Old 25th April 2010, 15:37   #646
Thanked: 4,682 Times
In Mumbai it is 150. I guess it's OK.
Best regards,
Behram Dhabhar
DHABHAR.BEHRAM is offline   (1) Thanks Reply With Quote
Old 25th April 2010, 16:47   #647
Thanked: 21 Times
Funkykar recently bought complete set of SAFEX Tinted glasses for his NE from scrapyard. He paid 600rs.
arun1100 is offline   Reply With Quote
Old 25th April 2010, 17:07   #648
funkykar's Avatar
Thanked: 1,728 Times
Originally Posted by samsag12 View Post
Karthik bhai (funkykar) if you have the S1 manual do share the said pics.
I too dont have it Sagar
If you find one, please send me an e-copy.
funkykar is offline   Reply With Quote
Old 25th April 2010, 17:44   #649
samsag12's Avatar
Thanked: 206 Times
@DHABHAR.BEHRAM thanks again for the help. Will think of buying it. The glass is of a very good condition padmini scrapped yesterday. Even the door and other panels were in original upholstery held up by clamps. Not a sign of rust anywhere. Know this as i myself folded the sleeves & got down with a screwdriver to unscrew some parts.
BTW what type of manual was Arun bhai talking of. Was it the owners manual or repairs manual?? I only have the owner's manual in orange shade but currently its misplaced. ASA i find it will post the soft copy to you Karthik bhai.
Old 25th April 2010, 18:16   #650
Thanked: 21 Times
I have the Owner's manual.
We are till waiting for Adheesh to send a e copy of the repair manual.
Adheesh/BD Sir.
Old 25th April 2010, 20:38   #651
samsag12's Avatar
Thanked: 206 Times
You have the owner's manual of S1. Then please upload the wiring diagrams from it.
Me too waiting for the service manual from Adheesh.
@Adheesh please upload the manual for the benefit of all.
Old 26th April 2010, 01:01   #652
Thanked: 113 Times
please add me to the list of ppl in line for the service manual
mycarhasablower is offline   Reply With Quote
Old 27th April 2010, 12:43   #653
Thanked: 20 Times
My 137D is Having Nissan gearbox. Now some problem is there in the gearbox. so it needs overhule. Is it possible to detach gearbox only without removing engine. My mechanic told me that engine has to be removed first.
thanks
mituadas is offline   Reply With Quote
Old 27th April 2010, 12:51   #654
samsag12's Avatar
Thanked: 206 Times
Sir how can the tranny be removed without engine removal as it is attached behind the engine and mounted on the chassis. The mechanic told you the right thing. Am not a fiat guru but know some common things.
Old 27th April 2010, 13:17   #655
ilangop's Avatar
Thanked: 582 Times
It can be removed. I had the clutch plate replaced in my 118 NE without getting the engine out of the engine bay. No idea about the PP.
ilangop is offline   Reply With Quote
Old 27th April 2010, 13:28   #656
adheesh's Avatar
Thanked: 34 Times
thanks
The transmission can be easily be removed without removing the engine. This is a very basic procedure and is followed during the clutch/pressure plate replacement. Such lack of knowledge from the mechanics side is termed as BMR ie."Basic mein rada" (reference from BD Dictionary). With such BMR, I doubt the competency of the mechanic to handle the gearbox issues since the gear box is compared to the Pandoras box and is best left to the experts.
Adheesh Parelkar
adheesh is offline   Reply With Quote
Old 27th April 2010, 21:22   #657
vkarulkar's Avatar
Thanked: 7 Times
Procedure:
1. detach prop. shaft from oth ends
2. disconnect shifter rods (in case of column shift)(i have worked on column shift fiat only and not on floor shift)
3. remove cross member below gearbox and disconnect reverse lighting switch
4. keep some support below gearbox and remove all mounting bolts.
5. pull out the gearbox away from engine and and you are done.
Please correct me if i am wrong.
vkarulkar is offline   Reply With Quote
Old 28th April 2010, 06:22   #658
samsag12's Avatar
Thanked: 206 Times
Originally Posted by vkarulkar View Post
Procedure:
Oh didn't knew that. But this way of tranny removal takes lesser time than opening engine or not?
Old 28th April 2010, 12:58   #659
vkarulkar's Avatar
Thanked: 7 Times
Its the fastest way. Only thing is you need to get under the car and do all things and pull out the gearbox. If you are interested in unmounting the engine do as follows:
1. DIsconnect cables going to alternator and earthng cable.
2. remove air filter and other stuff to make working easier
3. Unmount the engine
4. disconnect prop. shaft and remove cross member below gear box.
5. remove radiator and engine fan
6. take pulley n hook.
7. tie the engine to hook and then you can remove engne and gearbox together.
8. Then you can transfer engine and gearbox together on some bench and work comfortably on both.
This procedure is advisable if you want to work on engine and gearbox both. But to remove gearbox only, previous method is best. Opting to second method will be like using battle tank to kill the rat.
Old 28th April 2010, 14:15   #660
rajeev k's Avatar
Thanked: 1,736 Times
Originally Posted by CrackedHead View Post
I came across a set of standard sized pistons today - these had grooves for 4 piston rings as opposed to the usual three. (two compression rings and two oil rings). Can someone tell me if these are any better/worse than the usual design that has three rings?
I need parts for a re-bore job.
I feel the fourth groove would in fact help in reducing oil consumption and also would provide required compression. I remember in the 90s for Ambys this was preferred and the 4th groove used to be below the piston pinor gudgeon pin which in the long run would reduce wear due to piston skirt vibrations.
rajeev k is offline   Reply With Quote
Fiat 1100 / Premier Padmini - Parts to Stock for FUTURE! arun1100 Post-War 343 11th May 2017 16:57
The lovely Premier Padmini S1 (Fiat 1100-D) Ram The Indian Car Scene 391 1st February 2016 07:42
My 1973 (FIAT 1100) Premier President President Post-War 208 17th September 2015 00:13
Fiat 1100 "Family" -1962 -Technical, Photos & Information john a milne Post-War 64 29th May 2012 11:15
Used Maruti800, premier padmini , premier 118ne ? sakharamcool Hatchbacks 8 27th May 2008 11:17
