Old 4th November 2009, 21:03   #76
Stanher's Avatar
Thanked: 1,545 Times
Update again- we were blessed with progress again today, with the once-stubborn RH rear drum finally opening up at looong last!!
It was opened the same way as the LH one, described above. The lathe machine guys were visibly relieved! Then the whole shebang was loaded onto an auto rickshaw and taken back to the garage where the car is.
Unfortunately, my camera batteries were down at the time, so couldn't take proper pics. until I recharged them at a friend's camera store, by which time the diff. had already been opened up too:
Only the central flange at the front needs to be opened, for which my man's going to bring a box-spanner tomorrow morning. Then after scraping off the old muck, the entire exterior rear axle will be joining the leaf springs for sandblasting.
Both the rear drums/backplates and axle shafts stored safely inside the boot of the car. This rear drum too, doesn't look too bad, although is all seized solid with rust! 'hope we could get it to work.
NOTE: Contemplating giving the drums too (but NOT the backplates) for sandblasting as well. Is this recommended?? Anyone who's successfully done this before? Advice from experts welcome.
Stanher is offline   Reply With Quote
Old 4th November 2009, 21:28   #77
IndrojitSircar's Avatar
Thanked: 113 Times
Well i think you should just scrape them down for the time being and then paint them with primer.Later when you do the final painting of the car then you could paint it with epoxy black.This is what we had done on my mercedes have a look at these pics you will understand what i am saying http://www.team-bhp.com/forum/vintag...ml#post1395081 (Calcutta-Restorer/Collectors-Bumpu Sircar)
Old 4th November 2009, 22:44   #78
Stanher's Avatar
Thanks. I remember seeing pics. of this car before, looks nice. No offence meant but it looks like it was an unrestored car, and reasonably roadworthy? So the brake drums may not have gone through as rough a time as these? Another alternative I have in mind is to get them scraped, then treated with caustic soda then use phosphoric acid on them? In the end of course, I do intend to paint them.
Old 4th November 2009, 23:03   #79
Thanked: 113 Times
Well it is unrestored now.It was last restored close to 15 years back.After that this car has not participated in any rally or event because we didn't have the tyres for the car.Now this year in june we have got the tyres imported and then we decided to take it for a spin as the engine and all is in perfectly running condition.We just opened the drums to service them only to find that the oil seals had vorne out.Since we opened it we decided to change both the oil seals and flushed the differential.Now having opening all four drums then it was decided to paint them as well so that when we start the restoration process we don't have to open them again.The car was jacked up for 8 years and then was moved from our previous residence to our current one and for about 7 years.Its alright i understand. I have uploaded a pic of it when it last went to the rally its on that thread.
Why do you want to increase your work ?You have enough on your plate at the moment.So i think going for a simpler method would be worth considering.
Old 7th November 2009, 16:41   #80
Stanher's Avatar
Apologies for the break but my net was down y'day!
, interesting to know about your car! 'glad it's up and running now.
Anyways, update: On second thought, it was decided to not get the springs sandblasted, jus tthe diff./rear axle would suffice. So the springs came back with us on our 2nd trip when we went to hand over the axle the other day, in my car.
It was finally done today. 'seems to have turned out well, at a reasonable enough price too. 'brought it back in my car again and left it at the workshop with the Vauxhall.
The guy was also thoughtful enough to put a cardboard packing over the housing cover, secured with 4 bolts, so as to prevent the sand from 'attacking' the flange(?) inside. This way, only the exterior got the sandblasting.
He had warned me to get the thing primered/painted ASAP, as it would otherwise tend to corrode again, also even if we touched it with our hands, our finger stains would stick on to it.
Old 7th November 2009, 22:50   #81
Thanked: 113 Times
Not a problem.
Well the car is running but not on the road.But am trying to see a way we can start.
Attachment 223411
Attachment 223412
Attachment 223413
Well that looks well done.Yes that is true you need to get the primer done asap even if you don't paint it now.Whats the status on the missing springs?
Old 8th November 2009, 11:18   #82
Stanher's Avatar
Still lying with the car at the garage only. 'hope to give them for resetting tomorrow. I want to get this suspension work done ASAP so my man can proceed with the engine and finally have the bodywork commence.
Old 9th November 2009, 11:23   #83
bluestraveller's Avatar
Thanks for the updates Shyam. I did pick up a few of the parts you suggested, they must be on their way to Bangalore now.
Found this video on you tube that features the Wyvern
bluestraveller is offline   Reply With Quote
Old 9th November 2009, 18:37   #84
Stanher's Avatar
My pleasure, santhosh!
Incidentally, was planning to get in touch with you again. Do let me know what all parts you managed to buy btw.
Nice video. however, note that its not a Wyvern but a Velox!
Update: Nothing much as of today- axle shafts given for throughing at the lathe. The garage guys meanwhile, had unfortunately neglected the sandblasted diff./axle, which I'd left the other day, requesting them to atleast put a coat of primer on! It happened to be rainy the last 2 days, so the axle got partly ruined, showing signs of corrosion again!! Grrrrr!! I'm quite upset with this today!
Their painter was not available today, so they said will get it primed tomorrow.
Old 9th November 2009, 19:32   #85
Thanked: 113 Times
Has any portion with the sand blasting got washed off?
Old 9th November 2009, 20:12   #86
Stanher's Avatar
Doesnt look like it was washed off but got a couple of rusty-ish stains!!
Old 9th November 2009, 20:20   #87
Thanked: 113 Times
use some sand paper over the rust spots to clean them and then paint it ASAP other wise its going to grow.
Old 9th November 2009, 20:45   #88
Stanher's Avatar
Sure thing. BTW, just a thought I had of painting the thing RED instead of the more common black! Is it worth it, considering that this part would be well-oiled/greased most of the time?
Old 9th November 2009, 20:52   #89
Thanked: 113 Times
Well why not you can paint it any colour you wish to there is no hard and past rule about painting black.
Old 11th November 2009, 02:12   #90
Thanked: 113 Times
Mr. Shyam updateswith pics
Acquiring a Vauxhall Wyvern 1961 SILVERWOOD Post-War 11 6th May 2010 14:03
2010 Vauxhall VX8R Bathurst ..560hp Invinsible The International Automotive Scene 13 16th February 2009 06:37
Vauxhall on a Contessa artofzen Modifications & Accessories 18 1st September 2006 12:46
Vauxhall Ventura ananthkamath The International Automotive Scene 19 17th August 2005 10:11
Vauxhall Agila SLK The International Automotive Scene 8 27th September 2004 00:12
