Old 27th June 2012, 13:24   #961
Thanked: 4,682 Times
Default re: The FIAT 1100/Premier Padmini Technical Information thread
Dear Bulldogji - Oh, now I understand. If you have fitted to bigger engined cars (american cars generally have big engines and generally consume a lot of fuel), the mass flow may not be sufficient. Need to check. thanks for the information.
Best regards,
Behram Dhabhar
DHABHAR.BEHRAM is offline   Reply With Quote
Old 12th July 2012, 08:34   #962
samsag12's Avatar
Thanked: 206 Times
I need some help from fellow members regarding the location of temperature pin on the Konkorde (padmini speedo console with clock) type meter. Have tried a no. of times to locate it by trial & error but couldn't find the exact pin. I am attaching a pic of the said meter & pin socket.
The FIAT 1100/Premier Padmini Technical Information thread-image0097.jpg
The FIAT 1100/Premier Padmini Technical Information thread-image0100.jpg
Old 12th July 2012, 10:11   #963
ilangop's Avatar
Thanked: 582 Times
How did you check the console? You to power up with 12V at keyon. Connect the ground point to the Illumination light's ground. Take one more wire from the ground and check at one pin after the other. At the exact pin, the needle will show full deflection.
-Ilango
ilangop is offline   (1) Thanks Reply With Quote
Old 12th July 2012, 14:54   #964
samsag12's Avatar
Thanked: 206 Times
-Ilango
I have a spare meter on which i checked using a 12v battery. Have located the ground pin, (its the 32nd element in a matrix form )
I don't want to pull apart the fitted meter as its a herculean task to remove and fit it back.
Will try my luck with the spare meter one more time.
Old 14th July 2012, 23:47   #965
100kmph's Avatar
Thanked: 92 Times
Is it possible to fit a 12 V power source somewhere in the dashboard. Could it be fitted without drilling any holes on the metal dashboard?
100kmph is offline   Reply With Quote
Old 15th July 2012, 10:57   #966
samsag12's Avatar
Thanked: 206 Times
Yes a 12v power socket/ cig. lighter can be fitted without drilling hole on the dashboard. You have to procure a metal plate (looks same as the one on which the choke knob is fitted) which can be screwed under the dashboard & the socket fitted on it.
Here's a pic for reference.
samsag12 is offline   (1) Thanks Reply With Quote
Old 16th July 2012, 12:36   #967
100kmph's Avatar
Thanked: 92 Times
Is the engine oil filter for the old Fiat 1100Ds and Padminis the same as the newer versions? The mechanic told that the older models had a separate chamber for fitting the oil filter(just behing the cooling fan) but in the newer versions the filter is directly fitted(tightened) to the block. The old type oil filter is difficult to source now-a-days. Does the filter of any other car fit inside the chamber?Another query-Is Indian Oil SAE 20W-40 oil suitable for the engine and EP 90 for the gearbox and differential.The mechanic has also added coolant in the radiator diluted with distilled water. When I asked whether it is necessary to install a coolant expansion chamber he said that it is not required. Is it the right way to use coolant?
Old 16th July 2012, 16:59   #968
ilangop's Avatar
Thanked: 582 Times
1. Is the engine oil filter for the old Fiat 1100Ds and Padminis the same as the newer versions? The mechanic told that the older models had a separate chamber for fitting the oil filter(just behing the cooling fan) but in the newer versions the filter is directly fitted(tightened) to the block. The old type oil filter is difficult to source now-a-days. Does the filter of any other car fit inside the chamber?
2. Another query-Is Indian Oil SAE 20W-40 oil suitable for the engine and EP 90 for the gearbox and differential.
3. The mechanic has also added coolant in the radiator diluted with distilled water. When I asked whether it is necessary to install a coolant expansion chamber he said that it is not required. Is it the right way to use coolant?
1. Yes, the filters are different. Veteran Fiat enthusiats would be able to help you locate the Original filter cartridge. Just wait for a reply from them.
2. Yes, the oil specs are right.
3. Adding coolant is not mandatory as we dont live in a snow covered region where the water freezes in the day. But adding coolant is good because it contains some anti-rusting agents that prevent rusting in the Cast-Iron block of the Fiat engine. Expansion chamber is REQUIRED to collect the expanded water / coolant mixture while the engine is warm and then draw water back into the cooling circuit once the engine cools. Otherwise coolant would be lost though the drain hose and you will have to top it up very often. An expansion chamber wouldn't cost you more than a 100 or 150 bucks. Just buy one and fit it.
-Ilango
Old 16th July 2012, 18:12   #969
100kmph's Avatar
Thanked: 92 Times
Is it possible to fit a power steering in a Fiat 1100D. If possible, the assembly of which car can be an easy fit without many alterations.It becomes very difficult to park the car in tight spots . Actually there are no cross roads in our locality,the only way to turn the car the other way is to move the car back and forth. As the road is only 16 feet wide, it takes about 10 minutes to turn the car only. This is very cumbersome on a daily basis. So fiat gurus please suggest the way of fitting a power steering.
Old 16th July 2012, 21:10   #970
pradipk's Avatar
Thanked: 21 Times
Not exactly the solution to your query but:
With my personal experience with my PP (not the 1100D), I would say it's steering is quite smooth and doesn't need power steering. Also, ideally it's good to move vehicle while turning in manual/power assisted both case. It's good for mechanical parts + tyres.
