Closed Thread
Old 23rd September 2009, 14:00   #16
Lucas_2007's Avatar
Thanked: 12 Times
Originally Posted by adheesh View Post
Approximate prices of all the brake parts are as follows
1. Liners : Rs600-800 for all four (in exchange with your old ones which fetch some 200 bucks)
2.Wheel Cylinders (TVS Girling): Rs250-300 each (For some odd reason, the front and the rear wheel cylinders are priced differently)
3. Master Brake Cylinder(TVS Girling) : Single Piston Rs.1200 (For cars before 89-90's) Double Piston Rs.2200-2500
4. Brake Oil Dot 3 : Rs.206/liter (715ml is required + bleeding)
Lets please continue this discussion in the Fiat1100/Premier Padmini Technical Information thread.
Adheesh Parelkar
i am having some sort of problem with my brakes. suddenly the brake pedal goes down but doesn't touch the floor.brakes still work at that point. my master cylinder is single piston (1986 model).i noticed one strange thing also. the pedal automatically comes up & becomes firm after driving a distance of around 30-40 km. What to do?
Lucas_2007 is offline
Old 23rd September 2009, 16:13   #17
manishalive's Avatar
Thanked: 733 Times
Spongy Pedal, but i just don't understand why it firms up after driving 30-40 km.
Two reasons associated 1. Locked air in the system, Bleed the system.
2. If Pedal firms up after 2 -3 back to back pressing, then you need to Service the Master Cylinder.
manishalive is offline
Old 23rd September 2009, 21:26   #18
adheesh's Avatar
Thanked: 35 Times
Manish is right bang on the target ! Either there is air in the system (which needs to be bled down or the master brake cylinder is on its last verge. Go to a good mechanic and get the whole braking system throughly checked.
PS: Please continue the discussion in the Fiat 1100/ Premier Padmini Technical Information thread since a lot of the above posts are off topic for this thread.
Adheesh
adheesh is offline
Old 24th September 2009, 06:38   #19
Rudra Sen's Avatar
Thanked: 4,288 Times
I agree with Adheesh here. Please continue with your discussion on the thread he mentioned above.
Thread closed.
Rudra Sen is offline
Closed Thread
Honda Fit (Jazz in India) gets a fit-ting facelift sidindica The International Automotive Scene 16 17th August 2011 10:03
Machismo 350 AVL Technical Specs - Engine Oil, Clutch and Gearbox Amount and Specs imbue Motorbikes 1 26th April 2011 19:59
Retro fit seat belts 71Convertible Post-War 9 21st February 2010 13:34
Columnshifters: Engine and gearbox 'Retro' fit kavesh55 Modifications & Accessories 1 31st July 2009 14:16
