Old 27th October 2010, 11:36   #811
adheesh's Avatar
Thanked: 34 Times
Originally Posted by samsag12 View Post
Thanks a lot Adheesh for the correct readings. Really appreciate that. I plan to get the timing of my car checked so what tools are needed for this work. Hopefully an old electrician (he worked on our fiats for the past 24 yrs) would be having the said tool. I think i just need to tell him the correct reading. What do you say.
As my signature on this forum goes, theres only one way to set the ignition timing correctly. Follow these steps.
1. Set the point gap to 0.40 mm. (This should give you the dwell angle as 58 degrees.) If you have access to a dwell meter, set it to 60 degrees which is the company specification.
Please note that changing the point gap changes the ignition timing. Hence it has to be done BEFORE setting the ignition timing.
2. Get the distributor rotor to fire the first cylinder ie. it should point to the cable that goes to the first spark-plug on the cap. On normal cars, you can keep the car in neutral and move the fan with you hand. To do this on the S1, you would need to move the car by pushing it with the fourth gear engaged till the rotor comes to the desired position.
3. At this point when you look at the main pulley, (There are 3 of them ; Alternator/Dynamo, Waterpump and the main pulley) you'll see four markings on the pulley. Three together and one to their left. Move the car in the fourth gear slightly so that the center mark of the three marks together corresponds to the mark on the timing cover. Now put the car in neutral so that this position of the engine doesn't change.
4. Turn on just the ignition (where the two lights would turn on). Now loosen the 10 mm bolt of that holds the distributor. Its a longitudinal bolt pointing towards the transmission just below the main distributor body.
5. Rotate the distributor until theres spark in the CB points. You'll hear a distinct click. This is the critical position. Without moving the distributor, tighten the 10mm bolt.
6. Put the distributor cap back and start the car. It WOULD start in half a crank.
7. Now with the engine idling and warmed up, check the timing again. Fine adjustments can be made with the micrometer screw given on the distributor while the car is running.
Now hence forth, if the valve train if all right, even after thousands of kilometers, you'll just need to set the point gap to compensate its wear and tear. The ignition timing will automatically be right. Thats the beauty of this mechanism.
Adheesh Parelkar
adheesh is offline   (1) Thanks Reply With Quote
Old 27th October 2010, 15:49   #812
samsag12's Avatar
Thanked: 205 Times
Adheesh once again thanks a lot for providing the step by step procedure to set the ignition timing. I really admire your fiatful passion. I will definitely carry out the said work, with the help of a mechanic, as per your reference and keep you updated on this.
Old 27th October 2010, 16:44   #813
manishalive's Avatar
Thanked: 710 Times
Adheesh Parelkar
I see you suggesting the use of Dwell meter, but for timing you did not suggested timing light (if avaialble). I think that will be more easire to understand and adjust.
please correct me if I am wrong.
Old 27th October 2010, 22:33   #814
Fiat&Me's Avatar
Thanked: 25 Times
Default All nipples set for Padmini
I have done some basic engine overhauling, interior and painting overcoat of my 1987 make Padmini in 2000. I remember at that time my mechanic changed all greasing point nipples.
Now almost after 10 years, is it required to change all nipples?
If yes, what is approx. cost of set? which make? How many per 1 set?
How much we should pay to mechanic?
Fiat&Me is offline   Reply With Quote
Old 28th October 2010, 09:52   #815
adheesh's Avatar
Thanked: 34 Times
In the seventh step, I did mention checking the timing with the engine idling for finer adjustments. This can only be done with the timing light !
adheesh is offline   Reply With Quote
Old 28th October 2010, 10:29   #816
Thanked: 710 Times
Oh my mistake . By the way I have got timing light, rpm/dwell meter, feeler gauge, vacuum gauge + compression gauge and lastly multimeter which I think are good enough tools to tune a Fiat.
Any thing else would you reccomend off?
Old 29th October 2010, 09:49   #817
adheesh's Avatar
Thanked: 34 Times
If you are rebuilding the engine in your car yourself, a torque wrench should be ideal.
Old 29th October 2010, 09:52   #818
ilangop's Avatar
Thanked: 581 Times
I always wanted to have a set of box spanners with a torque wrench, but always backed away due to financial constraints
ilangop is offline   Reply With Quote
Old 29th October 2010, 09:53   #819
Thanked: 710 Times
That's the missing piece in my Tool Box, also my mechanic too dosent have the same. After the festival we will be assembling the engine :O}
What range would suffice for our fiats. Yesterday I bought a new box and some spanners / tools missing from years of use.
