Old 13th April 2010, 22:17   #91
Thanked: 2,459 Times
Some updates on the painting process.
Very little metal paste used, mostly to cover the light dinges.
Polyster patti used.
Tomorrow we are spraying Dupont 888 surfacer.
Old 14th April 2010, 09:51   #92
Thanked: 70 Times
Dupont is certainly a good paint. But it is difficult working with it.Too technical. Hardner,thinner everything in exact ratios;something our painters do not have the knowledge to understand. Above all, very very expensive. I have decided to go with Duco ordinary. Less headaches. With a clear coat, finish is as good
C.S.ANANTH is offline   Reply With Quote
Old 14th April 2010, 12:41   #93
President's Avatar
Thanked: 176 Times
Ananth Sir, I fully agree with your above experienced decision. Conventional ordinary Duco is easy to use, very economical, uncomplicated method of application and can give a very good Period finish on a Vintage or Classic car, if all the material procured is Genuine.
President is offline   Reply With Quote
Old 14th April 2010, 13:20   #94
harit's Avatar
Thanked: 2,723 Times
Hi did you notice the similarity between the doors and dicky lid of this car with those of an Ambassador?
I have a suggestion to use the front windshield of an Ambassador on the rear of this car as it is anyway modified. I have done that to my Amby and have a great rear view, very helpful when driving, the blind spot created by the window frame is reduced as the glass is quite large.
But maybe it is too late for that.
Cheers harit
harit is offline   Reply With Quote
Old 14th April 2010, 14:29   #95
Cheers harit
Too late sir, but that experiment is been done already, very unsucessful in it, because the rear is toooo curvy to take the amby front winshield, it fits outside the car.
So we custom made a frame upto the outer lines of the car and got a toughned glass made to the frame size.
I have used Duco on 1 car sometime back with a dupont clear coat, results are good for few months and year, the shine remains for a longer period, but the depth of color is lost within the second year.
Dupont might be a trifle pricey, but results are there on all the cars that i've painted over the years. So i shall stick to Dupont
Old 14th April 2010, 14:53   #96
Thanked: 54 Times
Yes, for vintage and classic car the period look can be got only with Nitrocellulose paint like Duco,Nerolac, but the painter should be a n expereinced guy.
kishorelal is offline   Reply With Quote
Old 14th April 2010, 15:08   #97
Thanked: 140 Times
why would the owner want to do this to a classic? you should have just told him to leave the car with you and try out his silly stunts on an amby outfitted with all the bells and whistles and lights to satisfy his cravings. No offence meant to you Mr Kadam, but i think i would have blown my top if I were in your shoes . Anyways all the best.
howler is offline   Reply With Quote
Old 14th April 2010, 19:34   #98
Ha ha....!
My thoughts were the same when i started.
But i clipped my wings and did not want to be toooo ambitious.
I know for everyone this project seems to be a fun project, but its actually not.
To do something creative and yet retain a bit of originality, its a tough task, only time will tell the final result.
Old 14th April 2010, 19:43   #99
wasif's Avatar
Thanked: 366 Times
I still feel you guys should have chopped the roof off and turned it into a convertible...now that would be a real interesting SHOW Car
wasif is offline   Reply With Quote
Old 14th April 2010, 23:30   #100
manishalive's Avatar
Thanked: 702 Times
Chop the roof, Lower the Car, Bigger, fat tyres on the rear, Hot Rod the Californian way. Mind blowing
Old 14th April 2010, 23:44   #101
Stanher's Avatar
Thanked: 1,539 Times
(*Continuing on a LIGHTER note*)
Hey, you forgot the supercharged N2O powered engine to plonk in!
Stanher is offline   Reply With Quote
Old 15th April 2010, 01:13   #102
tantragna's Avatar
Thanked: 23 Times
Pavan, I am noticing from quite a while that these painters/body workers do metal paste work on bare metal. It is not advisable as it has no corrosion resistance properties. It should be applied over a coat of primer (synthetic/oil based, like PU/red-oxide).
The 'metal paste' name refers to the metal like hardening of the material after application & not intended to be applied over bare metal. I advise you to speak to the painters on this.
And going by your restoration spree, I guess you have a good & ample space for parking these beauties. ;-)
tantragna is offline   Reply With Quote
Old 15th April 2010, 23:05   #103
1) We had put on the primer which was sanded down.
2) Metal paste work done later and again very little paste remains after sanding it down
3) Polyster putti also applied generously all over the surface, again sanded it down, only the blade marks and light dinges were covered.
4) Oil putty sprayed, again let it to harden for 24 hrs, and again sanded it down.
5) Tomorrow, we are spraying a high quality Dupont surfacer (Rs 2850/- a litre) and also spraying Dupont matte black on the car as base shade.
6) Monday will be the final spray of Dupont White (Ermine) (Rs. 4850/- per litre) and Dupont Burgandy (Rs 4900/- per litre) and over and above that 2 coats of Dupont Clear (Rs. 2900/- per litre)
7) I am buying a HVLP spray gun for the painter this time to get an even and a high gloss finish.(Cost Rs. 6750/-)
Also notice the bottom 2 inch of the body surface, the painter has coated a strip of anticorrosion polyster strip.
Painting cost is high, even the procedure involved is meticulous while handling costly paints, my painter is confident of pulling it off succesfully.
Monday is there for all to see.
Old 16th April 2010, 00:00   #104
Stanher's Avatar
I must say I like the way your guys carry out the painting process, pavan!
I'd be interested in this strip, could you find out where it is available and how much for how much?
Old 19th April 2010, 16:41   #105
Well shyam, will share the secret over the phone sometime.
We sprayed the C series or the 7 series Dupont surfacer on the car yesterday. This surfacer costs Rs 3000/- per litre and no thinner needs to be added. The worst part is if you dont complete the spary within 15 mins, the complete mix becomes hard as stone.
Advantages of this surfacer.
1) Great binding properties
2) Fills in many tiny scratches on the body surface
3) Gives an even surface
After this is done, the painter will sand down few microns of the surfacer and apply Dupont Tube putty ( Rs 346/- per 200 gms)
Some updates
Blog on Terrible accidental repair experience at VW Bhopal sridhu Indian Car Dealerships 53 19th May 2014 13:54
Blog on terrible dealership experience at Pinnacle Nissan, Thrissur Gannu_1 Indian Car Dealerships 10 11th January 2014 16:27
Driving a British car on British roads - The Mini Cooper S! raj_5004 The International Automotive Scene 9 14th August 2013 09:47
Terrible experience of booking a Dzire vdi from Modern Automobiles, Ambala natthu Indian Car Dealerships 6 22nd May 2011 19:05
Terrible experience with i-Phone, dealer and service; advice needed Guna Gadgets, Computers & Software 10 21st October 2009 12:29
