Old 20th May 2010, 18:47   #196
Thanked: 2,470 Times
Originally Posted by funkykar View Post
On a positive note, its good the issues showed up before car reached the owner. If not, it might have been embarassing. Good luck on the last few remaining bits Pavan!
Originally Posted by IndrojitSircar View Post
It really doesn't matter sir.Its an old car, these things are bound to happen. There is nothing to be embarassed about.
Yes Indrojit,
I've decided against a loooong journey with this car. No Way.
Also, the gearbox and diffrential thing can be avoided if its only a show car driven within the city.
I understood, under our limited resources, its only better to get the present combination running best.
It will be a major job, if it involves the engine, gearbox and diffrentials
Which at the present situation is ruled out.
Got 140 grade gearbox and transmission oil, will infuse them tomorrow.
Tomorrow will be another set of testing, hope nothing new crops up.
All in all, the car is good to be driven around the city roads, i.e., for any road shows or for some classic and vintage car rally's. I hope thats sufficient.
Old 21st May 2010, 00:37   #197
IndrojitSircar's Avatar
Thanked: 116 Times
Yes Indrojit,
One this is don't give up and the other is the more you drive it the more reliable the car will get.The problems will keep cropping up and the more you tackel them the finner the car will get.
Best of luck for tomorrow's day
Old 23rd May 2010, 01:43   #198
Thanked: 116 Times
So what is the Update now ? Is the overheating problem sorted out? What are the results of the road tests conducted now ?
Old 26th May 2010, 10:05   #199
Presently Aaaalll izzzzz well......
What was diagnosed as gear box issue was just drop in the oil level, But the main trouble is with the engine shaft, thats making some grinding noise. Mech says, 3k we can get a good Amby engine and can be transplanted.
Need to work out on the options, With the car owner not in country and my pockets already bleeded too much into this project, work presently is on hold.
Car is running fine, without any issues . But alignment is become a BIG issue at hand, no one has readings for this kind of set-up. I went to get it done manually, but they are not able to find the washers / shims for alignment
Pending work.
1) Engine related issue
2) Firewall to reduce in-cabin noise and heat.
3) Upholstery
4) Rubbing and polishing.
5) Alignment.
Old 26th May 2010, 18:01   #200
manishalive's Avatar
Thanked: 734 Times
5) Alignment.
Alignment is a real pain in neck. Shims might be available at Industrial stores. The easiest way to diagnose misallignment and or bearing issues is by vibration meter (but i don't think so if any body uses them in cars).
Bye the way does your gearbox mount directly on flywheel housing or do you have some spacer plate to match the mounting holes. In either care if the mating surface is not warped allignment should not be an issue.
Old 26th May 2010, 18:26   #201
Have ordered shims from one guy, might get them by week end.
No spacer, since the amby engine is a BMC engine and the wolsleys had the similar block the engine mates, but the trouble starts with the clutch operation and powerful engine.
Old 27th May 2010, 10:36   #202
Thanked: 734 Times
Then our problem is not that of allignment and that of matching / sizing . I believe Behram Sir will have some advice for us. Basically the characterstic curves of the Engine and that of gearbox should match in order to have a good matching.
Old 28th May 2010, 02:30   #203
Thanked: 116 Times
My suggestion is since the car has an amby engine why not put in an amby gearbox and then just sort the problem out once and for all.You can then get ridof the tandem master cylinder and have a normal cable operated clutch and also change the master cylinder and put in a new master cylinder with a matching servo? Your brakes , clutch and gear box problems are sorted out and then the car can be a reguler user and that is the ultimate aim isn't it ? Consider what i said.
Old 1st June 2010, 00:27   #204
Thanked: 116 Times
What's the update ?
Old 1st June 2010, 00:33   #205
What's the update ?
The car is running fine apart from the grinding noise in the engine.
Getting the rubbing polishing done and now planning to drive it to the owners house.
Will drop it , as its a big risk on my part to keep a neatly painted car.
Will upload some more pics of the car tomorrow.
Old 1st June 2010, 00:35   #206
Thanked: 116 Times
Ok one thing i would say is please check all the engine and Gearbox mounthings once again.Looking forward to the pics.
Old 3rd June 2010, 10:38   #207
Some updates,
Nothing much, car is running fine, covered and parked.
Old 3rd June 2010, 11:15   #208
Thanked: 734 Times
Some updates,
The car is looking awesome and the only sore point is the front windshield, if the chromed insert variety was in abundance, the same would have looked awesome.
Old 3rd June 2010, 12:05   #209
Thanked: 116 Times
If we are looking from the originality prospect then it is just right but if you are thinking from the prospect of a show car then i agree with you.
Old 3rd June 2010, 12:30   #210
Thanked: 734 Times
yes yes show car, that's how the owner wanted it. With all that chrome in the front, the windscreen rubber looks out of place.
Blog on Terrible accidental repair experience at VW Bhopal sridhu Indian Car Dealerships 53 19th May 2014 13:54
Blog on terrible dealership experience at Pinnacle Nissan, Thrissur Gannu_1 Indian Car Dealerships 10 11th January 2014 16:27
Driving a British car on British roads - The Mini Cooper S! raj_5004 The International Automotive Scene 9 14th August 2013 09:47
Terrible experience of booking a Dzire vdi from Modern Automobiles, Ambala natthu Indian Car Dealerships 6 22nd May 2011 19:05
Terrible experience with i-Phone, dealer and service; advice needed Guna Gadgets, Computers & Software 10 21st October 2009 12:29
