are Indian?
john a milne is offline   Reply With Quote
Old 18th March 2010, 14:49   #575
samsag12's Avatar
Thanked: 206 Times
Today i saw a pair of old horns in scrapyard which looked like Jalwa make but they were not Indian. Can any body tell which make and from which nation the original horns were whose replicas were Jalwa horn(indian make). BTW asking price is 400 Rs. Should i buy it or not?
Old 18th March 2010, 18:29   #576
adheesh's Avatar
Thanked: 35 Times
Engine is Indian. PA stands for Premier Automobiles. The body shells of all the Selects and SuperSelects were imported from Italy. "Made in Italy" is engraved near the chassis number plate on these cars.
Adheesh Parelkar
adheesh is offline   Reply With Quote
Old 18th March 2010, 20:38   #577
boeuff's Avatar
Thanked: 63 Times
Originally Posted by arun1100 View Post
Shell Helix HX5 must be better for our cars. Shell says its for 13+ years old cars who do frequent stops and short trips.
Shell Helix HX5 - INDIA
Depends on your engine condition, John Milne's has low oil pressure so he will need a more viscous oil to maintain the pressure.
boeuff is online now   Reply With Quote
Old 18th March 2010, 20:46   #578
Thanked: 4,736 Times
Dear all - NO ADDING ANY DIESEL / FLUSHING AGENT IN THE ENGINE. IT WILL RUIN THE LUBRICATION CHARACTERISTICS. THIS IS ALL NONSENSE THAT MECHANICS KEEP ON SPREADING, I FAIL TO UNDERSTAND WHY. JUST DRAIN OLD OIL WHEN THE ENGINE IS HOT (10 MINUTES AFTER SWITCH OFF IS IDEAL), ADD NEW OIL AND CHANGE OIL FILTER. USE PUROLATOR OIL FILTER ONLY. BE CAREFUL, THERE ARE NUMEROUS FAKES FLOATING ALL OVER THE PLACE.
The best way to clean an engine (if you are "hell bent" on doing it) is to remove the engine from the car, drain the oil, remove the clutch assembly, stand the engine on the flywheel, remove the sump and then wash it from inside with petrol only (no kerosene). Clean any grit stuck tothe oil pump suction mesh with a knife. Assemble the sump with a new gasket. It would be a good idea to replace the timing chain, water pump, manifold gaskets etc during this time. THERE IS NO OTHER WAY, WHICH PLEASE NOTE.
Best regards,
Behram Dhabhar
DHABHAR.BEHRAM is offline   (2) Thanks Reply With Quote
Old 18th March 2010, 21:12   #579
samsag12's Avatar
Thanked: 206 Times
Today i returned the cyclo engine flush after a lot of discussion on this thread regarding not to use it. I am going to replace the oil with a new one (sae 20w-40) rated. Will change the oil filter and want to know what other gasket and packing of engine should be changed as i have purchased major engine packing set. Presently i intend to replace the head gasket along with rocker cover/tappet cover gasket.
BTW Is manifold packing also included in the kit??
Old 18th March 2010, 21:16   #580
Thanked: 21 Times
The major engine packing set includes manifold, water pump packing too.. So are you changing the head gasket? Click pics of the engine head please. I want to see how it is..
Old 18th March 2010, 21:23   #581
samsag12's Avatar
Thanked: 206 Times
Pics of the engine head?? After removing or a general shot of is as is. Yes i intend to change the gasket (head) Should i not change it??
Old 18th March 2010, 21:28   #582
Thanked: 21 Times
Pics of the head when removed...
Its a tedious task to change it... Follow "Behram's First Law"... If everything is working in a Fiat, don't touch it.
Old 18th March 2010, 21:34   #583
funkykar's Avatar
Thanked: 1,740 Times
I too agree with the first law. Dont just change the gasket for the heck of it. If you open up the head, be ready for surprises. You never know what until you open it.
funkykar is offline   Reply With Quote
Old 18th March 2010, 21:36   #584
samsag12's Avatar
Thanked: 206 Times
Thinking of getting the car thoroughly serviced and greased followed by changing the oil replacing the oil filter. BTW the oil filter is to be replaced after the old oil is completely drained ?? Just clearing my doubts as i don't want to take chance.
Old 18th March 2010, 21:49   #585
Thanked: 21 Times
Make sure you fix the new oil filter and air filter back.
The lovely Premier Padmini S1 (Fiat 1100-D) Ram The Indian Car Scene 393 28th May 2018 15:40
Fiat 1100 / Premier Padmini - Parts to Stock for FUTURE! arun1100 Post-War 343 11th May 2017 16:57
My 1973 (FIAT 1100) Premier President President Post-War 208 17th September 2015 00:13
Fiat 1100 "Family" -1962 -Technical, Photos & Information john a milne Post-War 64 29th May 2012 11:15
Used Maruti800, premier padmini , premier 118ne ? sakharamcool Hatchbacks 8 27th May 2008 11:17