Just my thought though, let's see suggestions on the query you have.
Thanks,
Pradip.
pradipk is offline   Reply With Quote
Old 17th July 2012, 08:55   #971
ilangop's Avatar
Thanked: 582 Times
Hi 100Kmph,
Your answer regarding "If it is possible?" - Yes absolutely possible, but requires the help of a skilled person who has done this many times or one who knows what he does.
But, this is not going to change your turning radius because a power steering system doesnot alter the geometry of the linkages. It only assists. So you might still have to drive the car back & forth to turn your car. Only the effort put in from your side will be reduces.
As it is, the PP's steering system is butter smooth if the steering ball joints and king pins are properly lubricated. If not change all the ball joints & king pin journals and feel the difference. You will never again think of a power steering.
ilangop is offline   Reply With Quote
Old 17th July 2012, 09:13   #972
Dear 100kmph - there were two types of engine oil filters in Premier Padmini cars. 1. Behind the fan. 2. On the LH side of the cylinder block.
The first one is a bypass filter. The second one is a full flow filter. These filters are as different as apples and oranges, parts are not interchangeable. Full flow oil filter has better performance as compared to bypass oil filter. Full flow oil filter was introduced in production in 1986, first in black economy cars (Mumbai Taxies) and then in all cars. In bypass oil filter cars, the oil pressure relief valve is located externally. In full flow oil filter cars, it is located inside the oil sump.
If you are not using a surge tank, use only soft water in the radiator, there is no need for coolant except for the advantages as mentioned by Ilangop. Don't waste money un-necessarily. Please drain all old water by opening the tap behind the distributor. If it is jammed 9it will be), use a 14 mm spanner to remove the tap completely from the cylinder block, then clean the sludge in the cylinder block hole for the dirty water to come out. If this is not done, the cooling system will not get flushed. The best solution is to use the S1 degassing tank. I am attaching a photograph of one of my cars' engine compartment, showing the engineered fitment solution. The part number for the filler pipe is PAB48431 and for the return pipe is PAB48432 but in my case, the return pipe length is extended due to adaptation of the degassing tank with vertical flow radiator instead of cross flow radiator.
Do not even think of power steering. Ensure that the production system works properly. Ensure that you have 220cc of SAE140 grade oil in the steering gear box and all joints are properly lubricated. Also ensure that the tires are in order. Tire hysterisis can play havoc with the entire car and you will waste money doing things not required to be done.
Best regards,
Behram Dhabhar
The FIAT 1100/Premier Padmini Technical Information thread-100_0190.jpg
DHABHAR.BEHRAM is offline   (4) Thanks Reply With Quote
Old 20th July 2012, 08:57   #973
ilangop's Avatar
Thanked: 582 Times
Dude, Was brain storming about the power steering option such that it wouldn't affect the geometry of the steering systems. How about transplanting a Maruti Suzuki or Hyundai Electric assisted power steering. You will only have to retrofit the steering column and wire the system. Mostly the system would require a 12V power supply and a vehicle speed input. Any web based suzuki or Hyundai workshop manual can help you in this regard. But be warned, this mod would require some cutting & welding of the Steering column support frame on your vehicle.
Old 21st July 2012, 15:58   #974
Thanked: 930 Times
Hi 100 Kmph, I thought to add my two penny bits. Coolants are alcohol based solutions whose sole purpose is to raise the boiling point of water. Normal water boils at 100C, coolants boil at 120C.All modern cars have coolants because their normal operating temperatures are between 90 and 110 degrees Celsius, temperatures at which plain water turns to steam. In older technology cars, where normal operating temperatures are in the range of 80 to 85degrees Celsius, generally water suffices to cool the engine. However, if you are driving in heavy traffic with an air conditioner perhaps adding coolant is a good idea. This because once water boils, it transforms into steam, result? No cooling and major risk of damage to the engine. The anti rust properties are an added advantage . Having said this, a well tuned Fiat will not overheat, so its really your call. The steering geometry of Fiats is such that the steering is very light, so get your car checked thoroughly for possible faults. Power steering is not the remedy. Another cause for a heavier than normal steering is the tendency of putting oversize tyres.
Bulldogji is offline   Reply With Quote
Old 22nd July 2012, 18:09   #975
manishalive's Avatar
Thanked: 713 Times
Also, the coolant have lubricating properties good for the water pump seal.
Which is a good tyre option for fiat
5.20-14 MRF legend (with or without whitewall inserts).
or 165/80-14 of the Swift that I can get from my swift.
Fiat 1100 / Premier Padmini - Parts to Stock for FUTURE! arun1100 Post-War 343 11th May 2017 16:57
The lovely Premier Padmini S1 (Fiat 1100-D) Ram The Indian Car Scene 391 1st February 2016 07:42
My 1973 (FIAT 1100) Premier President President Post-War 208 17th September 2015 00:13
Fiat 1100 "Family" -1962 -Technical, Photos & Information john a milne Post-War 64 29th May 2012 11:15
Used Maruti800, premier padmini , premier 118ne ? sakharamcool Hatchbacks 8 27th May 2008 11:17