Old 14th November 2010, 19:16   #820
freakmuzik's Avatar
Thanked: 388 Times
Mods: Please move post if posted in wrong section.
Guys,
Do you have any information regarding the A/C that came along with the PP Deluxe BE? Because, i was told by my A/C mechanic that hereafter gas cannot be refilled in PP's as there is some sort of a regulation with regard to the gas used/ the A/C system used. Not sure what it is though. Hence he said that the A/C unit has to be changed in order to make it cool hereafter!
He also added that this might cost somewhere around Rs.10,000!
Any idea guys, please help.
Regards & Thanks
freakmuzik is offline   Reply With Quote
Old 14th November 2010, 22:25   #821
Thanked: 113 Times
@freakmuzik :its the age old r12 refigerant to r134a shift problem. well ideally there should be a change in most parts, but honestly, your mechanic is trying to make money off you. Back in the day r12 refridgerant was used but then it was banned since it damages the ozone layer.
all you need to do is change the compressor oil to an r134 compatible oil, change the expansion valve and the receiver drier bottle, and also blow air through the system to remove all traces of the old r12 oil.then refill the system with new r134 gas thats used in vehicles today. Should cost maximum 2.5-3 thousand
and go to a different mechanic this time round
mycarhasablower is offline   Reply With Quote
Old 15th November 2010, 23:06   #822
freakmuzik's Avatar
Thanked: 388 Times
Wow, that was a quick reply. Thanks a lot. Lucky that i did not replace the system according to his words! Will surely try this and i am surely going to try some other mechanic. Thanks a ton mycarhasablower
Old 18th November 2010, 09:00   #823
whicked wheels's Avatar
Thanked: 56 Times
Default premier padmini 95 s1, got my car yesterday.
hi guys, got my dream fulfilled of buying an s1 after selling my earlier padmini some seven years back. Some things i need help on, the earlier owner has fixed a maruti carburater he says the car gives about 16 kmpl but i was not too happy with the performance, the car is sluggish in intial pick up. No douth the car is going for a service and tune-up first but should i change it back to the s1carburater or will it get better with a service. Some pics of the car.
The FIAT 1100/Premier Padmini Technical Information thread-16112010269.jpg
The FIAT 1100/Premier Padmini Technical Information thread-16112010270.jpg
The FIAT 1100/Premier Padmini Technical Information thread-16112010271.jpg
The FIAT 1100/Premier Padmini Technical Information thread-16112010272.jpg
whicked wheels is offline   Reply With Quote
Old 18th November 2010, 10:54   #824
samsag12's Avatar
Thanked: 205 Times
whicked wheels congrats on the purchase. The car looks quite good physically ( being a S1). I think its a EXECUTIVE model. Please do revert back to the original Solex Bicsa carburetor which i hope that the seller has given to you. A well tuned one will give you 13-14KMPL with ease. Also whats the condition of the engine. DO post some interior and engine bay snaps for further comments.
Old 18th November 2010, 15:06   #825
Thanked: 56 Times
thanks samsag12, the owner has not given the original carburater but he has promised to do so. Just got the old tattered and dirty seat covers removed and to my suprise the original uphostry was asgood as new, not torn nothing. Gave it a good vaccume cleaning and are looking fresh. The engine seems to be running fine.a little misfiring and stalling in cold but once she gets to tempreture its ok. The owner said he had just serviced it but i am going to change all the lubricants, filters, cords, spark plugs, point and condensor. Is there any thing i should look at too. The car is a delux be model, a/c and it has floor gears. Will post pics of the interiors and the engine bay in an hour or so.
Fiat 1100 / Premier Padmini - Parts to Stock for FUTURE! arun1100 Post-War 343 11th May 2017 16:57
The lovely Premier Padmini S1 (Fiat 1100-D) Ram The Indian Car Scene 391 1st February 2016 07:42
My 1973 (FIAT 1100) Premier President President Post-War 208 17th September 2015 00:13
Fiat 1100 "Family" -1962 -Technical, Photos & Information john a milne Post-War 64 29th May 2012 11:15
Used Maruti800, premier padmini , premier 118ne ? sakharamcool Hatchbacks 8 27th May 2008 11:17
