Old 24th May 2011, 15:27   #361
President's Avatar
Thanked: 177 Times
Default Re: MPR 4142, 1959 Fiat 103D Select Restoration.
Very good going Manish.
Sounds like a plan!
Professional and methodic restoration.
Am watching this thread closely.
President is offline   Reply With Quote
Old 24th May 2011, 17:33   #362
manishalive's Avatar
Thanked: 711 Times
Sounds like a plan!
Thanks rony for the comments. You might have seen the pics elsewere.
I will update once the final tinkering is over as per painters satisfaction.
I have one big question. how to paint the engine block and exhaust manifold. they are to be red oxide painted. But will the common redoxide last for that much heat??
I checked high temperature paints and only silver and black are available. Please guide me.
Old 24th May 2011, 18:37   #363
samsag12's Avatar
Thanked: 205 Times
Thats some serious threat to rust. I am sure that after all this treatment MPR won't see even a trace rust for the coming 15 yrs.
I think your car would be a show car when completed. Do post some pictures, if possible.
Old 25th May 2011, 08:15   #364
Thanked: 711 Times
I forgot in between we have yellow zinc primer also sprayed . By the way I was recommending you Rust guard on your thread, it is 500 INR / liter and will work wonders in rust proofing our car.
Old 25th May 2011, 10:07   #365
mbz180's Avatar
Thanked: 552 Times
Have you already painted the underside of the car in the body colour? If you haven't, then I would suggest that you leave it at that. Mercedes Pontons when new from the factory also came with the underside the same colour as the body, but subsequent restorations have done away with this, and have left it at the rust proofing compound (such as epoxy paint) as that binds much better than normal paint.
What I mean to say is, that the last coat which will be the paint will be the first to get affected by rust. Just my 2 bits.
Best Regards
Prithvi
mbz180 is offline   (1) Thanks Reply With Quote
Old 25th May 2011, 10:14   #366
Thanked: 711 Times
Originally Posted by mbz180 View Post
Best Regards
Prithvi
Prithvi,
I am not getting you. what I have done is after cleaning applied rustolene, then yellow zinc primer then 3M underseal and finally paint. so for water to seep inside he has many layer of protection to go through.
The body color is only for cosmetic purpose.
Old 25th May 2011, 10:20   #367
mbz180's Avatar
Thanked: 552 Times
Prithvi,
I am not getting you. what I have done is after cleaning applied rustlene, then yellow zinc primer then 3M underseal and finally paint. so for water to seep inside he has many layer of protection to go through.
Your process is absolutely correct, but what I mean to say is that do not use normal body paint (NC or 2K) for the underside as the last coat. Use only epoxy based paint for the last coat. It binds much better to the previous layer.
At least that is what Bumpu Sircar insisted be done on my car, even though I wanted the body colour to be the final coat for the underside. With his experience, he must have a really good reason for insisting on epoxy paint.
Prithvi
mbz180 is offline   Reply With Quote
Old 25th May 2011, 11:07   #368
Thanked: 711 Times
Prithvi
Oh yes I got you now. Epoxy paint is the best. I have seen its application in petochemical industry. Now after this, for cosmetic purpose we can spray the color of our choice. In your case it will not make any differnce cause you are painting the car black.
Old 25th May 2011, 11:15   #369
mbz180's Avatar
Thanked: 552 Times
Yes, that is true. Indeed my car's body colour will be black.
Old 30th May 2011, 17:21   #370
beetle_boy's Avatar
Thanked: 58 Times
Hello Manish Bhai,
Please have a look and suggest me on the anti rusts you are using. Currently the vehicle has been scrapped and undergoing tinkering work.
http://www.team-bhp.com/forum/post-w...ml#post2371397 (My 1956 Fiat Millecento Restoration)
Thanks in Advance,
Saleem
beetle_boy is offline   Reply With Quote
Old 2nd June 2011, 12:18   #371
Thanked: 711 Times
This time on my visit to kolkata, I decided to have a spare day for looking for my Fiat parts.
I came in contact with mbz180 (Prithvi) and every thing was sorted out, his mechanic came along with me for the day. Tough we could not find much stuff there, but we managed to find one component which is holy grail for us Fiat lovers.
Original made in Italy fuel fump. After cleaning, this will be a looker.
I am thankful to Prithvi and his mechanic for such a lovely gift.
Old 2nd June 2011, 18:31   #372
mbz180's Avatar
Thanked: 552 Times
Thank you for the kind words Manish. I am glad you found something atleast. You are too kind though, my mechanic only pointed you to the right place I think. Always enthusiastic to help a fellow car nut, especially of the vintage and classic type
Best Regards
Prithvi
Old 3rd June 2011, 11:24   #373
Thanked: 31 Times
Dear Manish:
Congrats on procuring a golden part. But how reliable is it?A fuel pump has to be in top notch condition!
EARTHed is offline   Reply With Quote
Old 3rd June 2011, 15:48   #374
Thanked: 711 Times
Best Regards
Prithvi
Prithvi it is very toughf these days to find original stuff for Fiat these days and then to find one is like finding the holy grail.
Originally Posted by EARTHed View Post
Dear Manish:
Well it is not working . But could you leave that Italian part!! no. I have dismantled and I only need to change the diaphragm for the same.
Can any one lead me the source for the diaphragm or for the comeplete refurbishing kit which ever is available, I will be grateful.
Old 9th July 2011, 18:32   #375
Thanked: 711 Times
After a long time I am uptaing my thread, actually nothing seizable happened. And as usual I am hearing the "chalta hai" attitude of my mechanic. And then to get things done my way it takes time as I am only free on weekends.
First of all a big thanks to Indrojit for helping me with the fuel pump Diaphragm, which is the exact same part. I am excited, will test fit the part soon.
Now my mechanic has lost some small but key components like wheel cylinder spring, for which the project delayed. Now missing is the valve spring lock . Thank God list is small.
Comming to updates. As told earlier the underbody has been painted. 3M Under Sheild coating was used, here are the pics.
60% of mechanicals have been painted and assembled.
Those which were painted wrong or were shoddy looking were personally sanded by me and repainted.
This damper was painted black by the mechanic . I sanded it down to bare metal and then to have the same metalic blue shade.
The Logo / sticker / decal suggest the damper to be of 60-70's, good for me.
I took all the brackets, bolts, nuts and other stuff which was originally zinc coated for galvanizing. next set of photos denote the transformation.
The first two picture is of Dismantled original head light ring for Ravi bhau aka Superselect on the forum. Also the pictures denote the original fiat fasteners.
Today was the day of engine assembly, which has been postponed for a day as lot of prep work was required. As a sample I buffed the Inlet manifold and showed to the mechanic, which as usual was a waste of time for him.
Yesterday I will be assembling the engine , will use all the special tools also.
Restoration - 1963 Fiat 1100 Super Select karlosdeville Post-War 98 2nd January 2018 18:15
Restoration of "Vinty", a 1960 Fiat Select 1100! CAC444 Post-War 105 10th December 2016 01:13
Kolkata - 1959 Fiat Milicento / Select FIAT'57'Kolkata Post-War 48 4th September 2013 22:51
The MPR-999 is here! (Universal Learning Steering Remote Control ) frankmehta In-Car Entertainment 110 2nd April 2012 18:45
1959 Chevrolet Belair Restoration. junkmn Post-War 3 26th December 2010 12:47
