Old 6th October 2017, 21:15   #316
anjan_c2007's Avatar
Thanked: 5,186 Times
Default Re: Vespas and Vespas only
I used to see this scooter parked near Garware bridge everyday when I was in college. At the time it had a chrome plated complete handlebar! I assume it has now been replaced with a later model set, as this one should have had the protruding speedo from the earliest models.
Yes Karl, its in the vicinity of the Garware Bridge (off Deccan Gymkhana area). Its a 1965 model and in fact, these originally came with the protruding (from the Veglia speedo slot) bracket with the Yenkay speedo.
The owner could have replaced it with a Bajaj 150 handlebar, given the rickety Bajaj speedo it has now.
anjan_c2007 is online now   Reply With Quote
Old 23rd October 2017, 10:01   #317
schakravarthy's Avatar
Thanked: 4,127 Times
Spotted by a friend
schakravarthy is offline   (5) Thanks Reply With Quote
Old 25th October 2017, 11:55   #318
Spotted now
schakravarthy is offline   (3) Thanks Reply With Quote
Old 26th October 2017, 19:22   #319
SunnyBoi's Avatar
Thanked: 2,829 Times
Saw this Vespa needing a lot of TLC :( apologies for the blurry pictures, I was a passenger in a moving car.
SunnyBoi is offline   (2) Thanks Reply With Quote
Old 2nd November 2017, 14:59   #320
Majumdarda's Avatar
Thanked: 425 Times
Dada, I can very much relate to that number and the font. Ours is a WNK 267
Originally Posted by hillram View Post
I am trying to start restoration of our Vespa XE. The scooter has fond memories associated with it and now that dad is here with me for few days at Pune and the topic started, why not try procurring the parts and send it with him to WB. But apart from not getting the correct seller for spare parts, the other challenge is getting the correct part. It seems "to me", that the LML Vespa XE that was sold here in India was a customized version of the P125X. I am not too sure, but deciphering this on the base of the looks only. Can anyone of you please share your thoughts on this.
With regards to restoration, not much has to be done and I am sure if i can get a good pair of hands, the engine can be re-tuned to its original glory. But the body parts are breaking now and they need to be replaced.
Below is how I plan to progress on this restoration (Cost vis-a-vis time)
  • Immediate requirement : Complete external body parts including of headlights, bulbs etc.
  • Intermediate : Complete wiring.
  • Last : Electrical and remaining electronics. Our scooter will then become a oldish newish Vespa XE
Majumdarda is offline   Reply With Quote
Old 4th November 2017, 13:49   #321
Majumdarda's Avatar
Thanked: 425 Times
Originally Posted by schakravarthy View Post
Rescued my friend's granddad's Vespa XE from rusting away in peace.
My friend intends to restore the scooter and put it to regular use.
What is the status on the XE's restoration? Do you have shops at your place from where parts can be procured? I am looking for certain body parts for my Vespa XE.
Old 4th November 2017, 14:18   #322
My friend got it sorted mechanically - though there wasn't much that was needed to start with.
The scooter had most of the trims intact - what was missing was the 'Piaggio' monogram and the original headset - both of which I managed to procure from an abandoned XE.
schakravarthy is offline   (1) Thanks Reply With Quote
Old 4th November 2017, 20:23   #323
Stanher's Avatar
Thanked: 1,672 Times
My advice- now that tis mechanically sorted out, suggest to your friend to just try and run it as is for a while before he thinks of taking it apart to restore it. This way, he'll get to know all the weak points as well, which can be tackled when he finally get to restore it properly.
Too many people get over-enthusiastic about restoration of their vehicles only to realise mid-way how daunting it actually is and then give up; the dream project ends up as a ghost project! Are the documents updated btw? FC? Insurance? These are far more important issues to tackle than cosmetic restoration.
BTW, this is the same cream XE with the 'hasty' paint job right?
Stanher is offline   Reply With Quote
Old 11th November 2017, 10:00   #324
Exactly what I told him; took a while to convince, but he finally came around.
That was the first thing we did, actually. Papers are up-to-date and the scooter's transferred to my friend's name.
Aye.. hasty 'n' pasty
schakravarthy is offline   Reply With Quote
Old 8th January 2018, 18:57   #325
Spotted today
Old 14th January 2018, 19:01   #326
Took mine along to complete the picture
Old 13th March 2018, 18:22   #327
Spotted today
schakravarthy is offline   (2) Thanks Reply With Quote
Old 18th March 2018, 09:45   #328
Spotted this artwork Vespa outside my home.
schakravarthy is offline   (4) Thanks Reply With Quote
Old 28th March 2018, 03:52   #329
d4v3's Avatar
Hi Sean, Scootering Magazine UK had an article on the APSL Factory a few years ago, in it was mentioned the sighting of various odd smallframe/largeframes mixtures lying about in the APSL factory. I always wondered if there is a link with the Taiwanese smallframes. GNAL for example had some sort of collaboration with PGO, as peculiar headsets were identical. Let me know if you need any other info for your book.
Originally Posted by Skwirly View Post
Hi Elegant Pig!
I'm guessing that you are referring to one of two models, the first, manufactured in India by Andhra Pradesh Scooters Limited is the PL170. The second, manufactured in Indonesia by PT Danmotor Vespa Indonesia is the P100TS. Both models are built on the same platform as the Vespa 50 Special, and use a slightly differnet chassis with a left side cowl glove box. Both have a four speed manual transmission 100cc two-stroke engine. It is more likely that the model you've heard of is the PL170 manufactured from
1982-1987. If you have any more questions, just ask.
d4v3 is offline   Reply With Quote
Old 16th April 2018, 17:13   #330
Spotted today
Restored Classic Vespas & Lambrettas rangaraj Post-War 50 1st October 2016 21:32
Future Perfect! China-only/Sedan-only car Brands SankalpDesai The International Automotive Scene 1 8th August 2012 16:52
3 recent acquisitions - A Lambretta & 2 Vespas. Update: restoration of 1973 Lambretta wbd8779 Post-War 44 8th January 2012 07:33
Bird watching....but only the feathered kind only Perez Travelogues 9 1st April 2009 12:28
Your One and Only Vehicle v12 The International Automotive Scene 101 21st August 2008 14:11
