Old 29th July 2009, 16:10   #121
manishalive's Avatar
Thanked: 734 Times
i found very interesting site comprising of scooter manuals, sadly no Lambys
Index of /manuals
Posted here cause many scoot lovers visit this page. for deviating from topic.
Old 29th July 2009, 16:22   #122
suren181's Avatar
Awesome manish, I just happened to get a very comprehensive manual of the Vespa, one of which I own, at this link. Thanks a ton.
suren181 is offline   Reply With Quote
Old 29th July 2009, 17:48   #123
Thanked: 734 Times
My pleasure friend. Many thanks to Team Bhp.
Old 29th July 2009, 19:51   #124
Sidman's Avatar
Thanked: 15 Times
Originally Posted by SA7VA5 View Post
Hey Mole - wish you all the success in your resto job!
By the time they bring back the parts why dont you start with dismantling the scoot, inspecting the parts and chassis and correcting / repairing things.
Further to Saurabh's advice, do try to begin work on the engine first, when you get hold of the engine parts. This approach was what my mech followed, and it worked well for us. All the best!
Sidman is offline   Reply With Quote
Old 29th July 2009, 22:57   #125
SuperSelect's Avatar
Thanked: 224 Times
Default Awesome !
Awesome, Saurabh, simply awesome. Went through your thread (comprehending just as much as a scooter challenged guy possibly could !!) This is mind blowing man.. Your attention to the minutest of details, and your dedication to procurement of 'nothing but the best and original' for your baby is what makes your Lambretta stand out. This will probably be the best Lambretta in India - dare I say the world ?
Hats off to you buddy. Feel like making a trip to Dilli to take a peek !!
SuperSelect is offline   Reply With Quote
Old 30th July 2009, 19:46   #126
the mole's Avatar
Thanked: 719 Times
Hi Saurabh, Believe me i cant wait to get started, but right now the scooter is in Poona, need to finish some paperwork before I get her to Bombay and open her up for restoration. In the meanwhile I am chasing a 4 wheeler project, If that works out I will truck both of them together
the mole is offline   Reply With Quote
Old 3rd August 2009, 17:53   #127
Thanked: 136 Times
Default Front Fork
Hi Team,
Just an update !
The front fork has been set up. Did not use the hammer and tongs method but the front fork spring compressor tool to set it up. It was quite a breeze to set it up this way.
Now the fork is ready to go into the chassis with new bearings and bearing guides.
Here are some pics of the tool in action and the final finished fork assembly.
And thanks to all of you for the kudos!
Cheers!
Saurabh
SA7VA5 is offline   Reply With Quote
Old 4th August 2009, 20:53   #128
the mole's Avatar
Thanked: 719 Times
Saurabh while you put together your beauty can you please put up some research on Paintcodes etc and your knowledge on the topic. Just getting into the Lambretta learning mode. BTW managed to get a original LI 150 owners manual for my Scoot.
Old 17th August 2009, 14:49   #129
Thanked: 136 Times
Default Latest Update
Hi Team,
Am attaching the latest status of the project.
Over the long weekend was able to do up the wiring and cabling all in OE format using the imported Friction Free cables and the harness imported from SR England.
The stator was installed and the rear junction box (thanks to Arun) was also installed with its rubber cap and all wiring connected to the right locations.
The front small mudguard and big mudguard were also rubber coated and are now being cured before installation. The horn too was installed.
The rubber bump stopper for the stand was also installed.
The clutch cable, gear cable locater was installed on the chassis tube in the front and also the cable holder behind the Choke knob was installed and all cables wired up.
The rear brake cam was installed and so were the brake pins. The rear brake drum studds were installed and the rim with new tires mounted on to the drum.
The next is now the ignition timing that I need to do using a timing disc. New CB Point and Oiling Felt was installed on the stator as well.
Am attaching a few pics for all of you to enjoy.
Cheers!
Old 17th August 2009, 17:57   #130
Thanked: 136 Times
Default oWNER'S MANUAL
HI Mole,
Can you please send me a xerox copy of the Owner's manual? That'll be nice to have!
Cheers!
Old 17th August 2009, 22:38   #131
the mole's Avatar
Thanked: 719 Times
HI Mole,
Cheers!
Sure buddy! PM me your address.
Old 18th August 2009, 18:48   #132
Thanked: 136 Times
Smile
Some more updates.
The wiring harness has been prepared for OE standards - all bullet connectors redone to spec.
The stainless steel hardware has arrived from England for all the exterior nuts and bolts and am attaching pics of the same for your reference.
Cheers!
Saurabh
Old 20th August 2009, 21:58   #133
the mole's Avatar
Thanked: 719 Times
Hi Saurabh, any names or websites for the SS hardware kits? How much did the tailight lens cost you, and what brand is it?
Old 21st August 2009, 18:50   #134
Thanked: 136 Times
Hi Mole,
My brother in law in England gets me this stuff from local restorers or shops. There are plenty of them with websites. Cambridge Lambretta, MB Developments, etc.
You can order through any one of the sites too but if the weight is high then be prepared to visit the customs office too!
The lens is from Bosata Itally.
24.2 % is the duty rate.
Cheers!
Old 27th August 2009, 12:58   #135
Thanked: 136 Times
Hi The Mole,
I am still waiting for the copy of the owner's manual you promised to send.
Cheers!
1968 VW Beetle Restoration - From God's own Country PAVAN KADAM Post-War 23 20th July 2014 23:00
My Lambretta LD ! A new restoration project SA7VA5 Post-War 25 25th March 2013 11:28
3 recent acquisitions - A Lambretta & 2 Vespas. Update: restoration of 1973 Lambretta wbd8779 Post-War 44 8th January 2012 07:33
Restoration of my 1968 Lambretta girishpv Post-War 6 6th May 2011 16:53
1968 CJ3B - upgrade project gbanavar 4x4 Technical 176 9th January 2011 12:08
